Server Version#: Version 1.21.1.3830
Player Version#: latest
since this update i cant play any video directly without converting it
what is happening?
what is happening?
Going to need more details.
i am on LAN my PC with plex server and my clients such as ipad, apple tv all loading as converting video not direct play.
which usually it would be able to do direct play stream, what’s happened? do it has something to do with windows firewall?
thanks
I am also having this issue, Linuxserver Plex Docker updated on Dec 18th.
I can use direct play on Apple TV and Plex for Windows, but web based or IOS is broken.
Trying to switch Plex for Windows to transcoding caused it to fail.
Log for trying to watch with IOS is below. This one fails direct play and then fails transcode.
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] MDE: E7 - Promortyus: Direct Play is disabled
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] MDE: E7 - Promortyus: media must be transcoded in order to use the hls protocol
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] MDE: E7 - Promortyus: no direct play video profile exists for http/mkv/h264
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] MDE: E7 - Promortyus: no direct play video profile exists for http/mkv/h264/aac
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] MDE: Rick and Morty - S4 E7 - Promortyus: selected media 0 / 254324
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] Streaming Resource: Calculated bandwidth of 7784kbps exceeds bandwidth limit. Changing decision parameters provided by client $
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Dec 21, 2020 19:29:12.808 [0x7fd496ffd700] DEBUG - [Transcode] Scaled up video bitrate to 7591Kbps based on 1.500000x fudge factor.
Dec 21, 2020 19:29:12.809 [0x7fd496ffd700] DEBUG - [Transcode] Scaled up video bitrate to 7591Kbps based on 1.500000x fudge factor.
Dec 21, 2020 19:29:12.809 [0x7fd496ffd700] DEBUG - [Transcode] Streaming Resource: Reducing playback quality for 685kbps stream bitrate: video resolution to 480x270, audio channels to 2, qu$
Dec 21, 2020 19:29:12.809 [0x7fd496ffd700] DEBUG - [Transcode] Scaled maximum bitrate for resolution reduction to 474Kbps.
Dec 21, 2020 19:29:12.810 [0x7fd496ffd700] DEBUG - [Transcode] Scaled maximum bitrate for resolution reduction to 474Kbps.
Dec 21, 2020 19:29:12.810 [0x7fd496ffd700] DEBUG - [Transcode] MDE: Selected protocol hls; container: mpegts
Dec 21, 2020 19:29:12.810 [0x7fd496ffd700] DEBUG - [Transcode] MDE: analyzing media item 254324
Dec 21, 2020 19:29:12.810 [0x7fd496ffd700] DEBUG - [Transcode] MDE: E7 - Promortyus: Direct Play is disabled
This is log from different IOS device. This one fails transcode then fails direct play, opposite to the first one.
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: E5 - Another Toothpick: Direct Playing due to no transcode profile
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: E5 - Another Toothpick: DirectPlay
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: The Sopranos - S3 E5 - Another Toothpick: selected media 0 / 171945
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] Streaming Resource: Calculated bandwidth of 7782kbps exceeds bandwidth limit. Changing decision parameters provided by client $
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Dec 21, 2020 19:43:25.591 [0x7fd4a9ffb700] DEBUG - [Transcode] Scaled up video bitrate to 2362Kbps based on 1.500000x fudge factor.
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] Streaming Resource: Reducing playback quality for 2857kbps stream bitrate: video resolution to 720x406, audio channels to 2, d$
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] Scaled up video bitrate to 2362Kbps based on 1.500000x fudge factor.
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] Scaled maximum bitrate for resolution reduction to 332Kbps.
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: Selected protocol hls; container: mkv
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: analyzing media item 171945
Dec 21, 2020 19:43:25.592 [0x7fd4a9ffb700] DEBUG - [Transcode] MDE: E5 - Another Toothpick: Direct Play is disabled
I tried deleting /Library/…/…/Plex Media Server/ Codecs and restarting the container. It re-downloaded but no change.
Still going to need more info. Being able to direct play something depends on the video itself, some server settings, and client settings. Can you be more specific and provide an exact example of what you are playing along with file and client details.
So far everything fails to play on Iphone 11 pro.
Plex for windows works on direct play only.
