Can Plexamp read and use m3u playlists?
Did you find a solution? I have the same problem. The Plex playlists get exported, but no new Playlists in Plex after a successful import.
I did not find the solution, sorry. I just stopped using Plex music and am waiting until it catches up with the functionality of other music players.
Sad to see the slow or not existing progress in 2019 just ahmm 20 years after the invention of playlists.
Unfortunatelly i have bought a lifetime key before I digged into this and the worse alexa implementation of the german language.
Close to useless when I stopped in august or september.
  • 1 User awaithing an import m3u feature.
    Using AIMP until it happen. Come on Plex devs, what is it so hard to include such a basic feature, I would appreciate to use Plex for all my media needs.
We’re waiting on @elan
He’s got 3 more major U.S. holidays to stir up marketing hype.
Plex Amp as a:
Christmas gift
Happy New Year gift
Valentines Day gift
Beside marketing hype, you’re forgetting ā€œmake major change right before >x< holiday that will bring people that never used the forum before to ask what the devs were thinkingā€
I don’t even really care if it’s Plexamp - I just want Plex to understand M3U in general. SO many playlists I’d import from 15+ years of music goodness.
I played music in Plex on my phone for the first time in (months/years?), and noticed a stereo graph replaced the progress bar.
I don’t need that. I hope my phone isn’t using more energy to fill it in than it would a progress bar.
My Plex is up and running, but I don’t use it at all. Because of this missing feature.
Just made a very bad experience with a different music service some days ago. I’ve lost the work of hundreds of hours…
I’ll never accept a vendor lock in once more. The ability to properly backup / import / export / re-use the effort people spend in terms of meta information is essential.
I’ve updated my script (Plex Playlist Pusher) to include a full setup, and it should work better across Windows and Unix machines, if you tried it before and couldn’t get it to work maybe try again and it should be more beginner friendly!
That looks awesome, if you dont have a song in your library that is in a m3u playlist will it add it from tidal? Cause I have a Tidal Playlist I exported to m3u and want to import it to plex and mix the items I have in my library and songs I dont yet have with tidal versions.
Can you mix your tidal library with a library of local files?
PPP can only look for Plex music from one library, so I would imagine it wouldn’t work with tidal but I don’t use it myself so not sure!
Was really hoping for Christmas :christmas_tree: …
I’ve just spent a few days with PPP (pull request posted to @XDGFX’s GitHub page). I’ve got it working well for porting my playlists from MediaMonkey (on Windows) into my Plex server that’s on Linux. Score!
Thank you @XDGFX !
It took a while to get the pathing right but I have @XDGFX 's PPP working now and this is probably better than anything plex will come up with in terms of automation of syncing playlists inside and out of plex! One can only hope that if plex ever implements playlist importing/exporting via the UI they dont remove this api and render this tool useless!
Has there been any progress on support for plex to import playlists?
I’ve tried using the post method, but all I’m getting is ā€˜200 OK’ returns but no results :confused:
I’m going to try XDGFX’s solution next.
Would you mind sharing your variables JSON contents to let me know how you got this working? I too am trying to sync windows based m3us to a linux plex server!
Thanks a lot!
When you run for the first time a setup process will guide you through and create one automatically, alternatively there’s example-variables.json in the repo :slight_smile:
Yeah I just dont find the instructions very clear. (The wording in the instructions) I wanted somebody who got my exact use case working, to share their variables.json.
I have m3us and music library on windows, trying to import to a Linux Plex server.
In my instance, this does not work.
edit: I got it working. Seems I had to run the PPP script from the Linux side rather than on Windows.
@XDGFX - What should the paths look like in the ā€˜variables.json’ if I am running PPP on Windows?
Any luck with the post method or XDGFX’s ppp? I’m in the same boat - ā€œ200 OKā€ with postman, but no new playlists. Same thing wtih XDGFX’s ppp - it looks like it should work, it downloads Plex playlist, looking at the temp files all the paths look good, but nothing uploads back to Plex.
I’ve gotten this to work partially… Just made a m3u playlist with 240 lines of full path for each song already in Plex. Put the m3u file on the Plex server, used the http POST and pointed it to the dir the m3u playlist is in on the server. It works, there’s a playlist in Plex, but the odd thing is that only about 200 of the 240 songs are in the playlist. I can’t figure out what’s causing the issue. Thought it was odd characters like % or # in the directories but I’ve found missing songs that are on the server in the folders specified but for some reason were skipped and aren’t in the Plex playlist and there’s nothing odd about the directory path. Any ideas? I made the m3u file in notepad++. The only thing I can think of right now is that there’s some kinda hidden/non-visible character issue in my m3u file?
