Cannot stream DLNA to Yamaha receiver
Server Version#: 4.47.3
I have a Yamaha RX-V671. It has been a few years since I last used it I used to be able to stream to it but since I started using it again it hasn’t worked. A number of changes have been made since I last used it including moving to a new server. DLNA works to other devices just not the receiver.
I am using the Yamaha AV controller App for android. It is able to see Plex but when I select a song to play nothing happens.
I have tried creating the profile in this thread https://forums.plex.tv/t/dlna-yamaha-av-unable-to-play/17301/20 but still was unable to get it to work.
for the fun of it I also followed the suggestion of using Serviio and still nothing. I also tried disabling the firewall no change.
I would really like to get this going again any suggestions would be appreciated
So I have been digging around a bit and started looking at the logs. The profiles I have created appear to be loading fine.
Jan 21, 2021 13:32:55.392 [20844] INFO - Plex DLNA Server v1.21.1.3830-6c22540d5 - Microsoft PC x64 - build: windows-x86 - GMT -08:00
Jan 21, 2021 13:32:55.392 [20844] INFO - Windows version: 6.2 (Build 9200), language en-US
Jan 21, 2021 13:32:55.392 [20844] INFO - 32 2594 MHz processor(s): Architecture=0, Level=6, Revision=15876 Processor Identifier=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
Jan 21, 2021 13:32:55.392 [20844] DEBUG - "C:\Program Files (x86)\Plex\Plex Media Server\Plex Dlna Server.exe"
Jan 21, 2021 13:32:55.392 [23280] DEBUG - Unique device name = 3f3ed1c2-707e-ae74-05d1-e67fac4a5d4a
Jan 21, 2021 13:32:55.392 [23280] DEBUG - DLNA server port: 32469
Jan 21, 2021 13:32:55.392 [23280] DEBUG - PMS: http://127.0.0.1:32400/
Jan 21, 2021 13:32:55.392 [23280] DEBUG - MyPlex: https://plex.tv/
Jan 21, 2021 13:32:57.401 [23280] DEBUG - Reading system DLNA client profiles
Jan 21, 2021 13:32:57.436 [23280] DEBUG - Reading user client profile "RX-V671"
Jan 21, 2021 13:32:57.436 [23280] DEBUG - Reading user client profile "Yamaha-AV"
Jan 21, 2021 13:32:57.436 [23280] DEBUG - Read 24 DLNA client profiles
Jan 21, 2021 13:32:57.445 [23280] DEBUG - DLNA device discovery enabled every 60 seconds
Jan 21, 2021 13:32:57.466 [23280] DEBUG - Initialization complete
Jan 21, 2021 13:32:58.149 [25908] DEBUG - Device RX-V671 at 192.168.1.111 will use RX-V671 profile
but when I try to play something it errors.