This is the file I have been trying with the most.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="7" librarySectionTitle="TV Shows" librarySectionUUID="d8ffaa9d-4b95-40fe-b43d-efdb7ec04376" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1608235013">
<Video ratingKey="105460" key="/library/metadata/105460" parentRatingKey="99662" grandparentRatingKey="99661" guid="com.plexapp.agents.thetvdb://275274/4/7?lang=en" parentGuid="com.plexapp.agents.thetvdb://275274/4?lang=en" grandparentGuid="com.plexapp.agents.thetvdb://275274?lang=en" type="episode" title="Promortyus" grandparentKey="/library/metadata/99661" parentKey="/library/metadata/99662" librarySectionTitle="TV Shows" librarySectionID="7" librarySectionKey="/library/sections/7" grandparentTitle="Rick and Morty" parentTitle="Season 4" contentRating="TV-MA" summary="Rick and Morty find themselves in a fight against face-hugging aliens who just happen to have an M&Ms store." index="7" parentIndex="4" year="2020" thumb="/library/metadata/105460/thumb/1599851909" art="/library/metadata/99661/art/1599851909" parentThumb="/library/metadata/99662/thumb/1599851909" grandparentThumb="/library/metadata/99661/thumb/1599851909" grandparentArt="/library/metadata/99661/art/1599851909" grandparentTheme="/library/metadata/99661/theme/1599851909" duration="1274590" originallyAvailableAt="2020-05-10" addedAt="1589178993" updatedAt="1599851909">
<Media id="254324" duration="1274590" bitrate="5061" width="1920" height="1080" aspectRatio="1.78" audioChannels="2" audioCodec="aac" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="lc" videoProfile="high">
<Part accessible="1" exists="1" id="310941" key="/library/parts/310941/1589178937/file.mkv" duration="1274590" file="/Media/TV Shows/Rick and Morty/Season 4/Rick and Morty - S04E07 WEBDL-1080p.mkv" size="806342148" audioProfile="lc" container="mkv" deepAnalysisVersion="4" indexes="sd" requiredBandwidths="10307,9017,7364,7364,7364,7364,7364,7364" videoProfile="high">
<Stream id="720670" streamType="1" default="1" codec="h264" index="0" bitrate="5061" codedHeight="1088" codedWidth="1920" frameRate="23.976" hasScalingMatrix="0" height="1080" level="41" profile="high" refFrames="1" requiredBandwidths="10181,8892,7287,7287,7287,7287,7287,7287" scanType="progressive" width="1920" displayTitle="1080p (H.264)" extendedDisplayTitle="1080p (H.264)"> </Stream>
<Stream id="720671" streamType="2" selected="1" default="1" codec="aac" index="1" channels="2" language="English" languageCode="eng" profile="lc" requiredBandwidths="126,126,126,126,126,126,126,126" samplingRate="44100" title="English" displayTitle="English (AAC Stereo)" extendedDisplayTitle="English (AAC Stereo)"> </Stream>
<Stream id="720672" streamType="3" codec="srt" index="2" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" title="English (SDH)" displayTitle="English (SRT)" extendedDisplayTitle="English (SDH) (SRT)"> </Stream>
</Part>
</Media>
<Writer id="73496" filter="writer=73496" tag="Jeff Loveness"/>
<Marker type="intro" startTimeOffset="60166" endTimeOffset="91454"/>
<Extras size="0"> </Extras>
<Related> </Related>
</Video>
</MediaContainer>
I checked settings on my phone and server to make sure nothing changed from the update, it all looks the same. the only variables that have changed on my server is the PMS update and a new drive in my snapraid pool.
I also checked my play history and tried replaying some episodes I had previously watched on my phone without issue, they no longer play on IOS but will play on Plex for Windows and Apple TV 4.
well i tried the video that before this new update the same one and it is able to do direct play.
since this new update everything has to be converted for any type of video file.
i will try to reinstall the plex server.
I see something with that file.
codedHeight=“1088”
Did you maybe turn on hardware encoding on your server? It may be thinking this is not 1080p and trying to transcode it down to 1080p.
I would need the log from the iOS app after you try playing that file. iOS Logs | Plex Support
I messaged you the IOS log. And no hardware encoding is not on.
I got your logs. You have the option enabled for Automatic Bitrate Adjustment. This isn’t supported with the new video player which has a lot more capabilities. Turn off this option and it should be back to direct playing these files.
Yes that solved the problem.
Thanks for your help.
Glad you found the problem!
I wanted to share - that shouldn’t be an issue, and is normal for H.264 1080p video.
The H.264 standard internally uses color arrays with dimensions divisible by 16, and if the video is smaller, cropping is performed internally by the codec.
So all H.264 1080p video is stored as 1088 (divisible by 16) internally, and any encoder/decoder capable of 1080p accommodates this.
It solved the problem with my Iphone but my sisters Iphone is still having the issue and the auto setting was already off. I cant go and look at the setting on her phone myself right now, so I just told her to delete the app and reinstall but that did nothing.
It appears the transcoder is broken, on any device it will stop playing if I manual switch from direct play. Except for the iphone below it wont direct play or transcode.
