yesterday all my shows and movies worked, now today half of what I own wont play. It tries loading for a few seconds then says “We cannot play this, please check you connection” . I know it is not a connection issue, nothing has changed, and I even hooked up ethernet just to make sure.
I have finally figured out that it will not play anything with 5.1 audio, only stereo audio. I went to the settings where you can change what can play, i tried turning it all the way down, and turning it off, and a few inbetween with no fix.
I am playing it on a Philips Android TV, and the server is on my computer in the other room on the same network.
