Server Version#: v1.23.6.4863-6b3792414
Player Version#: app.plex.tv (hosted)
I just installed the latest PMS and there seams to be a problem with access to the DB. The PMS logs only contains the following:
Jul 26, 2021 17:59:23.434 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:25.676 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:27.908 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:30.134 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:32.358 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:34.595 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:36.825 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:39.053 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:41.278 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:43.504 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:45.730 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:47.956 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:50.182 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:52.409 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:54.638 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:56.865 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 17:59:59.092 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 18:00:01.322 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 18:00:03.552 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 18:00:05.789 [0x7f0b1ea3cb50] WARN - Waited one whole second for a busy database.
Jul 26, 2021 18:00:07.001 [0x7f0b1ea3cb50] ERROR - Database corruption: sqlite3_statement_backend::loadOne: database is locked
Looks like the SQLite3 process hangs (i guess). I did not previously have a problem with locked DB.
I tried to rollback a couple of versions. Rebooted - and it worked again. Updated to the latest (beta) version and it works. Looks like the latest fix doesn’t solve it completely (reboot required).
Can I convince you to try one more time so the full ZIP logs can be uploaded here and the issue investigated? A filtered excerpt is not enough to go on.
I would try again, but I think it will be hard to reproduce. Since I restarted the NAS and it works now. I did notice the previous release also had a fix for locked DB. This is the first time it has happened to me (no beta QNAP fw - just current stable rel)
The logs posted previously was actually the only log file that existed in the logs folder. Only missing the HW info.
Could you recommend some specific steps? I would gladly give it a try.
I’ll give it another try. I have “all” PMS versions available locally.
QNAP FW: 4.5.4.1723 (latest official stable)
PMS: Had no active streams/users. DVR idle.
Downloaded the latest PMS beta.
Updated it manually by QNAP “App Center” (did not stop Plex service before update)
Update completed without any problems.
I noticed in PlexWeb (hosted - google devtools), that it couldn’t connect to websockets (it tried 3 different - and one strange websocket host: 253.253.253.253). I could browse some sections - but clicking the latest movie I had added 5 min before - made everything hang.
This was the PMS log. No other logs existed in the logs folder, when this happened. I always clear the logs folder, when something strange happens. This time i forgot to make a backup, before delete though.