Media info:
<Video ratingKey="62504" key="/library/metadata/62504" parentRatingKey="62495" grandparentRatingKey="62444" guid="com.plexapp.agents.thetvdb://75299/3/5?lang=en" parentGuid="com.plexapp.agents.thetvdb://75299/3?lang=en" grandparentGuid="com.plexapp.agents.thetvdb://75299?lang=en" type="episode" title="Another Toothpick" grandparentKey="/library/metadata/62444" parentKey="/library/metadata/62495" librarySectionTitle="TV Shows" librarySectionID="7" librarySectionKey="/library/sections/7" grandparentTitle="The Sopranos" parentTitle="Season 3" contentRating="18+" summary="Bobby's cancer-ridden father comes out of retirement to do a hit. Meanwhile, Junior is given some unpleasant news about his medical condition. Tony's racism again boils to the surface when he has a run-in with a black cop. Artie explores his feelings for Adriana, while Carmela participates more actively in Tony's therapy." index="5" parentIndex="3" rating="7.5" year="2001" thumb="/library/metadata/62504/thumb/1599852086" art="/library/metadata/62444/art/1599852088" parentThumb="/library/metadata/62495/thumb/1599852087" grandparentThumb="/library/metadata/62444/thumb/1599852088" grandparentArt="/library/metadata/62444/art/1599852088" grandparentTheme="/library/metadata/62444/theme/1599852088" duration="3598336" originallyAvailableAt="2001-03-25" addedAt="1556419306" updatedAt="1599852086" chapterSource="media">
<Media id="171945" duration="3598336" bitrate="2391" width="1920" height="1080" aspectRatio="1.78" audioChannels="6" audioCodec="ac3" videoCodec="h264" videoResolution="1080" container="mp4" videoFrameRate="24p" optimizedForStreaming="0" has64bitOffsets="0" videoProfile="high">
<Part accessible="1" exists="1" id="280424" key="/library/parts/280424/1588817223/file.m4v" duration="3598336" file="/Media/TV Shows/The Sopranos/Season 3/The Sopranos 3x5.m4v" size="1075328169" container="mp4" deepAnalysisVersion="4" has64bitOffsets="0" hasChapterVideoStream="1" hasThumbnail="1" optimizedForStreaming="0" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647" videoProfile="high">
<Stream id="660155" streamType="1" default="1" codec="h264" index="0" bitrate="1575" language="English" languageCode="eng" frameRate="23.976" hasScalingMatrix="0" height="1080" level="31" refFrames="1" requiredBandwidths="11955,6600,6600,6600,6600,6600,6600,6600" streamIdentifier="1" width="1920" displayTitle="1080p (H.264)" extendedDisplayTitle="1080p (H.264)"> </Stream>
<Stream id="660156" streamType="2" selected="1" default="1" codec="aac" index="3" channels="2" bitrate="175" language="English" languageCode="eng" profile="lc" requiredBandwidths="170,170,170,170,170,170,170,170" samplingRate="48000" streamIdentifier="4" displayTitle="English (AAC Stereo)" extendedDisplayTitle="English (AAC Stereo)"> </Stream>
<Stream id="660157" streamType="2" codec="ac3" index="4" channels="6" bitrate="640" language="English" languageCode="eng" audioChannelLayout="5.1(side)" requiredBandwidths="640,640,640,640,640,640,640,640" samplingRate="48000" streamIdentifier="5" displayTitle="English (AC3 5.1)" extendedDisplayTitle="English (AC3 5.1)"> </Stream>
<Stream id="660158" streamType="3" default="1" codec="mov_text" index="5" bitrate="0" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" streamIdentifier="6" displayTitle="English (MOV_TEXT)" extendedDisplayTitle="English (MOV_TEXT)"> </Stream>
</Part>
</Media>
<Writer id="1076" filter="writer=1076" tag="Terence Winter"/>
<Chapter id="324" filter="thumb=324" index="1" startTimeOffset="0" endTimeOffset="99725" thumb="/library/media/171945/chapterImages/1"/>
<Chapter id="324" filter="thumb=324" index="2" startTimeOffset="99725" endTimeOffset="569235" thumb="/library/media/171945/chapterImages/2"/>
<Chapter id="324" filter="thumb=324" index="3" startTimeOffset="569235" endTimeOffset="978728" thumb="/library/media/171945/chapterImages/3"/>
<Chapter id="324" filter="thumb=324" index="4" startTimeOffset="978728" endTimeOffset="1536785" thumb="/library/media/171945/chapterImages/4"/>
<Chapter id="324" filter="thumb=324" index="5" startTimeOffset="1536785" endTimeOffset="2071403" thumb="/library/media/171945/chapterImages/5"/>
<Chapter id="324" filter="thumb=324" index="6" startTimeOffset="2071403" endTimeOffset="2590379" thumb="/library/media/171945/chapterImages/6"/>
<Chapter id="324" filter="thumb=324" index="7" startTimeOffset="2590379" endTimeOffset="3496827" thumb="/library/media/171945/chapterImages/7"/>
