knep som funkar
finns det någon smidig lösning för att köra iplayer, hulu och andra regionsspecifika tjänster i sverige?
Inte vad jag vet. Det enda sättet jag kan komma på är att köra genom en proxylösning.
I can highly recommend http://vpnuk.info/shared-ip.html - You can subscribe to UK, US, French, Spanish, Dutch, Swiss or German IP address!
At any time you can modify what servers/countries you want and sign off or on specific countries.
With the Swiss IP, you can use Zattoo for watching A LOT of German and French speaking live television channels outside of the PLEX interface.
In the UK you can use TVCATCHUP to watch all FREEVIEW channels and they have an app for PLEX and soon a new and improved (direct streaming) app will be available.
It just WORKS and is cheap and the traffic is unlimited and the downstream is 10Mbit and 1Mbit Upstream, BBC iPlayer works flawlessly, even in HD!
Hulu has sometimes a few buffering issues, but generally works like a charm in PLEX, ABC, FOX and other (Move Networks) streams works 100% in both SD and HD, though they are not supported by any PLEX apps at the moment.
I have used this service for years and there are no subscription plan, you can cancel at any time.
There are some Apple Scripts you can download somewhere else on this forum (Sorry, cant remember the link), that you can access from the FAVORITES menu in Plex and you are connected to the VPN server in 2 seconds.
I am not affiliated with vpnuk or affiliates, i just loves their product!
They also have some great support and live chat support and are always very friendly and helping out if you have any issues with setting up your connection.
