Can't build plex server on raspberry pi 4 with docker compose
Can’t build plex server on raspberry pi 4 with docker compose
Docker Version#: Docker version 20.10.1, build 831ebea
Docker compose Version#: docker-compose version 1.27.4, build unknown
OS version#: Linux raspberrypi 5.4.79-v7l+
using dockerfile for Dockerfile.armv7
Hi when I run the command:
docker build -t plexinc/pms-docker:latest -f Dockerfile .
Errors appear:
	/installBinary.sh: 5: /plex-common.sh: function: not found
	/installBinary.sh: 6: local: not in a function
how can this be fixed?
You might just try directly pulling and using a prebuilt image from linuxserver.io instead.
linuxserver/plex:bionic
i was able to run “lsioarmhf/plex: latest”
but I wonder why it does not start “plexinc/pms-docker”
plexinc/pms-docker is an amd64 image. It will not run on your hardware.
at https://github.com/plexinc/pms-docker there is a dockerfile for ARM
