There was an unexpected error loading this library
When I try and open my photos library on my plex server it shows up with this message (There was an unexpected error loading this library) is there anything that I can provide from my plex server to see why this is happening?
I get this error to when trying to load photos:
Ubuntu Virtual Machine via ESXi
Plex Server Version 1.11.3.4803
Reading from Drobo directory over the network
Anything video related works just fine with the same setup. Why?
same issue, newest version on windows 10. tried reinstalling pms several times. deleting and re creating several times. maybe itll work itself out w/ the next version. If not ill post up some logs.
fortunately photos are the leastimportant part of plex for me. That being said, i dont like it when things dont work as intended :stuck_out_tongue:
Plex Web App logging to be enabled - see https://support.plex.tv/articles/201611836-plex-web-app-logs/
Server Debug Logging to be enabled (this is default)
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
when error displayed, take screenshot - do not crop it (need to see time and url)
Collect logs
Plex Web App Log - see https://support.plex.tv/articles/201611836-plex-web-app-logs/
(view log, select all, copy to text file)
and server logs zip
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
and attach with time of error (crucial)
May I ask is where your library is located?
Usually this is because Plex is having a hard time scanning and extracting information from that library. This could include slow connections to that library…
Example: “The library I’m trying to access is on my friends computer who has a 56k connection to the internet”
This could mean:
  • Database Corruption
  • Permissions Failure
  • Hard Drive Failure
  • Disconnected or Slow External Hard Drive or other Media
  • Faulty or Slow Data Cabling to a LAN or WAN Library
Also, if you could produce some logs from your Plex Media Server, that would be helpful.
I am also having the same issue with one of my libraries.
Windows Server 2008 R2 SP1
Error occurred at 9:13 PM Arizona time (GMT-7)
Uncropped error screen snip:
I have attached the Plex Web and Server logs.
Same issue here.
Yep. Same issue
Chiming in to say I’m having the same issue with one of my libraries after upgrading to server version 1.13.0.5023. Error present on all clients.
It is a database corruption.
May 16, 2018 21:13:30.120 [2824] DEBUG - Request: [127.0.0.1:60760 (Loopback)] GET /library/sections/4/all?type=1&includeCollections=1 (21 live) TLS Page 0-49 GZIP Signed-in Token (josurr)
May 16, 2018 21:13:30.121 [2824] DEBUG - Setting container serialization range to [0, 49] (total=-1)
May 16, 2018 21:13:30.125 [2824] ERROR - SQLITE3:0x2bb2636a, 11, database corruption at line 72951 of [fc49f556e4]
May 16, 2018 21:13:30.125 [2824] ERROR - SQLITE3:0x2bb2636a, 11, statement aborts at 7: [select distinct metadata_items.id from metadata_items  left join media_items on media_items.metadata_item_id=metadata_items.id  left join media_parts on media_parts.media_item_id=media_
May 16, 2018 21:13:30.125 [2824] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
May 16, 2018 21:13:30.127 [4784] DEBUG - Completed: [127.0.0.1:60760] 500 GET /library/sections/4/all?type=1&includeCollections=1 (19 live) TLS GZIP Page 0-49 6ms 405 bytes (pipelined: 4)
Pre-existing database issues do show up after upgrades when the upgrade includes a schema update. This is because the action may access all database records
Please go through the following steps to attempt a database repair. The steps outlined on this support article Repair a Corrupt Database need a small adjustment and i will give that below
Download the Sqlite3-tools binaries zip from SQLite Download Page
Section Precompiled Binaries for Windows and unzip - you will use sqlite3.exe for the following steps
For your configuration, the database file path is
D:\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db
Shut down Plex Media Server (exit from system tray plex icon pop-up)
Part 1
The following sequence gives details of the corruption
sqlite3 com.plexapp.plugins.library.db "DROP index 'index_title_sort_naturalsort'"
sqlite3 com.plexapp.plugins.library.db "DELETE from schema_migrations where version='20180501000000'"
sqlite3 com.plexapp.plugins.library.db "PRAGMA integrity_check"
Part 2
The following steps attempt the repair saving existing db file to filename with .original extension
sqlite3 com.plexapp.plugins.library.db .dump > dump.sql
rename com.plexapp.plugins.library.db com.plexapp.plugins.library.db.original
sqlite3 com.plexapp.plugins.library.db < dump.sql
If you did not bother with Part 1 , the repair sequence would need to be
Now launch Plex Media Server
The above extra steps are needed for databases on versions 1.13.1.5063 onwards
@“studiozepp@gmail.com” said:
Same issue here.