Jan 21, 2021 13:35:03.336 [12704] DEBUG - PlexMediaConnectDelegate::OnBrowseDirectChildren for '7ab73ba77d63182c3f28' with filter '*' and sort '', paged as 0 + 64
Jan 21, 2021 13:35:03.336 [12704] DEBUG - Mapped client to generic profile: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"; CONTENT-TYPE: text/xml; charset="utf-8"; User-Agent: Dalvik/2.1.0 (Linux; U; Android 9; SM-T380 Build/PPR1.180610.011); Host: 192.168.1.37:32469; Connection: Keep-Alive; Accept-Encoding: gzip; Content-Length: 433
Jan 21, 2021 13:35:03.336 [12704] DEBUG - Mapped object 7ab73ba77d63182c3f28 to /library/sections/1/folder?parent=10 part 0 on server http://127.0.0.1:32400/
Jan 21, 2021 13:35:03.337 [12704] DEBUG - Downloading document http://127.0.0.1:32400/library/sections/1/folder?parent=10
Jan 21, 2021 13:35:03.337 [12704] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/sections/1/folder?parent=10
Jan 21, 2021 13:35:03.530 [12704] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/sections/1/folder?parent=10
Jan 21, 2021 13:35:03.560 [12704] DEBUG - Caching document http://127.0.0.1:32400/library/sections/1/folder?parent=10 as 140f2a4d72f444cacf3adb2020ff33b97afc5513
Jan 21, 2021 13:35:03.589 [12704] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/956,957,958,959,960,961,962,963,964,965,966,967,968,969,970,1495,1188,1606,1180,1475,1600,1539,1257,1414,1036,1003,1032,1096,1226,1227,1429,1228,976,1509,1553,986,1075,1536,994,1034,1534,978,1004,1074,1548,1245,1098,1016,1329,971,973,1266,1360,1556,1558,1419,1502,1563,1533,1115,1411,1152,1505,1544,1510,1101,1050,995,996,1153,1267,1580,1569,1570,1571,1573,1574,1575,1576,1577,1578,1579,1325,1294,1356,1019,1280,1607,1054,972,974,1049,1361,1543,1189,1128,1097,1389,979,1225,1058,1090,1117,1155,1615,1463,1298,1035,1076,1150,1268,1322,1138,1118,1310,1119,1190,1602,1191,1392,1604,1331,1312,1269,1493,1224,1134,975,1242,1082,1611,1072,1297,1156,1113,980,1435,1342,1132,981,1239,1608,1302,988,993,1369,1165,1476,1013,1402,1311,1480,1541,1277,983,1616,1452,1021,1204,1278,1006,1513,984,1584,1241,1212,1276,1205,1169,1465,1457,1093,1313,1598,1504,985,1564,1400,1339,1565,1166,1309,1247,998,987,1594,1005,1015,1051,999,997,990,1000,991,1007,1340,1041,1418,1599,1084,1446,1550,1274,1125,1010,1008,982,1545,1085,1002,1088,1473,1009,1091,1011,1012,1590,1238,1497,1202,992,1617,1582,1014,1163,1567,1001,1528,1029,1538,1040,1175,1048,1540,1561,1597,1603,1025,1347,1618,1022,1511,1542,1026,1033,1043,1042,1046,1038,1568,1027,1537,1037,1045,1060,1028,1031,1023,1047,1566,1535,1249,1024,1174,1610,1044,1039,1061,1207,1080,1020,1408,1591,1065,1613,1083,1102,1208,1066,1092,1063,1588,1103,1073,1078,1062,1081,1095,1612,1284,1089,1057,1087,1068,1079,1086,1077,1064,1069,1070,1071,1619,1094,1104,1124,1106,1130,1121,1508,1123,1514,1172,1052,1107,1498,1108,1122,1116,1620,1126,1127,1133,1346,1171,1139,1114,1135,1129,1105,977,1110,1120,1131,1589,1112,1315,1587,1609,1559,1111,1348,1145,1621,1246,1099,1167,1055,1161,1