Cannot get my remote control (RC6) work properly with Plex-HTPC
I have plex-htpc installed on Lubuntu 22.04
I have an IR remote control from Microsoft model 1039 - RC6, which I believe is pretty common.
Using the command ir-keytable I can see my remote is recognized as rc6 and all button are detected and correctly mapped to the right function (OK, PLAY,…)
In plex-htpc, only the arrow keys and play work. All others are inactive.
Looking at the article https://support.plex.tv/articles/plex-htpc-input-maps/ , I see that I may need to change the input-map. Unfortunately in bullet point 5. I cannot see any name of a device.
In the logs, iIt looks like what I have is only keyboard and there is an error with LIRC
Mar 11, 2023 11:42:47.784 [0x7fcbb7e48c40] DEBUG - [InputManager] Initializing.
Mar 11, 2023 11:42:47.787 [0x7fcbb7e48c40] INFO - [InputManager] Loading inputmaps from: /snap/plex-htpc/31/resources/inputmaps
Mar 11, 2023 11:42:47.789 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: libass API version: 0x1600000
Mar 11, 2023 11:42:47.789 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: libass source: tarball: 0.16.0
Mar 11, 2023 11:42:47.795 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 4.2.1 (COMPLEX)
Mar 11, 2023 11:42:47.795 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: Setting up fonts...
Mar 11, 2023 11:42:47.801 [0x7fcbb7e48c40] INFO - [InputManager] Loading inputmaps from: /home/player/snap/plex-htpc/common/inputmaps
Mar 11, 2023 11:42:47.802 [0x7fcbb7e48c40] INFO - **[InputManager/Keyboard] Successfully inited input**
Mar 11, 2023 11:42:47.871 [0x7fcb5ffff700] INFO - [Input/SDL] Found 0 joysticks
Mar 11, 2023 11:42:47.871 [0x7fcbb7e48c40] INFO - [InputManager/SDL] Successfully inited input
Mar 11, 2023 11:42:47.871 [0x7fcbb7e48c40] **ERROR - [InputManager/LIRC] LIRC Socket Error : 2**
Mar 11, 2023 11:42:47.871 [0x7fcbb7e48c40] WARN - [InputManager/LIRC] Failed to init input
Mar 11, 2023 11:42:47.872 [0x7fcb5f7fe700] INFO - libCEC was successfully initialized, found version 262151
Mar 11, 2023 11:42:47.897 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: Using font provider fontconfig
Mar 11, 2023 11:42:47.897 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] osd/libass: Done.
Mar 11, 2023 11:42:47.900 [0x7fcb937fe700] DEBUG - [MPVEngine/mpv] cplayer: Done loading scripts.
Mar 11, 2023 11:42:47.941 [0x7fcbb7e48c40] INFO - [InputManager/CEC] Successfully inited input
Mar 11, 2023 11:42:48.052 [0x7fcbb7e48c40] INFO - [DisplayManager] Found 1 Display(s).
Mar 11, 2023 11:42:48.052 [0x7fcbb7e48c40] INFO - [DisplayManager] Available modes for Display HDMI-1
Mar 11, 2023 11:42:48.052 [0x7fcbb7e48c40] INFO - [DisplayManager] Mode:  1920x 1080ix 0bpp@60.000Hz
When pressing on OK for instance there is no trace of it in the logs, only the working keys (arrows and PLAY):
Mar 11, 2023 11:43:10.463 [0x7fcbb7e48c40] DEBUG - [InputManager] Input received: source: Keyboard keycode: Right:3
Mar 11, 2023 11:43:10.463 [0x7fcbb7e48c40] DEBUG - [InputManager] Emit input action: ["right"]
Mar 11, 2023 11:43:10.463 [0x7fcbb7e48c40] INFO - [InputManager] [InputConnector] Sending actions to UI: ["right"]
Mar 11, 2023 11:43:10.769 [0x7fcbb7e48c40] DEBUG - [InputManager] Input received: source: Keyboard keycode: Right:1
Mar 11, 2023 11:43:18.896 [0x7fcbb7e48c40] DEBUG - [InputManager] Input received: source: Keyboard keycode: Media Play:3
Mar 11, 2023 11:43:18.896 [0x7fcbb7e48c40] DEBUG - [InputManager] Emit input action: ["play_pause"]
Mar 11, 2023 11:43:18.896 [0x7fcbb7e48c40] INFO - [InputManager] [InputConnector] Sending actions to UI: ["play_pause"]
I use the keyboard for the back/exit function. The keyboard works correctly.
Is there a way that Plex-htpc uses the default remote from linux, or how should I proceed if my remote looks recognized only as « keyboard ».
Thank you for helping.
Player Version#: plex-htpc 1.35.1
This thread may be of help. The issue is the snap can’t open the LIRC socket.
sorry did you forget the link to the thread ?
Is it this one: Plex HTPC doesn’t work with LIRC ?
Not sure how I managed to miss pasting the link. Yeah, that’s the thread I was going to paste.
As seen in the other article, I removed liblirc and use ir-keytable, but it doesn’t change anything.
I still have the same logs:
is there anything else I could try to use my RC6 remote with the snap install of plex-htpc ?
Will I have the same issue with the flatpak package ?
So I tried with Flatpak and the behaviour is the same.
So snap and flatpak packages do not support IR remote correctly (at least RC6).
Is there an alternate install for linux (apt or else ?)
Also what are the recommended remotes for linux plex-htpc ?