<Chapter id="324" filter="thumb=324" index="8" startTimeOffset="3496827" endTimeOffset="3598304" thumb="/library/media/171945/chapterImages/8"/>
<Marker type="intro" startTimeOffset="1733" endTimeOffset="97397"/>
</Video>
</MediaContainer>
I think this is the right part of the IOS log:
2020/12/21 21:37:34.520 (154 MB) (70190) 🔧 PMKNetworkTask.m:221 | Completed [401]: 40: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /transcode/sessions
2020/12/21 21:37:34.521 (154 MB) (70021) 🔧 PMKNetworkTask.m:197 | Started: 42: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=960
2020/12/21 21:37:34.523 (154 MB) (70190) 🔧 PMKNetworkTask.m:197 | Started: 43: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=960
2020/12/21 21:37:34.563 (154 MB) (70021) 🔧 PMKNetworkTask.m:221 | Completed [200]: 41: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /:/timeline?bufferedTime=0&duration=3598336&key=/library/metadata/62504&location=wan&playQueueItemID=222787&playbackTime=0&ratingKey=62504&state=buffering&time=0
2020/12/21 21:37:34.564 (154 MB) (67382) ➖ PMKPlaybackEngine.m:650 | Received timeline response: <PMKServerTimelineResponse: 0x28029c3a0>
2020/12/21 21:37:34.628 (156 MB) (70021) 🔧 PMKNetworkTask.m:221 | Completed [200]: 42: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=960
2020/12/21 21:37:34.685 (158 MB) (70190) 🔧 PMKMPVClient.m:494 | [ffmpeg] v: Mime-type: 'application/vnd.apple.mpegurl'
2020/12/21 21:37:34.685 (161 MB) (70190) 🔧 PMKMPVClient.m:494 | [demux] v: Trying demuxers for level=request.
2020/12/21 21:37:34.691 (157 MB) (70190) 🔧 PMKMPVClient.m:494 | [lavf] v: Found 'hls' at score=100 size=217.
2020/12/21 21:37:34.740 (158 MB) (67382) ➖ PMKMPVVideoPlayerView.m:84 | Player moved to window <PMWindow: 0x106c60ed0; baseClass = UIWindow; frame = (0 0; 414 896); autoresize = W+H; gestureRecognizers = <NSArray: 0x2809cc840>; layer = <UIWindowLayer: 0x2801a3fc0>> (screen: <UIScreen: 0x106b0bee0; bounds = {{0, 0}, {414, 896}}; mode = <UIScreenMode: 0x2801cc1a0; size = 828.000000 x 1792.000000>>)
2020/12/21 21:37:34.764 (159 MB) (70189) 🔧 PMKNetworkTask.m:221 | Completed [200]: 43: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=960
2020/12/21 21:37:34.766 (159 MB) (70030) 🔧 PMKNetworkTask.m:197 | Started: 44: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=720
2020/12/21 21:37:34.766 (159 MB) (69965) 🔧 PMKNetworkTask.m:197 | Started: 45: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?background=000000&blur=80&format=png&height=2&minSize=1&opacity=70&quality=0&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=240
2020/12/21 21:37:35.027 (160 MB) (70187) 🔧 PMKNetworkTask.m:221 | Completed [200]: 45: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?background=000000&blur=80&format=png&height=2&minSize=1&opacity=70&quality=0&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=240
2020/12/21 21:37:35.038 (163 MB) (70188) 🔧 PMKNetworkTask.m:221 | Completed [200]: 44: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /photo/:/transcode?height=2&minSize=1&url=http://127.0.0.1:32400/library/metadata/62444/thumb/1599852088&width=720
2020/12/21 21:37:35.367 (168 MB) (70190) 🔧 PMKMPVClient.m:494 | [ffmpeg/demuxer] v: hls: Opening 'https://174-93-30-158.d33df9553fc94355a7631aabac0a4fc4.plex.direct:11081/video/:/transcode/universal/session/C5572165-0D68-40ED-B344-029938C9DF0F/base/index.m3u8?X-Plex-Incomplete-Segments=1' for reading
2020/12/21 21:37:35.625 (168 MB) (70190) 🔧 PMKMPVClient.m:494 | [ffmpeg/demuxer] v: hls: Opening 'https://174-93-30-158.d33df9553fc94355a7631aabac0a4fc4.plex.direct:11081/video/:/transcode/universal/session/C5572165-0D68-40ED-B344-029938C9DF0F/base/header' for reading
2020/12/21 21:37:35.840 (168 MB) (69969) ⚠️ PMKMPVClient.m:482 | [ffmpeg] warn: https: HTTP error 404 Not Found
2020/12/21 21:37:35.841 (168 MB) (70127) ⚠️ PMKMPVClient.m:482 | [ffmpeg/demuxer] warn: hls: Failed to open an initialization section in playlist 0
2020/12/21 21:37:35.841 (168 MB) (70127) ❌ PMKMPVClient.m:478 | [ffmpeg/demuxer] error: hls: Error when loading first segment 'https://174-93-30-158.d33df9553fc94355a7631aabac0a4fc4.plex.direct:11081/video/:/transcode/universal/session/C5572165-0D68-40ED-B344-029938C9DF0F/base/00000.ts'
2020/12/21 21:37:35.845 (168 MB) (70127) ❌ PMKMPVClient.m:478 | [lavf] error: avformat_open_input() failed
2020/12/21 21:37:35.846 (168 MB) (70127) ⚠️ PMKMPVClient.m:482 | [lavf] warn: Leaking 1 nested connections (FFmpeg bug).
