Channel to View VLC Stream
Essentially what i'm trying to do is create a plex plugin that will allow me to watch a live stream.
I am currently using vlc to successfully tune my tvtuner and can stream to other vlc clients. I have the best success using an RTP stream with no transcoding simply providing the ts encapsulation as it is received over the air.
cvlc atsc://frequency=605029000 --sout '#rtp{dst=10.0.1.8,port=5004,mux=ts,ttl=1}' --sout-keep -d
Using a separate instance of vlc I can open the network stream using rtp://10.0.1.8:5004 and it streams butter smooth.
I have also successfully streamed content using HTTP Live Streaming (HLS) as designed by Apple:
cvlc -I dummy --ffmpeg-hw atsc://frequency=605000000 :live-cache=5000 --sout='#transcode{vcodec=h264,vb=200,fps=30,scale=.5,venc=x264{aud,level=50,keyint=15,bframes=0,ref=1},acodec=aac,ab=40,channels=2,samplerate=22050}:duplicate{dst=std{mux=ts,dst=-,access=livehttp{seglen=30,delsegs=true,numsegs=20,index=/var/www/stream/live.m3u8,index-url=content/live-######.ts},mux=ts{use-key-frames},dst=/var/www/stream/content/live-######.ts,ratecontrol=true}}'
This generates a .m3u8 file which is dynamically updated as new clips are processed. It is accessible in safari on the iphone.
What I'm trying to do is create a plugin that will grab that live feed (preferably an rtp stream) and transcode it on the fly for my clients.
I have created a plugin which I thought would essentially look at that address (10.0.1.8:5004) and transcode it for whichever client I am using. However, I can't get it to actually find the stream!
Here's my init.py:
# Autor:    Roland Fritz
# Date:     7/31/2012
# About:    This plugin is designed to enable live TV viewing on Plex clients. Required for this to
#	    to work is a usb DTV tuner and vlc.
# NOTE:	    I do not make any guarantees that this will work for you. I do not endorse using this for
#	    anything beyond personal use. This has been tested to work on Ubuntu server 12.04 running PMS.
# Version:  0.1
#import mechanize
VIDEO_PREFIX = “/video/fritztv”
NAME = L(‘Title’)
ART = ‘art-default.jpg’
ICON = ‘icon-default.jpg’
NAMESPACES = {‘a’:‘http://xspf.org/ns/0/’}
def Start():
Plugin.AddPrefixHandler(VIDEO_PREFIX, MainMenu, NAME, ICON, ART)
Plugin.AddViewGroup("InfoList", viewMode="InfoList", mediaType="items")
Plugin.AddViewGroup("List", viewMode="List", mediaType="items")
MediaContainer.title1 = NAME
MediaContainer.viewGroup = "List"
MediaContainer.art = R(ART)
DirectoryItem.thumb = R(ICON)
VideoItem.thumb = R(ICON)
HTTP.CacheTime = CACHE_1HOUR
def MainMenu():
oc = ObjectContainer(title1=“VLC Player”)
mo = MediaObject(parts=[PartObject(key=HTTPLiveStreamURL("10.0.1.8:5004"))])
vco = VideoClipObject(title="Play local VLC stream", url='10.0.1.8:5004')
vco.add(mo)
oc.add(vco)
return oc
And Here's the Log
2013-04-17 13:44:50,161 (-48d91700) :  INFO (core:336) - Starting framework core - Version: 2.3.4, Build: 7570849 (Tue Apr  9 16:23:58 UTC 2013)
2013-04-17 13:44:50,161 (-48d91700) :  DEBUG (core:348) - Using the standard policy
2013-04-17 13:44:50,162 (-48d91700) :  DEBUG (core:437) - Starting runtime component.
2013-04-17 13:44:50,164 (-48d91700) :  DEBUG (core:437) - Starting caching component.
2013-04-17 13:44:50,165 (-48d91700) :  DEBUG (core:437) - Starting data component.
2013-04-17 13:44:50,166 (-48d91700) :  DEBUG (core:437) - Starting networking component.
2013-04-17 13:44:50,177 (-48d91700) :  DEBUG (networking:318) - Loaded HTTP cookies
2013-04-17 13:44:50,237 (-48d91700) :  DEBUG (networking:504) - Setting the default network timeout to 20.0
2013-04-17 13:44:50,238 (-48d91700) :  DEBUG (core:437) - Starting localization component.