515,1157,1146,1601,1159,1503,1555,1154,1148,1149,1164,1142,1162,1141,1170,1151,1160,1158,1351,1507,1168,1143,1144,1140,1316,1614,1213,1053,1496,1532,1177,1622,1195,1546,1516,1178,1194,1193,1181,1349,1200,1182,1201,1198,1585,1179,1494,1549,1206,1185,1203,1176,1197,1186,1184,1136,1196,1192,1199,1512,1187,1234,1236,1216,1517,1554,1583,1230,1219,1250,1231,1232,1217,1220,1237,1233,1214,1593,1557,1240,1350,1223,1221,1243,1218,1229,1623,1244,1235,1248,1215,1018,1265,1258,1252,1275,1254,1259,1287,1518,1283,1595,1260,1271,1253,1261,1262,1272,1255,1281,1264,1256,1270,1624,1282,1251,1279,1273,1625,1531,1318,1303,1304,1305,1519,1291,1292,1137,1288,1314,1289,1295,1586,1307,1301,1290,1308,1300,1173,1299,1100,1306,1286,1296,1560,1529,1332,1376,1344,1321,1337,1352,1520,1345,1323,1324,1338,1330,1333,1341,1320,1343,1335,1336,1326,1327,1626,1334,1552,1328,1364,1365,1377,1627,1368,1366,1367,1354,1357,1370,1372,1362,1363,1373,1371,1358,1353,1375,1359,1374,1530,1386,1391,1406,1592,1499,1521,1387,1378,1596,1395,1399,1397,1394,1385,1209,1396,1384,1398,1425,1401,1628,1403,1390,1317,1407,1393,1404,1405,1500,1417,1424,1522,1410,1420,1423,1380,1059,1409,1056,1421,1415,1416,1413,1422,1211,1434,1506,1428,1430,1381,1523,1427,1436,1439,1432,1433,1437,1438,1443,1501,1524,1547,1017,1444,1605,1447,1441,1445,1382,1442,1562,1453,1551,1454,1451,1450,1449,1459,1460,1383,1525,1456,1455,1458,1464,1572,1526,1462,1466,1461,1527,1469,1467,1426,1468,1471,1472,1210,1379,1474,1470,1479,1478,1477,1481,1581,1484,1483,1482,1486,1487,1485,1488,1489,1490,1491,1285,1492,989,1030,1067,1109,1147,1183,1222,1263,1293,1319,1355,1388,1412,1431,1440,1448
Jan 21, 2021 13:35:03.589 [12704] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/metadata/956,957,958,959,960,961,962,963,964,965,966,967,968,969,970,1495,1188,1606,1180,1475,1600,1539,1257,1414,1036,1003,1032,1096,1226,1227,1429,1228,976,1509,1553,986,1075,1536,994,1034,1534,978,1004,1074,1548,1245,1098,1016,1329,971,973,1266,1360,1556,1558,1419,1502,1563,1533,1115,1411,1152,1505,1544,1510,1101,1050,995,996,1153,1267,1580,1569,1570,1571,1573,1574,1575,1576,1577,1578,1579,1325,1294,1356,1019,1280,1607,1054,972,974,1049,1361,1543,1189,1128,1097,1389,979,1225,1058,1090,1117,1155,1615,1463,1298,1035,1076,1150,1268,1322,1138,1118,1310,1119,1190,1602,1191,1392,1604,1331,1312,1269,1493,1224,1134,975,1242,1082,1611,1072,1297,1156,1113,980,1435,1342,1132,981,1239,1608,1302,988,993,1369,1165,1476,1013,1402,1311,1480,1541,1277,983,1616,1452,1021,1204,1278,1006,1513,984,1584,1241,1212,1276,1205,1169,1465,1457,1093,1313,1598,1504,985,1564,1400,1339,1565,1166,1309,1247,998,987,1594,1005,1015,1051,999,997,990,1000,991,1007,1340,1041,1418,1599,1084,1446,1550,1274,1125,1010,1008,982,1545,1085,1002,1088,1473,1009,1091,1011,1012,1590,1238,1497,1202,992,1617,1582,1014,1163,1567,1001,1528,1029,1538,1040,1175,1048,1540,1561,1597,1603,1025,1347,1618,1022,1511,1542,1026,1033,1043,1042,1046,1038,1568,1027,1537,1037,1045,1060,1028,1031,1023