2020/12/21 21:37:35.846 (168 MB) (70127) 🔧 PMKMPVVideoPlayer.m:896 | event: tracks-changed
2020/12/21 21:37:35.846 (168 MB) (70127) 🔧 PMKMPVVideoPlayer.m:896 | event: idle
2020/12/21 21:37:35.846 (168 MB) (70127) 🔧 PMKMPVClient.m:494 | [cplayer] v: Opening failed or was aborted: https://174-93-30-158.d33df9553fc94355a7631aabac0a4fc4.plex.direct:11081/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&includeCodecs=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=40000&partIndex=0&path=%2Flibrary%2Fmetadata%2F62504&protocol=hls&session=C5572165-0D68-40ED-B344-029938C9DF0F&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=4096x2160&X-Plex-Client-Identifier=13B067E2-9965-4C42-947A-1DF4FE0AD004&X-Plex-Client-Platform=iOS&X-Plex-Device=iPhone&X-Plex-Device-Screen-Density=2&X-Plex-Device-Screen-Resolution=828x1792&X-Plex-Device-Vendor=Apple&X-Plex-Drm=fairplay%3Avideo&X-Plex-Http-Pipeline=infinite&X-Plex-Incomplete-Segments=1&X-Plex-Model=11%2C8&X-Plex-Platform=iOS&X-Plex-Platform-Version=14.2&X-Plex-Product=Plex%20for%20iOS&X-Plex-Provides=client%2Ccontroller%2Csync-target%2Cplayer%2Cpubsub-player%2Cprovider-playback&X-Plex-Supported-Commands=abort%2CchangeQuality&X-Plex-Sync-Version=2&X-Plex-Token=jzgtWxxxxxxxxxxxxxxx&X-Plex-Username=s_burgess5%40hotmail.com&X-Plex-Version=7.11&X-Plex-Device-Name=Susan%E2%80%99s%20iPhone
2020/12/21 21:37:35.846 (168 MB) (70127) 🔧 PMKMPVClient.m:494 | [cplayer] v: finished playback, unrecognized file format (reason 4)
2020/12/21 21:37:35.846 (168 MB) (70127) ❌ PMKMPVClient.m:478 | [cplayer] error: Failed to recognize file format.
2020/12/21 21:37:35.850 (168 MB) (70127) ➖ PMKMPVClient.m:486 | [cplayer] info:
2020/12/21 21:37:35.863 (168 MB) (70127) 🔧 PMKNetworkTask.m:197 | Started: 46: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /:/timeline?bufferedTime=0&duration=3598336&key=/library/metadata/62504&location=wan&playQueueItemID=222787&playbackTime=0&ratingKey=62504&state=buffering&time=0
2020/12/21 21:37:35.894 (168 MB) (70188) 🔧 PMKNetworkTask.m:221 | Completed [200]: 46: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /:/timeline?bufferedTime=0&duration=3598336&key=/library/metadata/62504&location=wan&playQueueItemID=222787&playbackTime=0&ratingKey=62504&state=buffering&time=0
2020/12/21 21:37:35.895 (168 MB) (67382) ➖ PMKPlaybackEngine.m:650 | Received timeline response: <PMKServerTimelineResponse: 0x28027a780>
2020/12/21 21:37:35.895 (168 MB) (67382) 🔧 PMKVideoPlaybackEngine.m:345 | Preparing to play video { <PMKPlayQueueMetadata:0x10b321470 key:/library/metadata/62504 title:Another Toothpick type:4 isDirectory:0> }, playQueueItemID:222787
2020/12/21 21:37:35.895 (168 MB) (67382) 🔧 PMKPlaybackSessionItem.m:330 | Destroyed transcode ping timer for <PMKPart:0x2831b0000 iden=280424 key=/library/parts/280424/1588817223/file.m4v>
2020/12/21 21:37:35.895 (168 MB) (67382) 🔧 PMKPlaybackSessionItem.m:255 | Stopping transcode for <PMKPart:0x2831b0000 iden=280424 key=/library/parts/280424/1588817223/file.m4v>
2020/12/21 21:37:35.896 (168 MB) (67382) ➖ PMKMPVVideoPlayerView.m:84 | Player moved to window (null) (screen: (null))
2020/12/21 21:37:35.898 (168 MB) (67382) ➖ PMKScreenLockManager.m:103 | Restoring screen dimming
2020/12/21 21:37:35.898 (168 MB) (67382) ➖ PMKAudioSessionCategoryManager.m:64 | Setting audio session to ambient
2020/12/21 21:37:35.901 (168 MB) (70136) 🔧 PMKMPVClient.m:494 | [cplayer] v: Set property: pause=true -> 1
2020/12/21 21:37:35.907 (167 MB) (70237) ➖ PMKMPVVideoPlayerRenderer.m:71 | Deallocating mpv video player renderer...
