Can anyone help
I was usually able checking through my movies i was usually able to see that i had two copies of the movie since I’ve done some changes I’ve seem to have lost it I would be grateful for your help
Use the Duplicates filter.
brilliant thank you that helps
:+1::+1::+1::+1::+1::+1::+1:
