[Beta] PlexAmp icon is low resolution on Windows
I’m on beta v4.50.6
On the Windows taskbar, the PlexAmp icon is notably lower resolution than all the icons around it, even the previous version’s icon (on the right).
(Also, the Start menu only has one PlexAmp instance listed, and it launches the old one)
Should be fixed in the next release.
