Server Version#: Linuxserver.io version: 1.41.8.9834-071366d65-ls269
Been using Plex for years. Using the docker image utilizing Unraid as the hypervisor for the last 4-5 with only minor issues. Recently, I’ve seen continuous writes to my redundant cache drives (where the docker images and appdata folders reside). Nothing ever seems to write as utilized space remains unchanged. Writes are usually between 6mbs and 8mbs. Unraid and the plex docker are both current and when the plex docker is stopped, the writes return to normal. CPU usage is also significantly higher than normal as well. 7% - 8% during this process while normal is around .2%. I also have a dedicated GPU so there are no transcoding responsibilities done by the CPU. Nothing is being played, and nothing shows as abnormal in the logs. Any help would be greatly appreciated. Happy to provide any more information that might help.