,1047,1566,1535,1249,1024,1174,1610,1044,1039,1061,1207,1080,1020,1408,1591,1065,1613,1083,1102,1208,1066,1092,1063,1588,1103,1073,1078,1062,1081,1095,1612,1284,1089,1057,1087,1068,1079,1086,1077,1064,1069,1070,1071,1619,1094,1104,1124,1106,1130,1121,1508,1123,1514,1172,1052,1107,1498,1108,1122,1116,1620,1126,1127,1133,1346,1171,1139,1114,1135,1129,1105,977,1110,1120,1131,1589,1112,1315,1587,1609,1559,1111,1348,1145,1621,1246,1099,1167,1055,1161,1515,1157,1146,1601,1159,1503,1555,1154,1148,1149,1164,1142,1162,1141,1170,1151,1160,1158,1351,1507,1168,1143,1144,1140,1316,1614,1213,1053,1496,1532,1177,1622,1195,1546,1516,1178,1194,1193,1181,1349,1200,1182,1201,1198,1585,1179,1494,1549,1206,1185,1203,1176,1197,1186,1184,1136,1196,1192,1199,1512,1187,1234,1236,1216,1517,1554,1583,1230,1219,1250,1231,1232,1217,1220,1237,1233,1214,1593,1557,1240,1350,1223,1221,1243,1218,1229,1623,1244,1235,1248,1215,1018,1265,1258,1252,1275,1254,1259,1287,1518,1283,1595,1260,1271,1253,1261,1262,1272,1255,1281,1264,1256,1270,1624,1282,1251,1279,1273,1625,1531,1318,1303,1304,1305,1519,1291,1292,1137,1288,1314,1289,1295,1586,1307,1301,1290,1308,1300,1173,1299,1100,1306,1286,1296,1560,1529,1332,1376,1344,1321,1337,1352,1520,1345,1323,1324,1338,1330,1333,1341,1320,1343,1335,1336,1326,1327,1626,1334,1552,1328,1364,1365,1377,1627,1368,1366,1367,1354,1357,1370,1372,1362,1363,1373,1371,1358,1353,1375,1359,1374,1530,1386,1391,1406,1592,1499,1521,1387,1378,1596,1395,1399,1397,1394,1385,1209,1396,1384,1398,1425,1401,1628,1403,1390,1317,1407,1393,1404,1405,1500,1417,1424,1522,1410,1420,1423,1380,1059,1409,1056,1421,1415,1416,1413,1422,1211,1434,1506,1428,1430,1381,1523,1427,1436,1439,1432,1433,1437,1438,1443,1501,1524,1547,1017,1444,1605,1447,1441,1445,1382,1442,1562,1453,1551,1454,1451,1450,1449,1459,1460,1383,1525,1456,1455,1458,1464,1572,1526,1462,1466,1461,1527,1469,1467,1426,1468,1471,1472,1210,1379,1474,1470,1479,1478,1477,1481,1581,1484,1483,1482,1486,1487,1485,1488,1489,1490,1491,1285,1492,989,1030,1067,1109,1147,1183,1222,1263,1293,1319,1355,1388,1412,1431,1440,1448
Jan 21, 2021 13:35:04.115 [12704] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/metadata/956,957,958,959,960,961,962,963,964,965,966,967,968,969,970,1495,1188,1606,1180,1475,1600,1539,1257,1414,1036,1003,1032,1096,1226,1227,1429,1228,976,1509,1553,986,1075,1536,994,1034,1534,978,1004,1074,1548,1245,1098,1016,1329,971,973,1266,1360,1556,1558,1419,1502,1563,1533,1115,1411,1152,1505,1544,1510,1101,1050,995,996,1153,1267,1580,1569,1570,1571,1573,1574,1575,1576,1577,1578,1579,1325,1294,1356,1019,1280,1607,1054,972,974,1049,1361,1543,1189,1128,1097,1389,979,1225,1058,1090,1117,1155,1615,1463,1298,1035,1076,1150,1268,1322,1138,1118,1310,1119,1190,1602,1191,1392,1604,1331,1312,1269,1493,1224,1134,975,1242,1082,1611,1072,1297,1156,1113,980,1435,1342,1132,981,1239,1608,1302,988,993,1369,1165,1476,1013,1402,1311,1480,1541,1277,983,1616,1452,1021,1204,1278,1006,1513,984,1584,1241,