The Documentation is insufficient and I didn’t find some good examples.
What’s the best practice to pass a Cookie to the Url Service?
Exists there any more documentation about the framework besides the ones linked here in the Sticky?
Is ‘Cookie = GetCookiesForURL(url)’ possible? Or do I have to go down the road to manually deconstruct a returned response header? I find it extremely irritating to use the build in functions the whole time and when there’s one case where the documentation lacks information I end up having to import urllib and requests to get one piece of logic done. I really need the cookie to retrieve the video url.
Can the URL Service Access the Data API feeded with Data from the main Plugin?
Can a global Search Service return a directory object?
It would be extremely helpful, if someone experienced could answer my questions.
1-I don’t think you can pass anything to the url service besides the url. Some channels like YouTubeTV create custom urls for the urlservice which can include extra data. like http://something.that.doesnt.exist/?foo=bar&cookie=stuff
You could try skipping using a url service entirely.
if you do something like this in channel code I think its pretty much the equivalent of using url= on an object.
4-I don’t think the URL Service can access anything from the channel (Dict, Data, Prefs, etc)
5-I don’t know about global search, I’ve just been putting a Search(query) function in my channel code and using an InputDirectoryObject to call it. I think global search would have stricter requirements on what you return.
