[BUG] Photos > SQLITE3:0x80000001, 28, double-quoted string literal: "2021-05-17 19:36:06"
I rolled back to 1.22.3.4523 and the problem is not present in the old server build. I don’t have the patience to roll through all the updates in the middle to nail down the update when the bug was introduced but that at least gives you a starting point :slight_smile:
It is not fixed. I keep getting this error, even when opening the home menu that does not have any photos pinned. It makes it load very slow and consume 100% of my cpu for 15 to 20 seconds.
Yep, still broken.
I am also seeing this error but not for pictures ( don’t have any loaded ) just a few TV and Movies
After looking at the logs, and some googling, I found that this is caused by some library called libva and the lack of support for NVIDIA hardware acceleration.
Turning off hardware acceleration fixed these issues for me. Hoping a future patch will fix this and allow me to re-enable hardware encoding.
@ChuckPa
If I may clarify ?
  1. libva is the framework API.
  2. If you add the QSV libraries, you get support for Intel Quick Sync Video – Which Plex as done and ships with PMS.
  3. If you add the Nvidia drivers, you get Nvidia support although the native Nvidia API is better. Plex uses the Nvidia-native API
  4. if you add the AMD drivers, even though not officially supported by Plex, you can get Plex to use AMD GPU cards. (you have to be 100% correct in how you do it).
If you will show me the logs of the failure, I might have the fix for it now.
I know what happened.
I’m also willing to bet that if you went back to 1.22.3 and enabled HW transcoding, it would work flawlessly. - which is a very quick way to confirm.
Would you like the solution now?
Additionally – SQLITE quoted string errors have nothing to do with Hardware Transcoding.
Updated to version 1.23.3.4692 yesterday and am no longer seeing this issue. I haven’t tested extensivily, but all indications is that my problem displaying some images appears to have been resolved.
I have something like this:
Time
Level
Error
Thread
Message
SQLITE3: 0x80000001, 28, double-quoted string literal: “2021-06-18 10:30:00”
Plex in Docker. Can it be fixed somehow?
What exactly is broken?
I changed the docker and now this message will not appear when starting the movie.