@derfinatrix said:
Yep. Same issue
As explained above, it may be pre-existing db corruptions that showed up in this way after upgrading.
Please provide logs and screenshot of the error and time of error
See
Here are my screenshot and logs.
Thanks for any assistance.
Jun 05, 2018 14:25:19.697 [0x14744edfa700] ERROR - SQLITE3:0x10, 11, database corruption at line 72951 of [fc49f556e4]
Jun 05, 2018 14:25:19.697 [0x14744edfa700] ERROR - SQLITE3:0x10, 11, statement aborts at 11: [select parents.parent_id,count(*) from metadata_items as parents join metadata_items as leaves on leaves.parent_id=parents.id where parents.metadata_type = 3 group by parents.parent_id
Jun 05, 2018 14:25:19.698 [0x14744edfa700] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
Jun 05, 2018 14:25:19.699 [0x1474673ff700] DEBUG - Completed: [67.128.11.162:64581] 500 GET /library/sections/2/all?type=2&unwatchedLeaves=1&includeCollections=1 (13 live) TLS GZIP Page 0-49 38ms 478 bytes (pipelined: 8)
As you are on version 1.13.0.5023 the standard instructions for repair should apply
See
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
Thanks! Will follow the instructions to fix.
So, I followed the instructions over at: https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
and upon restarting my server, my logs filled with:
Starting Plex Media Server.
continuously until I stop the server. The servers shows offline from all clients. When I place the old database files back, everything operates normally again (except for the corrupted TV library).
Thoughts?
Thoughts?
I can see repeated crashes on startup due to the database being corrupt with a table missing
Jun 07, 2018 20:37:50.230 [0x14e4b5b4e800] ERROR - SQLITE3:0x10, 1, no such table: schema_migrations
Jun 07, 2018 20:37:50.230 [0x14e4b5b4e800] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
This continued until
Jun 07, 2018 20:37:54.236 [0x154558708800] DEBUG - Running migrations.
Jun 07, 2018 20:37:54.236 [0x154558708800] ERROR - SQLITE3:0x10, 1, no such table: schema_migrations
but the startup after this at Jun 07, 2018 20:41:28 was ok.
So did you attempt the repair between 20:38 and 20:41 ?
Did you bring back an older database ?
The database download zip is empty which indicates that the database still had some corruptions at 20:45 when the database download was attempted
I can have a look at the database if you send me a zip of it by private message and also some info on what was done between 20:38 and 20:41
The files to zip are
/config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
/config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
/config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-shm
If too big to attach in a message as zip, please upload to dropbox or similar service and send me a link to the zip
Sounds great, will do. Thanks.
I have looked at the database files and there are corruptions still
Could you go through the following repair steps
mv com.plexapp.plugins.library.db com.plexapp.plugins.library.db.original
and delete
and then restart the server
If you continue to have issues with the database then look for backup - the folder zip you sent me shows last successful backup was dated 25 April
This appears to have resolved the database corruption! Thanks much!
I have just add a pb of a db that could not be repaired. If this happens, pick up the latest backup, a large file finishing with a date tag like “com.plexapp.plugins.library.db-2019-11-19” and copy it to com.plexapp.plugins.library.db, then follow the repair instruction. In my case it worked like a charm, you will then only need to reload the meta data added since then.
Also, I cannot say for sure, but I suspect that optimising my db (i.e. from the menue) before repairing it was actually the source of the problem.
