Hi
Just had a drive die and want to know if I can run a inventory list from Plex that tells me what is in what library
Many Thanks
Weezy
You can open the database in https://portableapps.com/apps/development/sqlite_database_browser_portable
Browse data from table media_parts and filter out the data you need. Maybe there is a easier way but I don’t know it.
The PlexPy 3rd-party app can do this.
https://forums.plex.tv/discussion/169591/plexpy-another-plex-monitoring-program/p1#top
Both
WebTools
or
ExportTools
may be suitable Plex Plugins.
Export Tools writes its findings into a CSV file which you can sort and filter in any conventional spreadsheet calc.