1212,1276,1205,1169,1465,1457,1093,1313,1598,1504,985,1564,1400,1339,1565,1166,1309,1247,998,987,1594,1005,1015,1051,999,997,990,1000,991,1007,1340,1041,1418,1599,1084,1446,1550,1274,1125,1010,1008,982,1545,1085,1002,1088,1473,1009,1091,1011,1012,1590,1238,1497,1202,992,1617,1582,1014,1163,1567,1001,1528,1029,1538,1040,1175,1048,1540,1561,1597,1603,1025,1347,1618,1022,1511,1542,1026,1033,1043,1042,1046,1038,1568,1027,1537,1037,1045,1060,1028,1031,1023,1047,1566,1535,1249,1024,1174,1610,1044,1039,1061,1207,1080,1020,1408,1591,1065,1613,1083,1102,1208,1066,1092,1063,1588,1103,1073,1078,1062,1081,1095,1612,1284,1089,1057,1087,1068,1079,1086,1077,1064,1069,1070,1071,1619,1094,1104,1124,1106,1130,1121,1508,1123,1514,1172,1052,1107,1498,1108,1122,1116,1620,1126,1127,1133,1346,1171,1139,1114,1135,1129,1105,977,1110,1120,1131,1589,1112,1315,1587,1609,1559,1111,1348,1145,1621,1246,1099,1167,1055,1161,1515,1157,1146,1601,1159,1503,1555,1154,1148,1149,1164,1142,1162,1141,1170,1151,1160,1158,1351,1507,1168,1143,1144,1140,1316,1614,1213,1053,1496,1532,1177,1622,1195,1546,1516,1178,1194,1193,1181,1349,1200,1182,1201,1198,1585,1179,1494,1549,1206,1185,1203,1176,1197,1186,1184,1136,1196,1192,1199,1512,1187,1234,1236,1216,1517,1554,1583,1230,1219,1250,1231,1232,1217,1220,1237,1233,1214,1593,1557,1240,1350,1223,1221,1243,1218,1229,1623,1244,1235,1248,1215,1018,1265,1258,1252,1275,1254,1259,1287,1518,1283,1595,1260,1271,1253,1261,1262,1272,1255,1281,1264,1256,1270,1624,1282,1251,1279,1273,1625,1531,1318,1303,1304,1305,1519,1291,1292,1137,1288,1314,1289,1295,1586,1307,1301,1290,1308,1300,1173,1299,1100,1306,1286,1296,1560,1529,1332,1376,1344,1321,1337,1352,1520,1345,1323,1324,1338,1330,1333,1341,1320,1343,1335,1336,1326,1327,1626,1334,1552,1328,1364,1365,1377,1627,1368,1366,1367,1354,1357,1370,1372,1362,1363,1373,1371,1358,1353,1375,1359,1374,1530,1386,1391,1406,1592,1499,1521,1387,1378,1596,1395,1399,1397,1394,1385,1209,1396,1384,1398,1425,1401,1628,1403,1390,1317,1407,1393,1404,1405,1500,1417,1424,1522,1410,1420,1423,1380,1059,1409,1056,1421,1415,1416,1413,1422,1211,1434,1506,1428,1430,1381,1523,1427,1436,1439,1432,1433,1437,1438,1443,1501,1524,1547,1017,1444,1605,1447,1441,1445,1382,1442,1562,1453,1551,1454,1451,1450,1449,1459,1460,1383,1525,1456,1455,1458,1464,1572,1526,1462,1466,1461,1527,1469,1467,1426,1468,1471,1472,1210,1379,1474,1470,1479,1478,1477,1481,1581,1484,1483,1482,1486,1487,1485,1488,1489,1490,1491,1285,1492,989,1030,1067,1109,1147,1183,1222,1263,1293,1319,1355,1388,1412,1431,1440,1448
