Collections with 1
Server 4.116.1
I’m connected directly to the server for viewing.
I made a mistake when building my library for the first time, I selected Collections with 1. I changed it to 2 and ran refresh all metadata.
My collections are still showing 1. How can I fix this?
You could manually delete the „obsolete“ collections or set them to be hidden.
That is a crummy solution, I probably have 75+ collections with one in them. Why does the metadate update not properly fix this?
Metadata refreshes will not delete collections. Once created, they need to be deleted manually.
