It seems that with the new HTTPS support in Plex, it is using Diffie-Hellman (DHE for Ephemeral Diffie-Hellman) protocol for session key exchange (please, please correct me if I am wrong). Is there any possible way to change the cipher suite to one of the below?
The reason I ask is I am attempting to do SSL Inbound decryption on my firewall (Palo Alto Networks) to take a peek inside the SSL tunnel to identify the traffic that is inside the SSL/TLS tunnel. (Better layer 7 control on FW as well as scanning for possible malware, etc)
Yes. I want to do deeper packet inspection. But I wouldn’t say that I am asking Plex to change it, but rather just asking if
A. It is a current possibility to change what cipher suite it uses
or
B. Is it possible to have the capability to select cipher suite in the future.
It is not possible for a user to change the suite because the other end of the connection is the Plex Cloud and the rules for connecting to it are VERY strict. Without the source code and keys to the Plex kingdom, you can’t do it.
For a long time, users were complaining Plex wasn’t secure enough so it was made more secure. You’re asking how to make it less secure so you can dig into the packets for whatever reason(s) you might have.
If you are on a corporate or other type LAN and the use of Plex is a problem for you, I respectfully suggest you simply block it as that is the only real way of knowing what is and isn’t happening.
The other end of the communication should be directly to the client, and as I am using my own certificate on the server, I own the key for it so I can decrypt that session if need be. (That is, if the local Plex Server was not negotiating a DH cipher suite)
My understanding is that plex cloud is just a connection broker and should be redirecting clients connecting to the link that I have provided on my custom certificate.
If you install your certs in your proxy, you will have the best which can be had. Anything else on Plex’s part exposes all other Plex users to security issues. What you do inside your proxy is for you to decide.