Jan 21, 2021 13:35:04.150 [12704] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/956,957,958,959,960,961,962,963,964,965,966,967,968,969,970,1495,1188,1606,1180,1475,1600,1539,1257,1414,1036,1003,1032,1096,1226,1227,1429,1228,976,1509,1553,986,1075,1536,994,1034,1534,978,1004,1074,1548,1245,1098,1016,1329,971,973,1266,1360,1556,1558,1419,1502,1563,1533,1115,1411,1152,1505,1544,1510,1101,1050,995,996,1153,1267,1580,1569,1570,1571,1573,1574,1575,1576,1577,1578,1579,1325,1294,1356,1019,1280,1607,1054,972,974,1049,1361,1543,1189,1128,1097,1389,979,1225,1058,1090,1117,1155,1615,1463,1298,1035,1076,1150,1268,1322,1138,1118,1310,1119,1190,1602,1191,1392,1604,1331,1312,1269,1493,1224,1134,975,1242,1082,1611,1072,1297,1156,1113,980,1435,1342,1132,981,1239,1608,1302,988,993,1369,1165,1476,1013,1402,1311,1480,1541,1277,983,1616,1452,1021,1204,1278,1006,1513,984,1584,1241,1212,1276,1205,1169,1465,1457,1093,1313,1598,1504,985,1564,1400,1339,1565,1166,1309,1247,998,987,1594,1005,1015,1051,999,997,990,1000,991,1007,1340,1041,1418,1599,1084,1446,1550,1274,1125,1010,1008,982,1545,1085,1002,1088,1473,1009,1091,1011,1012,1590,1238,1497,1202,992,1617,1582,1014,1163,1567,1001,1528,1029,1538,1040,1175,1048,1540,1561,1597,1603,1025,1347,1618,1022,1511,1542,1026,1033,1043,1042,1046,1038,1568,1027,1537,1037,1045,1060,1028,1031,1023,1047,1566,1535,1249,1024,1174,1610,1044,1039,1061,1207,1080,1020,1408,1591,1065,1613,1083,1102,1208,1066,1092,1063,1588,1103,1073,1078,1062,1081,1095,1612,1284,1089,1057,1087,1068,1079,1086,1077,1064,1069,1070,1071,1619,1094,1104,1124,1106,1130,1121,1508,1123,1514,1172,1052,1107,1498,1108,1122,1116,1620,1126,1127,1133,1346,1171,1139,1114,1135,1129,1105,977,1110,1120,1131,1589,1112,1315,1587,1609,1559,1111,1348,1145,1621,1246,1099,1167,1055,1161,1515,1157,1146,1601,1159,1503,1555,1154,1148,1149,1164,1142,1162,1141,1170,1151,1160,1158,1351,1507,1168,1143,1144,1140,1316,1614,1213,1053,1496,1532,1177,1622,1195,1546,1516,1178,1194,1193,1181,1349,1200,1182,1201,1198,1585,1179,1494,1549,1206,1185,1203,1176,1197,1186,1184,1136,1196,1192,1199,1512,1187,1234,1236,1216,1517,1554,1583,1230,1219,1250,1231,1232,1217,1220,1237,1233,1214,1593,1557,1240,1350,1223,1221,1243,1218,1229,1623,1244,1235,1248,1215,1018,1265,1258,1252,1275,1254,1259,1287,1518,1283,1595,1260,1271,1253,1261,1262,1272,1255,1281,1264,1256,1270,1624,1282,1251,1279,1273,1625,1531,1318,1303,1304,1305,1519,1291,1292,1137,1288,1314,1289,1295,1586,1307,1301,1290,1308,1300,1173,1299,1100,1306,1286,1296,1560,1529,1332,1376,1344,1321,1337,1352,1520,1345,1323,1324,1338,1330,1333,1341,1320,1343,1335,1336,1326,1327,1626,1334,1552,1328,1364,1365,1377,1627,1368,1366,1367,1354,1357,1370,1372,1362,1363,1373,1371,1358,1353,1375,1359,1374,1530,1386,1391,1406,1592,1499,1521,1387,1378,1596,1395,1399,1397,1394,1385,1209,1396,1384,1398,1425,1401,1628,1403,1390,1317,1407,1393,1404,1405,1500,1417,1424,1522,1410,1420,1423,1380,1059,1409,1056,1421,1415,1416,1413,1422,1211,1434,1506,1428,1430,1381,1523,1427,1436,1439,1432,1433,1437,1438,1443,1501,1524,1547,1017,1444,1605,1447,1441,1445,1382,1442,1562,1453,1551,1454,1451,1450,1449,1459,1460,1383,1525,1456,1455,1458,1464,1572,1526,1462,1466,1461,1527,1469,1467,1426,1468,1471,1472,1210,1379,1474,1470,1479,1478,1477,1481,1581,1484,1483,1482,1486,1487,1485,1488,1489,1490,1491,1285,1492,989,1030,1067,1109,1147,1183,1222,1263,1293,1319,1355,1388,1412,1431,1440,1448 as 26239f244d95af3986fe7549dc82c442b97ab49d
