Server Version # 1.16.5.1554
Player Version # 7.21.0.12128 Android Beta
Not sure if it’s been reported yet or if anyone else has had this happen, but I had 2 different Podcasts finish playing the file (last/newest file, so no “next” episode) on either show. As soon as the file ended the same file started playing over again. I had to stop the player and manually mark it as played.
Will send logs if/when requested.
On a side note, Thank you for fixing the “resume play after interruption” bug that has been plaguing the player for months now. Great job
Found another issue with this build of Android Beta, When accessing remotely I usually have to start at the Home Tab screen then proceed to the folder destination of my choice (IE: Home Tab > Music Tab or Home > Podcasts Tab) before it will load the folders without the “Retry” Splash screens.
But with this latest build trying to get to my Music Folder (after I goto the Home Tab) I have to choose the Audiobooks Folder first from the dropdown menu then use the dropdown menu again to choose my Music Folder, and now it has some issues that cause me to repeat the steps… Home Tab >
Music Tab >
Audiobooks Folder (usually defaults here, I assume due to alphabetical reasons) >
Dropdown Menu >
Music Folder
and this (randomly) doesn’t always work.
Yesterday and today It looks like this…
I couldn’t reproduce that issue myself, logs from that session could be helpful.
We’ve seen some other reports of this happening and we’re investigating the issue. Logs from the session would be helpful as well. In the meantime, a reinstall of the app should fix it, although it’s understandable if you don’t want to do that due to settings/synced content loss. We’ll let you know when this is fixed.
@marekszulik I’m having this same issue, happens constantly on my Pixel 3 running Android 9 and now 10. I multiple “offline” sources that are repeats of the online sources. The repeats increase until I clear the app’s storage, and then the process starts over. As far as I can tell, this only happens when I’m remote from my PMS server, usually on cellular.
