Hello,
On every local playback of synced movie, the progress bar is not updated.
I have to stop the movie, back to the info in order to update the movie progress…
Are developers aware of this bug ?
Thnaks sixones for reopening the thread
Hello,
@“maxime.wantiez” can you check the version you have installed? I think latest beta should’ve fixed this. But if not, let me know the version and I’ll take a look.
Still not working
Version 6.8.0.2564 (72c68e70)
Nor Version 9.8.0.2591
I can see it update when I sync something and play it, can you tell me more about the situation? airplane mode maybe, or not connected to network? Can you make sure it’s 6.9.x and upload a record a video that shows the issue? Thanks!
Version 6.9 seems working.
i’ will do more test this evening
thanks for the reply ( and the work )
Hello @antoniolg
It seems working. This topic can be closed .
Thanks for the communication
Max
Thanks for letting us know! Will close the thread for you
@antoniolg
the bug comes backs
Video of the bug ( android version 6.10.0.2853)
Hello everyone.
No news ?
