Building on Ci20
Hi All,
I'm trying to build (and document) PHT on the new CI20. I've gotten so far but im stuck with the below. If anyone is able to provide any assistance or guidance it would be greatly appreciated!
[ 0%] Built target xbmc-xrandr
[ 1%] Built target lib_squish
[ 1%] Built target lib_hts
[ 7%] Built target lib_upnp
[ 7%] Built target lib_dllsymbols
[ 8%] Built target ffmpeg
[ 10%] Built target cpluff-i486-linux
[ 10%] Built target wrapper
[ 12%] Built target cximage
[ 12%] Built target cx_raw
[ 13%] Built target cx_zlib
[ 13%] Built target ImageLib-i486-linux
[ 13%] Built target TexturePacker
[ 13%] Built target waveform
[ 13%] Built target ProjectMPresets
[ 17%] Built target projectM
[ 17%] Built target opengl_spectrum
[ 19%] Built target Goom
[ 19%] Building CXX object xbmc/CMakeFiles/xbmc.dir/GUIInfoManager.cpp.o
In file included from /home/ci20/plex-home-theater-public/xbmc/linux/PlatformInclude.h:25:0,
from /home/ci20/plex-home-theater-public/xbmc/system.h:254,
from /home/ci20/plex-home-theater-public/xbmc/network/Network.h:26,
from /home/ci20/plex-home-theater-public/xbmc/GUIInfoManager.cpp:21:
/home/ci20/plex-home-theater-public/xbmc/linux/XHandlePublic.h:41:1: warning: ‘__stdcall__’ attribute directive ignored [-Wattributes]
In file included from /home/ci20/plex-home-theater-public/xbmc/linux/PlatformInclude.h:27:0,
/home/ci20/plex-home-theater-public/xbmc/linux/XTimeUtils.h:28:39: warning: ‘__stdcall__’ attribute directive ignored [-Wattributes]
In file included from /home/ci20/plex-home-theater-public/xbmc/GUIInfoManager.cpp:55:0:
/home/ci20/plex-home-theater-public/xbmc/utils/MathUtils.h: In function ‘int MathUtils::round_int(double)’:
/home/ci20/plex-home-theater-public/xbmc/utils/MathUtils.h:150:6: error: unknown register name ‘st’ in ‘asm’
make[2]: *** [xbmc/CMakeFiles/xbmc.dir/GUIInfoManager.cpp.o] Error 1
make[1]: *** [xbmc/CMakeFiles/xbmc.dir/all] Error 2
make: *** [all] Error 2
Trying to build on a Pine64 … same problem in same spot.
Looks like an issue with the base architecture and that the code being compiled (this part in particular looks like it might be assembler inside c++) is not compatible.
