Building a new PC
It’s been about 8 years since I last built a new machine. I’m looking to build something that will be powerful enough for Plex Media Server and looking to the future, I want it to handle 4K. (I don’t have a 4K TV just yet)
I also want the ability to game a little bit. I don’t game on my PC as much as I did before I had kids (haha), but I do have a ton of Steam games I’d like to still be able to play. Most of them are not new though. I think the newest game I have is Civ 6. I only buy Asus motherboards as they have been reliable and worked without issues in the past for me.
Would appreciate some suggestions on hardware.
In the past year I built dedicated rigs for a PMP client (stock Intel i3-7100, 8GB RAM, GeForce 1050ti running Windows 10) as well as a new PMS rig that is just getting off the ground (AMD Threadripper 1920x, 16GB RAM/32GB eventually, cheap graphics card just to drive a display, also running Windows 10).
The hardware you need will depend on your streaming setup. If you’re streaming to less capable clients (generally weak CPU/GPU, or SoC) , the server needs to be more powerful; if your clients are more capable, then the server doesn’t need to be as powerful (since it can direct play/offload playback to the clients).
With my setup, my client GPU handles all the work (hardware decodes HEVC up to 12bit), so I don’t need a powerful server (I’m currently running PMS on a 2010 iMac, passmark ~5,300). As I add more and more 4k content (encoded with HEVC/x265) though, my friends and family who stream from me can’t handle that directly and thus the server needs to transcode. My 2010 iMac is woefully underequipped for 4k HEVC transcoding, which is why I invested in the 12 core Threadripper (passmark just under 18,000). If I took that external streaming out of the equation, I’d likely be able to run a cheap i5 on the server.
I don’t game much, aside from SNES emulation (hey old habits die hard), so I can’t give much help on that front. I’d think for stuff like Steam games, a capable graphics card would do the trick. I know Threadrippers are built more for hyperthreaded applications like video encoding, so an Intel CPU with a capable embedded GPU might be a better call there (I haven’t looked at AMD’s more gaming friendly CPU offerings).
For RAM, 16-32GB of the fastest RAM your mobo supports should do the trick.
…And here I’ve written the first chapter in a novel. Sorry for the long-winded response. This is what happens when I cut down on coffee during the week and overdo it on weekends!
EDIT: Plex has an article on how to pick a server CPU as well.
I’m debating on just getting a Nvidia Shield. I only stream 1 at a time and locally. I currently have Rokus in the house that serve as clients just fine. However, if I get a shield I can finally turn off my PC. It’s getting up there in age now. Current system is an i7-950
16GB RAM
nvidia Ti 750
Only running 1080 content for now but as I look to the future, 4K will be entering my library soon once I get a new TV.
For best overall performance, price, and future proof, I recommend an i7 laptop with 256Gig SSD with the highest passmark you can afford.
Attach USB HDDs for your media.
Be sure the laptop has the Intel Quick Sync if possible, allowing for hardware transcoding.
Sorry but did you actually read what @Stryker412 usage scenario is.
The system you suggest for his situation is a great example of what he really doesn’t need.
Well apart from Quicksync.
But a Shield will be far far cheaper and offer far greater future proofing than any laptop.
@HitsVille
I humbly disagree with you.
@jjrjr1 said:
@HitsVille
And that’s fine.
Requirements as stated.
One stream maximum.
Limited gaming.
And you offer the highest end laptop he can possibly afford, as his solution not to mention the future proofing you offer. Like future proofing even exists in a laptop. Still I guess he can always admire the stack of hard drives hanging out of several usb hubs hanging out of the laptop…and know that if that one probable direct play requirement suddenly becomes a need for 10+ transcodes hes gonna be golden with that blazingly high CPU benchmark.
But I don’t know. The Shield option asside maybe in your part of the world a laptop of that spec is cheaper than to build than a PC with a moderate recent i3/i5 a decent amount of RAM and an ultra quiet case.
Here in the UK sadly you’re looking around £600-800 minimum, whilst the Quiet PC is a maximum of £250-350 including SSD. Upgrade the PC specs to what you suggest he desperately needs for his single stream and you’re looking £400-500 maximum in PC form. And either PC setup will always offer a far higher degree of future proofing. Not just a slim hope of a RAM upgrade.