Jan 21, 2021 13:35:04.181 [12704] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, but could not determine best protocol. Defaulting to HTTP
Jan 21, 2021 13:35:04.181 [12704] DEBUG - MDE: analyzing media item 946
Jan 21, 2021 13:35:04.181 [12704] DEBUG - MDE: (01) song 1: Direct Playing due to no transcode profile
Jan 21, 2021 13:35:04.181 [12704] DEBUG - MDE: (01) song 1: no direct play music profile exists for http/mp3/mp3
Jan 21, 2021 13:35:04.181 [12704] DEBUG - (01) song 1 - audio.bitrate limitation applies: 320 > 288
Jan 21, 2021 13:35:04.181 [12704] DEBUG - MDE: (01) song 1: selected media 0 / 946
Jan 21, 2021 13:35:04.183 [12704] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, but could not determine best protocol. Defaulting to HTTP
Jan 21, 2021 13:35:04.183 [12704] DEBUG - MDE: analyzing media item 947
Jan 21, 2021 13:35:04.183 [12704] DEBUG - MDE: (02) song 2: Direct Playing due to no transcode profile
Jan 21, 2021 13:35:04.183 [12704] DEBUG - MDE: (02) song 2: no direct play music profile exists for http/mp3/mp3
Jan 21, 2021 13:35:04.183 [12704] DEBUG - (02) song 2 - audio.bitrate limitation applies: 320 > 288
Jan 21, 2021 13:35:04.183 [12704] DEBUG - MDE: (02) song 2: selected media 0 / 947
Details for the profiles I am using below
RX-V671.xml
<?xml version="1.0" encoding="utf-8"?>
    <Client name="RX-V671">
      <Identification>
 	<Header name="User-Agent" substring="(RX-V671)"/>
		<DeviceDescription type="urn:schemas-upnp-org:device:MediaRenderer:1">
                <ModelName substring="RX-V671" />
        	<Manufacturer substring="Yamaha Corporation" />
        	<ManufacturerUrl substring="http://www.yamaha.com/"/>
            </DeviceDescription>
      </Identification>
      <TranscodeTargets>
        <MusicProfile codec="mp3" container="mp3,wav" />
      </TranscodeTargets>
      <DirectPlayProfiles>
        <MusicProfile codec="mp3" container="mp3"/>
      </DirectPlayProfiles>
      <CodecProfiles>
        <VideoAudioCodec name="mp3">
            <Limitations>
                <UpperBound name="audio.bitrate" value ="192" />
              <UpperBound name="audio.samplingRate" value="48000"/>
            </Limitations>
        </VideoAudioCodec>
      </CodecProfiles>
    </Client>
Yamaha-AV.xml
    <Client name="Yamaha-AV">
      <Identification>
        <Header name="User-Agent" substring="KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0"/>
        <Header name="USER-AGENT" substring="KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0"/>
        <Header name="User-Agent" substring="WinampMPEG/2.8"/>
        <Header name="USER-AGENT" substring="WinampMPEG/2.8"/>
      </Identification>
      <TranscodeTargets>
      </TranscodeTargets>
      <CodecProfiles>
            <Limitations>
            </Limitations>
        </VideoAudioCodec>
      </CodecProfiles>
    </Client>
bumping. Really hoping someone can help!