2013-04-17 13:44:50,249 (-48d91700) :  INFO (localization:408) - Setting the default locale to en-us
2013-04-17 13:44:50,250 (-48d91700) :  DEBUG (localization:426) - Loaded en strings
2013-04-17 13:44:50,250 (-48d91700) :  DEBUG (core:437) - Starting messaging component.
2013-04-17 13:44:50,251 (-48d91700) :  DEBUG (core:437) - Starting debugging component.
2013-04-17 13:44:50,251 (-48d91700) :  DEBUG (core:437) - Starting services component.
2013-04-17 13:44:50,252 (-48d91700) :  DEBUG (core:437) - Starting myplex component.
2013-04-17 13:44:50,252 (-48d91700) :  DEBUG (core:437) - Starting notifications component.
2013-04-17 13:44:50,275 (-4dd054c0) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.fritztv'
2013-04-17 13:44:50,563 (-48d91700) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.fritztv in namespace 'metadata'
2013-04-17 13:44:50,646 (-48d91700) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2013-04-17 13:44:50,967 (-48d91700) :  DEBUG (runtime:1090) - Created a thread named 'load_all_services'
2013-04-17 13:44:50,968 (-4dd054c0) :  DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2013-04-17 13:44:50,972 (-48d91700) :  DEBUG (runtime:1090) - Created a thread named 'get_server_info'
2013-04-17 13:44:50,975 (-48d91700) :  DEBUG (core:149) - Finished starting framework core
2013-04-17 13:44:50,975 (-48d91700) :  DEBUG (core:547) - Loading plug-in code
2013-04-17 13:44:50,973 (-4ed074c0) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400'
2013-04-17 13:44:50,991 (-48d91700) :  DEBUG (core:553) - Finished loading plug-in code
2013-04-17 13:44:51,034 (-4dd054c0) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2013-04-17 13:44:51,042 (-48d91700) :  DEBUG (runtime:623) - Adding a prefix handler for 'FRITZTV' ('/video/fritztv')
2013-04-17 13:44:51,068 (-48d91700) :  INFO (core:598) - Started plug-in
2013-04-17 13:44:51,068 (-48d91700) :  DEBUG (socketinterface:144) - Starting socket server
2013-04-17 13:44:51,076 (-4ed074c0) :  DEBUG (core:525) - Machine identifier is b51c1396cf6dfd857daa78c4ee9ddd57f97f76d1
2013-04-17 13:44:51,077 (-4ed074c0) :  DEBUG (core:526) - Server version is 0.9.7.22.510-8faeab3
2013-04-17 13:44:51,080 (-48d91700) :  DEBUG (runtime:1090) - Created a thread named 'start'
2013-04-17 13:44:51,080 (-48d91700) :  INFO (socketinterface:168) - Socket server started on port 60346
2013-04-17 13:44:51,081 (-48d91700) :  INFO (pipeinterface:25) - Entering run loop
2013-04-17 13:44:51,081 (-48d91700) :  DEBUG (runtime:700) - Handling request GET /:/prefixes
2013-04-17 13:44:51,084 (-48d91700) :  DEBUG (runtime:797) - Found route matching /:/prefixes
2013-04-17 13:44:51,102 (-48d91700) :  DEBUG (runtime:897) - Response: [200] MediaContainer, 442 bytes
2013-04-17 13:44:51,429 (-4dd054c0) :  DEBUG (services:362) - Loaded services
2013-04-17 13:44:51,437 (-4e5064c0) :  DEBUG (services:438) - No shared code to load
2013-04-17 13:45:08,839 (-4dd054c0) :  DEBUG (runtime:700) - Handling request GET /:/plugins/com.plexapp.plugins.fritztv/resources/icon-default.jpg?t=1366169333
2013-04-17 13:45:08,912 (-4e5064c0) :  DEBUG (runtime:700) - Handling request GET /:/plugins/com.plexapp.plugins.fritztv/resources/icon-default.jpg?t=1366169333
2013-04-17 13:45:08,920 (-4dd054c0) :  DEBUG (runtime:797) - Found route matching /:/plugins/com.plexapp.plugins.fritztv/resources/icon-default.jpg
2013-04-17 13:45:08,920 (-4e5064c0) :  DEBUG (runtime:797) - Found route matching /:/plugins/com.plexapp.plugins.fritztv/resources/icon-default.jpg
2013-04-17 13:45:08,943 (-4e5064c0) :  DEBUG (runtime:897) - Response: [200] DataObject, 23789 bytes
2013-04-17 13:45:08,973 (-4dd054c0) :  DEBUG (runtime:897) - Response: [200] DataObject, 23789 bytes
2013-04-17 13:45:10,923 (-4dd054c0) :  DEBUG (runtime:700) - Handling request GET /video/fritztv
2013-04-17 13:45:10,925 (-4dd054c0) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-04-17 13:45:10,927 (-4dd054c0) :  DEBUG (runtime:797) - Found route matching /video/fritztv
2013-04-17 13:45:10,927 (-4dd054c0) :  WARNING (objectkit:193) - The 'platforms' attribute is deprecated and should not be assigned.
