Configuring M3U8 url to change transcoding options
Hi there,
I'm having some issues with an app for an LG TV and it's not able to always read the format outputted to the .ts files by ffmpeg. I find it quite strange that it occasionally works, but I'm assuming that ffmpeg guesses certain values based on others to improve the quality etc.
I'm using the url structure that it's used in Plex/Web in Safari:
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * path => http://127.0.0.1:32400/library/metadata/130
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * mediaIndex => 0
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * partIndex => 0
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * protocol => hls
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * offset => 0
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * fastSeek => 1
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * directPlay => 1
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * directStream => 1
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * videoQuality => 100
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * videoResolution => 1280x720
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * maxVideoBitrate => 3724
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * subtitleSize => 100
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * audioBoost => 100
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * session => dffuc2po15w
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Version => 1.2.16
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Platform-Version => 7
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Client-Identifier => dffuc2po15w
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Platform => Safari
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Product => Web Client
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Device => Mac
Oct 25, 2013 14:12:14 [0x80850e000] DEBUG -  * X-Plex-Device-Name => Plex/Web (Safari)
The original files work fine. They are usually formatted correctly anyway and are supported by Safari and the LG TV. I know this because I have 2 apps, one supports transcoding, the other does not and the one that doesn't plays all media perfectly.
From what I've learnt, the transcoding parameters are determined by the platform because I've noticed "Using profile Safari" in the log as well. Basically my question is, can I prevent it from using a pre-defined profile and customise the parameters manually?
Looking at the input and output formats for ffmpeg, there are only minor differences between the format that works and the transcoded output, which doesn't. Here's some samples:
Oct 25, 2013 14:12:14 [0x808137c00] INFO - [Transcoder] Input #0, matroska,webm, from 'http://127.0.0.1:32400/library/parts/104/file.mkv':
Oct 25, 2013 14:12:14 [0x80764e800] INFO - [Transcoder]     Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Oct 25, 2013 14:12:14 [0x807ce2800] INFO - [Transcoder]     Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
Oct 25, 2013 14:12:14 [0x807640400] INFO - [Transcoder] Output #0, segment, to 'media-%05d.ts':
Oct 25, 2013 14:12:14 [0x80850e000] INFO - [Transcoder]     Stream #0:0: Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 90k tbn, 23.98 tbc
Oct 25, 2013 14:12:14 [0x808137c00] INFO - [Transcoder]     Stream #0:1: Audio: aac, 48000 Hz, 5.1, fltp, 384 kb/s (default)
Now it looks like only 2 of the values are different; the added q=2-31 and the 90k tbn value. Now I'm not 100% sure what these values represent, but if I could try and manually configure them maybe I could attempt to alter them to match.
One other example of the streaming url structure I found was for apple tv and this seems to pass what it's capable of. Something like:
X-Plex-Client-Capabilities => protocols=http-live-streaming,http-mp4-streaming,http-streaming-video,http-streaming-video-720p,http-mp4-video,http-mp4-video-720p;videoDecoders=h264{profile:high&resolution:1080&level:51};audioDecoders=mp3,aac{bitrate:160000}
Now, I tried this but it seems to just output the same format. Is there any other changes that could be made to this?
Any help would be very much appreciated. I've been battling with this issue for a week now and I'm really getting to a dead end.
Thanks.
What you really want to be doing is building a profile for the LG, and setting it all up there :)
Is it possible to define a profile dynamically or does it have to be a static file in the PMS configuration?
I've looked around the PMS files and I can only find "Plug-ins/System.bundle/Contents/Resources/clients.xml" and "Plug-ins/System.bundle/Contents/Resources/dlnaclientprofiles.xml" and neither seem to define the transcoding profiles.
Thanks for the reply. At least now I have something to move forward with.
Edit: Found the profiles. Thanks.
