Cleanup Wizard/Helper
Hi Plex
I would love a helping hand for clearing up space on my server.
My problem is that I don’t want to remove content, if any of my plex friends is using it, and i don’t know what they are using, and what they are not.
I would love a wizard, which suggests shows and movies to remove, based on last accessed by me or any friend.
The amount of time should be changeable to fit anyones needs. And shows should be pr. show not pr. episode, so it skips any show intirely if any friend has watched as little as a single episode within the set amount of time.
Is it doable? and is it feasable for you to make such a feature?
Best regards
CinaedPhoenix