2013-04-17 13:45:10,928 (-4dd054c0) :  WARNING (objectkit:193) - The 'protocols' attribute is deprecated and should not be assigned.
2013-04-17 13:45:10,929 (-4dd054c0) :  DEBUG (base:123) - Checking if com.plexapp.plugins.fritztv is broken
2013-04-17 13:45:10,930 (-4dd054c0) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjcKY29tLnBsZXhhcHAucGx1Z2lucy5mcml0enR2czEwCmlkZW50aWZpZXJyMAo_'
2013-04-17 13:45:10,943 (-4dd054c0) :  WARNING (objectkit:193) - Media part has no streams - attempting to synthesize
2013-04-17 13:45:10,949 (-4dd054c0) :  DEBUG (services:602) - No service found for URL '10.0.1.8:5004'
2013-04-17 13:45:10,949 (-4dd054c0) :  DEBUG (services:617) - No matching services found for '10.0.1.8:5004'
2013-04-17 13:45:10,956 (-4dd054c0) :  DEBUG (services:41) - Loading service code for Fallback (URLServiceRecord)
2013-04-17 13:45:11,178 (-4dd054c0) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-04-17 13:45:11,181 (-4dd054c0) :  DEBUG (runtime:106) - Sending packed state data (108 bytes)
2013-04-17 13:45:11,182 (-4dd054c0) :  DEBUG (runtime:897) - Response: [200] MediaContainer, 774 bytes
2013-04-17 14:14:36,146 (-4dd054c0) :  DEBUG (runtime:700) - Handling request GET /video/fritztv
2013-04-17 14:14:36,149 (-4dd054c0) :  DEBUG (runtime:797) - Found route matching /video/fritztv
2013-04-17 14:14:36,151 (-4dd054c0) :  DEBUG (base:123) - Checking if com.plexapp.plugins.fritztv is broken
2013-04-17 14:14:36,172 (-4dd054c0) :  DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjcKY29tLnBsZXhhcHAucGx1Z2lucy5mcml0enR2czEwCmlkZW50aWZpZXJyMAo_'
2013-04-17 14:14:36,183 (-4dd054c0) :  DEBUG (services:602) - No service found for URL '10.0.1.8:5004'
2013-04-17 14:14:36,183 (-4dd054c0) :  DEBUG (services:617) - No matching services found for '10.0.1.8:5004'
2013-04-17 14:14:36,187 (-4dd054c0) :  DEBUG (runtime:106) - Sending packed state data (108 bytes)
2013-04-17 14:14:36,188 (-4dd054c0) :  DEBUG (runtime:897) - Response: [200] MediaContainer, 774 bytes
Thanks,
FRITZ|FRITZ
You won't have much luck with a RTP stream. PMS doesn't support it. Yes, FFMPEG does but PMS does not. Oh well. In theory, the HLS stream should work but you're constructing your VideoClipObject improperly.  The current plugin framework is designed around URL Services. In your case, an URL Service isn't really going to add much benefit but going without one makes the __init__.py look a little more confusing.
When you're not using an URL Service, you must not set the 'url' attribute of the VideoClipObject. Instead you need to set the "key" and "rating_key" attibutes.  Usually the key is a callback and the rating_key is a unique string to identify the video. Often the URL can be used as the rating_key. I just re-wrote the channel for Sesame Street using this method. It uses MP4 videos rather than m3u8, but the concept for structuring the VideoClipObject is pretty much the same.
this thread may provide you some useful information.