2020/12/21 21:37:35.914 (167 MB) (67382) 🔧 PMMediaPlayerBufferUnderflowManager.m:216 | New state - stopped
2020/12/21 21:37:35.917 (167 MB) (67382) ❌ PMKPlaybackEngine.m:504 | <PMKVideoPlaybackEngine: 0x106b2ef10> did receive error playing metadata { <PMKPlayQueueMetadata:0x10b321470 key:/library/metadata/62504 title:Another Toothpick type:4 isDirectory:0> }, playQueueItemID:222787: Error Domain=PMKPlaybackErrorDomain Code=4006 "Playback session was terminated by the server" UserInfo={NSLocalizedDescription=Playback session was terminated by the server, NSUnderlyingError=0x280970d20 {Error Domain=PMKTerminationErrorDomain Code=4006 "Conversion failed. The transcoder exited due to an error." UserInfo={NSLocalizedDescription=Conversion failed. The transcoder exited due to an error.}}}
2020/12/21 21:37:35.917 (167 MB) (67382) ❌ PMKPlayerManager.m:307 | Error playing media of type video: Error Domain=PMKPlaybackErrorDomain Code=4006 "Playback session was terminated by the server" UserInfo={NSLocalizedDescription=Playback session was terminated by the server, NSUnderlyingError=0x280970d20 {Error Domain=PMKTerminationErrorDomain Code=4006 "Conversion failed. The transcoder exited due to an error." UserInfo={NSLocalizedDescription=Conversion failed. The transcoder exited due to an error.}}}
2020/12/21 21:37:35.921 (167 MB) (67382) 🔧 PMKAppSessionManager.m:489 | Using playback metrics context: home:hub.home.ondeck@1,0
2020/12/21 21:37:35.923 (167 MB) (70127) 🔧 PMKMetricsEngine.m:348 | Generated identifiable metrics event playback:failure {
col = 0;
connectionType = remote;
context = "home:hub.home.ondeck";
error = 4006;
page = preplay;
player = mpv;
reason = "Playback session was terminated by the server";
row = 1;
serverType = online;
sessionIdentifier = "C1DE2634-AF14-44DE-BDA7-4AE297B74753";
type = episode;
2020/12/21 21:37:35.924 (167 MB) (70237) ➖ PMKMPVVideoPlayerRenderer.m:310 | Finishing render thread
2020/12/21 21:37:35.947 (167 MB) (67382) ⚠️ PMKMetadata+PlaybackParameters.m:15 | Container should not be nil for <PMKMetadata:0x11aabded0 key:/library/metadata/62504 title:Another Toothpick type:4 isDirectory:0>
2020/12/21 21:37:35.955 (167 MB) (70030) 🔧 PMKNetworkTask.m:197 | Started: 47: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /video/:/transcode/universal/stop?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&includeCodecs=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=40000&partIndex=0&path=/library/metadata/62504&protocol=hls&session=C5572165-0D68-40ED-B344-029938C9DF0F&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=4096x2160
2020/12/21 21:37:35.976 (167 MB) (70127) 🔧 PMKNetworkTask.m:221 | Completed [200]: 47: Z800 (cb33cea144ee753b39281a35b05e35340ece5c96): GET /video/:/transcode/universal/stop?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&includeCodecs=1&location=wan&maxVideoBitrate=3000&mediaBufferSize=40000&partIndex=0&path=/library/metadata/62504&protocol=hls&session=C5572165-0D68-40ED-B344-029938C9DF0F&subtitleSize=100&videoBitrate=3000&videoQuality=75&videoResolution=4096x2160
2020/12/21 21:37:37.134 (167 MB) (70135) 🔧 PMKNetworkTask.m:197 | Started: 6: Susan’s iPhone (13B067E2-9965-4C42-947A-1DF4FE0AD004): GET http://127.0.0.1:32500/
2020/12/21 21:37:37.160 (167 MB) (70127) 🔧 PMKNetworkTask.m:221 | Completed [200]: 6: Susan’s iPhone (13B067E2-9965-4C42-947A-1DF4FE0AD004): GET http://127.0.0.1:32500/
2020/12/21 21:37:41.461 (167 MB) (67382) ➖ PMKAppDelegate.m:220 | Application will resign active
2020/12/21 21:37:42.291 (167 MB) (67382) ➖ PMKAppDelegate.m:225 | Application did enter background
2020/12/21 21:37:42.293 (167 MB) (69965) ➖ PMKEventSourceManager.m:188 | Channel connection to Cloud (plex.tv) - server,cloud closed
2020/12/21 21:37:42.297 (167 MB) (67382) ➖ PMKServiceFinder.m:156 | Paused service finder for ServerService
2020/12/21 21:37:42.300 (167 MB) (67382) ➖ PMKServiceFinder.m:156 | Paused service finder for PlayerService
2020/12/21 21:37:42.301 (167 MB) (67382) ➖ PMKServiceAdvertizer.m:135 | Paused service advertizer for PlayerService
2020/12/21 21:37:42.301 (167 MB) (67382) 🔧 PMKAppSessionManager.m:289 | Suspended session C1DE2634-AF14-44DE-BDA7-4AE297B74753 (length: 159.9382090000017)
2020/12/21 21:37:42.301 (167 MB) (67382) ➖ PMKCameraUploadEngine.m:253 | Entering background.
