Is there a specific api for managing sections via the channel dev or is the only option to use the web api?
What I want to do is create a plugin that would allow a great deal of management tasks. Such as:
- Scanning sections
- Adding/removing sections
- Scanning sub-folders of sections (Is this available yet via api?)
- Analyze media
- Empty section trash
- View section trash
- etc
Also, where is the web api documented? Can't find it for some reason.
AFAIK, there is little to no documentation for the PMS web API. I would approach your project the same way I would approach any other channel project where there's no documented API. Monitor HTTP traffic as you explore the existing web app. I like the developer tools in Chrome for that.
Thanks for the reply. I saw in one of the latest newsletters that you can scan a small subset of a section. Is there a thread/documentation on the topic?
I'm not aware of any. I suspect any discussion of it would take place in the "General" Development sub-forum. There is a sticky thread there about "undocumented tips and tricks".
