Can not get this to work, please help
      Hi there, I can not seem to get plex connect to work. I have no luck using terminal to get it going. months ago when plex connect first came out I was able to make it work. I have since then upgraded both systems running plex to the latest OSX  Mavericks, so I dunno if thats the issues. I will paste below the the error I;m getting in terminal.  Any help would be greatly appreciated.  I've been reading and watching movies on the web her to make sure I;m doing it right and from what I see I believe I am doing everything right.  Thanks in advance to anyone that helps out here,
  • ATV model 3 and firmware version 5.3 (6105)
  • The DNS server 109.123.111.24
  • Macbook pro running OS X 10.9
  • The local IP address 192.168.0.12
  • Plex media server Version 0.9.8.10.215-020456b
  • The local IP address of the device that the Plex media server (PMS) 192.168.0.12
  • Downloaded Plex connect today from github @ 5 PM
  •  'Settings.cfg' file I don't have I have .py but I haven't been able to get it running once to create the .cfg
xxxxxxxx-MacBook-Pro-2:PlexConnect-master xxxxxx$ sudo ./PlexConnect.py
Password:
Traceback (most recent call last):
  File "./PlexConnect.py", line 17, in
    import DNSServer, WebServer
  File "/Users/xxxxxx/Downloads/PlexConnect-master/DNSServer.py", line 76, in
    import Settings
  File "/Users/xxxxxx/Downloads/PlexConnect-master/Settings.py", line 27
    'prevent_atv_update'           :('True', 'False'), \
SyntaxError: invalid syntax
    import Settings
I suggest you read the sticky post “read before posting” and post all the information it requests. Also make sure you advise what version of python you are using.
The more information you provide the easier it is to help you.
Also the ONLY install guides you should use are the ones on the wiki (linked in the sticky or my sig). As others on the web are often out of date and incomplete.
