CONEXIONES
Porque ahora no se conecta directamente con PLEX, sino http://127.0.01:32400/web/index/htlm#.
Si alguien puede ayudarme Gracias.
@DANHIP said:
Because now it does not connect directly with PLEX, but http://127.0.01:32400/web/index/htlm#.
If anyone can help me thank you.
We are going to need more info to go on. Was this after an update? Are you haveing issues with remote connections? What operating system are you running PMS on? What browser?
I’m guessing the link you gave above is misstyped, it should be http://127.0.0.1/web/index.html for hitting the web application via localhost.