2020/12/21 21:37:42.301 (167 MB) (69965) ➖ PMKEventSourceManager.m:188 | Channel connection to Susan’s iPhone (13B067E2-9965-4C42-947A-1DF4FE0AD004) - server,embedded closed
2020/12/21 21:37:42.347 (164 MB) (70136) ➖ PMKEventSourceManager.m:188 | Channel connection to Z800 (cb33cea144ee753b39281a35b05e35340ece5c96) - server,standard,hasPresence,requiresSecureConnections closed
2020/12/21 21:37:42.649 (158 MB) (67382) ➖ PMKInterruptionListener.m:63 | Interruption happened, but no audio nor video was playing: NSConcreteNotification 0x280bf9230 {name = AVAudioSessionInterruptionNotification; object = <AVAudioSession: 0x2804f3320>; userInfo = {
AVAudioSessionInterruptionTypeKey = 1;
The log says the error is happening on your PMS. Can you provide me the log from your PMS for that time period. If the logs have rolled over, you’ll need to get your sister to try again to reproduce the error then get me the PMS log from that new attempt.
I had her try again and record the exact time, I messaged you both logs.
Thanks this helped with me on my Apple TV settings to play videos it would not!
Happy New Year!
I think I’m seeing this same issue as well. Had to roll back to server 1.21.1.3766 to get it to work. Most of my media is H.264 high@4.1 video with AAC-LC or AC-3 audio. Until the recent update, it was able to direct play. I’m using the Plex official Docker image. I tried updating and rolling back several times and the issue consistently appears on the newer version, but not the older version. I don’t have “automatically adjust quality” enabled.
My issue ended up being the Automatic Bitrate Adjustment option needed to be turned off and the noexec option in /etc/fstab got re-entered somehow by OMV and would not allow transcode.
The update was probably just a coincidence in my case.
Synology DS1618+ on Intel Atom® Processor C3538 NO Supports Intel Quick Sync Video.
Plex Web Version 4.47.3
Can I Direct Play 4K (HEVC Main 10 HDR) on my web browser Chrome ?
On my Samsung TV is possible, but when I try to play on my computer (Intel i7 6th genertion) I’ll get info that my server is not powerful enough to convert video.
log:
Jan 03, 2021 22:58:08.527 [0x7f6d37735700] Debugowanie — WebSocket: Performing handshake from origin http://192.168.1.100:32400
Jan 03, 2021 22:58:08.527 [0x7f6d37735700] Debugowanie — Beginning read from WebSocket
Jan 03, 2021 22:58:08.574 [0x7f6d44911700] Debugowanie — Auth: authenticated user 1 as Y4k
Jan 03, 2021 22:58:08.574 [0x7f6ce6b7d700] Debugowanie — Request: [192.168.1.33:64123 (Subnet)] GET /activities (9 live) TLS GZIP Signed-in Token (Y4k)
Jan 03, 2021 22:58:08.574 [0x7f6d44911700] Debugowanie — Completed: [192.168.1.33:64123] 200 GET /activities (9 live) TLS GZIP 0ms 429 bytes (pipelined: 24)
Jan 03, 2021 22:58:10.412 [0x7f6d44623700] Debugowanie — Auth: authenticated user 1 as Y4k
Jan 03, 2021 22:58:10.412 [0x7f6d44335700] Debugowanie — Request: [192.168.1.33:64123 (Subnet)] GET /library/metadata/1133?includeExternalMedia=1&Accept-Language=pl&includeConcerts=1&includeExtras=1&includeOnDeck=1&includePopularLeaves=1&includePreferences=1&includeChapters=1&includeStations=1&includeExternalMedia=1&asyncAugmentMetadata=1&checkFiles=1 (9 live) TLS GZIP Signed-in Token (Y4k)
Jan 03, 2021 22:58:10.424 [0x7f6d44335700] Debugowanie — It took 0.000000 ms to retrieve 125 items.
