I just tried to connect my RPi3 to my new samsung tv but I’m having some trouble with home video playback. No matter what type of file I use the image freezes during playback and then caches up a few seconds later. It’s not at specific intervals as it would be if it was a framerate issue and I can have long periodes of playback without freezing or buffering. It only happens with my home video files, Not with movies. Some home videos are running 25fps and some 30fps, while movies are running 23.976fps, but I have a few movies running PAL or 25fps and they seem to be running fine. Some files are called.MTS some are mp4, but common for all is that they are appended to each other in a .mkv container.
I’ve set my rasplex settings to always change refresh rate to video playback, but turning it off doesn’t change anything. It’s still buffering.
When I connect the same RPi3 to my older samsung tv (LE32C650) I get flawless playback when running all files. It only happen when using my new samsung tv (UE40H6505). Also when I run the home video files using the samsung tv plex app on my new tv I also get flawless playback, so the tv is capable of playing the files, which means it’s got something to do with the combination of rasplex and the new tv.
I’ve also checked if it for some reason was triggering transcoding and that’s why it was buffering, but my QNAP ts-251+ NAS isn’t transcoding during playback and ram and cpu usage is steady.
Here are a few info files showing what files is causing the buffering. If you need more info please tell me and i’ll deliver.
Hope someone can help! It’s really frustrating my new tv is performing worse than my old.
General
Unique ID : 212763481160243812251473250282178959595 (0xA010C18589650A3B89D1653424AD58EB)
Complete name : E:\Rejser\Costa Rica 2014.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 20.8 GiB
Duration : 3 h 9 min
Overall bit rate mode : Variable
Overall bit rate : 15.7 Mb/s
Encoded date : UTC 2016-09-16 19:01:25
Writing application : mkvmerge v9.4.2 (‘So High’) 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=12
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 15.3 Mb/s
Maximum bit rate : 16.8 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 50.000 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.148
Stream size : 20.3 GiB (98%)
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Compression mode : Lossy
Stream size : 521 MiB (2%)
Default : Yes
Forced : No
General
Unique ID : 163849585980393195494086188896898488096 (0x7B44484B771D9E779FAE8258770F9720)
Complete name : E:\Rejser\Borneo 2006.mkv
Format : Matroska
Format version : Version 2
File size : 16.9 GiB
Duration : 2 h 28 min
Overall bit rate : 16.3 Mb/s
Encoded date : UTC 2016-09-26T04:23:32Z
Writing application : HandBrake 0.10.5 2016021100
Writing library : Lavf55.12.0 / Lavf55.12.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 5 frames
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=10.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Delay relative to video : -23 ms
Title : Stereo
Default : Yes
Forced : No
General
Unique ID : 215773078820441379937290331564057844800 (0xA25462247D696C3FAC2D33F82BA45C40)
Complete name : E:\Rejser\Canada 2015.mkv
Format : Matroska
File size : 7.22 GiB
Duration : 43 min
Overall bit rate : 23.8 Mb/s
Encoded date : UTC 2016-09-12 19:03:53
Video
Format : AVC
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Duration : 43 min
Bit rate : 23.7 Mb/s
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.381
Stream size : 7.18 GiB (99%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 43 min
Bit rate : 127 kb/s
Frame rate : 46.875 FPS (1024 spf)
Stream size : 39.5 MiB (1%)
Language : English
Default : Yes
Forced : No
