Been trying for a day to get CEC setup working on rasplex, but just can’t quite get it and figured it was time to ask for help…
TV: 55KU6300
Pi: RaspberryPi 3B
What I have done:
installed kodi and verified TV / hdmi cable are working with CEC (it worked perfect, no setup needed!)
Ensured CEC was turned on in rasplex settings (System>Input Devices>Peripherals>CEC Adapter)
So far this thread has been most helpful:
forums.plex.tv/discussion/150209/cec-remote-buttons-how-do-i-find-out-which-button-has-been-pressed
After logging in via SSH I enabled debug log (tail -F /storage/.plexht/temp/plexhometheater.log) and hit the left button on my remote. It shows this as a response:
11:04:30 T:1851782112 DEBUG: CecLogMessage - >> 01:44:03
11:04:30 T:1851782112 DEBUG: CecLogMessage - SetCurrentButton left (3) D:0ms cur:3
11:04:30 T:1851782112 DEBUG: CecLogMessage - key pressed: left (3) current(ff) duration(0)
11:04:30 T:1851782112 DEBUG: CecLogMessage - Changed key left (3) D:0ms cur:ff
11:04:30 T:1851782112 DEBUG: CecLogMessage - key pressed: left (3, 0)
11:04:30 T:1851782112 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:15)
11:04:30 T:1851782112 DEBUG: PushCecKeypress - added key a9
11:04:30 T:1851782112 DEBUG: CecLogMessage - CheckKeypressTimeout T:1489.293
11:04:30 T:1851782112 DEBUG: CecLogMessage - Key left: idle (duration:0) (3) timeout:500ms (rel:500,rep:0,prs:1,rel:0)
11:04:30 T:1851782112 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): user control pressed (44)
11:04:30 T:1851782112 DEBUG: CecLogMessage - >> 01:8b:03
11:04:30 T:1851782112 DEBUG: CecLogMessage - key released: left (3) D:69ms
11:04:30 T:1851782112 DEBUG: PushCecKeypress - received key a9 duration 69 (rep:0 size:16)
11:04:30 T:1851782112 DEBUG: PushCecKeypress - replaced key a9
11:04:30 T:1851782112 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor remote button up (8B)
So I believe the CEC is working as it should, it’s just a question of setting up the key mapping.
This is where I’m a little more fuzzy on what it should be, but I’ve been trying some permutations of keymap files to no avail.
The xlm tag inside the <>, what should that be named?
* <a9> * <left> * <left id="a9">
Here is the current file (just trying to get basic navigation, the rest can be sorted later once I understand this)
<keymap> <remote name="CEC ADAPTER"> <a9>Left</a9> <a8>Right</a8> <a6>Up</a6> <a7>Down</a7> <b>Select</b> <d8>Back</d8> </remote> </keymap>
Any hints what I’m doing wrong? the file is being saved as \Userdata\keymaps\remote.xml and the pi is being restarted once the file is saved there. Is there anything else I should be doing to get it to load that keymap? Any quick test I can do to ensure its being loaded correctly?
Appreciate the help!