Jan 03, 2021 22:58:10.425 [0x7f6d44623700] Debugowanie — Auth: authenticated user 1 as Y4k
Jan 03, 2021 22:58:10.425 [0x7f6d44bff700] Debugowanie — Request: [192.168.1.33:64179 (Subnet)] GET /:/timeline?ratingKey=1133&key=%2Flibrary%2Fmetadata%2F1133&playbackTime=0&playQueueItemID=1306&state=playing&hasMDE=1&context=library%3Acontent.library&time=0&duration=8497000 (9 live) TLS GZIP Signed-in Token (Y4k)
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — Client [czy19sxtox01riinn79m9p57] reporting timeline state playing, progress of 0/8497000ms for guid=, playbackTime=0ms ratingKey=1133 url=, key=/library/metadata/1133, containerKey=, metadataId=1133, source=
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — [Now] User is Y4k (ID: 1)
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — [Now] Device is Chrome (Chrome).
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — [Now] Profile is Web
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — [Now] Updated play state for /library/metadata/1133.
Jan 03, 2021 22:58:10.427 [0x7f6d44bff700] Debugowanie — Statistics: (32fxv4a8tyajx68tv8mktgod) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Jan 03, 2021 22:58:10.432 [0x7f6d44911700] Debugowanie — Completed: [192.168.1.33:64179] 200 GET /:/timeline?ratingKey=1133&key=%2Flibrary%2Fmetadata%2F1133&playbackTime=0&playQueueItemID=1306&state=playing&hasMDE=1&context=library%3Acontent.library&time=0&duration=8497000 (9 live) TLS GZIP 7ms 526 bytes (pipelined: 3)
Jan 03, 2021 22:58:10.437 [0x7f6d44335700] Debugowanie — We’re going to try to auto-select an audio stream for account 1.
Jan 03, 2021 22:58:10.437 [0x7f6d44335700] Debugowanie — Selecting best audio stream for part ID 5696 (autoselect: 1 language: pl)
Jan 03, 2021 22:58:10.437 [0x7f6d44335700] Debugowanie — Audio Stream: 10896, Subtitle Stream: -1
Jan 03, 2021 22:58:10.536 [0x7f6d44911700] Debugowanie — Completed: [192.168.1.33:64123] 200 GET /library/metadata/1133?includeExternalMedia=1&Accept-Language=pl&includeConcerts=1&includeExtras=1&includeOnDeck=1&includePopularLeaves=1&includePreferences=1&includeChapters=1&includeStations=1&includeExternalMedia=1&asyncAugmentMetadata=1&checkFiles=1 (9 live) TLS GZIP 124ms 10534 bytes (pipelined: 25)
Jan 03, 2021 22:58:10.594 [0x7f6d44623700] Debugowanie — Auth: authenticated user 1 as Y4k
Jan 03, 2021 22:58:10.594 [0x7f6d37735700] Debugowanie — Request: [192.168.1.33:64123 (Subnet)] GET /:/timeline?ratingKey=1133&key=%2Flibrary%2Fmetadata%2F1133&playbackTime=0&playQueueItemID=1306&state=error&hasMDE=1&context=library%3Acontent.library&time=0&duration=8497000 (9 live) TLS GZIP Signed-in Token (Y4k)
Jan 03, 2021 22:58:10.595 [0x7f6d37735700] Debugowanie — Client [czy19sxtox01riinn79m9p57] reporting timeline state error, progress of 0/8497000ms for guid=, playbackTime=0ms ratingKey=1133 url=, key=/library/metadata/1133, containerKey=, metadataId=1133, source=
Jan 03, 2021 22:58:10.596 [0x7f6d37735700] Debugowanie — [Now] User is Y4k (ID: 1)
Jan 03, 2021 22:58:10.596 [0x7f6d37735700] Debugowanie — [Now] Device is Chrome (Chrome).
Jan 03, 2021 22:58:10.596 [0x7f6d37735700] Debugowanie — [Now] Profile is Web
Jan 03, 2021 22:58:10.596 [0x7f6d37735700] Debugowanie — [Now] Updated play state for /library/metadata/1133.
Jan 03, 2021 22:58:10.596 [0x7f6d37735700] Debugowanie — Statistics: (32fxv4a8tyajx68tv8mktgod) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Jan 03, 2021 22:58:10.602 [0x7f6d44911700] Debugowanie — Completed: [192.168.1.33:64123] 200 GET /:/timeline?ratingKey=1133&key=%2Flibrary%2Fmetadata%2F1133&playbackTime=0&playQueueItemID=1306&state=error&hasMDE=1&context=library%3Acontent.library&time=0&duration=8497000 (9 live) TLS GZIP 7ms 526 bytes (pipelined: 26)
Thank You
