Converting with Handbrake
Hi all,
I apologise if this is in the wrong section/category I was unsure as to which it would come under.
With all my Plex media files I try to convert everything to MP4 web optimised but sometimes if I leave Handbrake on converting things over night it seems to of crashed, no error on screen just the application has quit.
I am using Handbrake 0.9.5 (x86_64) on CentOS 6.9
Any ideas and suggestions would be great, thank you.
Regards
Rob
Handbrake Guide in my signature, but I know nothing about CentOS.
You might want to try a newer version of Handbrake.
1.0.7 is the latest and seems to be more stable than previous versions.
Thank you for your reply, I believe it is the latest version that I have for CentOS.
I’ve checked the software manager and it appears to be the latest version on there.
If anyone can help that would be great
Here is my latest Handbrake log before it crashed
No accelerated IMDCT transform found
[12:38:41] reader: done. 1 scr changes
[12:38:41] work: average encoding speed for job is 153.077438 fps
[12:38:41] sync: got 43020 frames, 43045 expected
[12:38:41] h264-decoder done: 43020 frames, 0 decoder errors, 0 drops
[12:38:41] render: lost time: 0 (0 frames)
[12:38:41] render: gained time: 0 (0 frames) (0 not accounted for)
x264 [info]: frame I:366 Avg QP:17.40 size: 52897 PSNR Mean Y:46.35 U:52.73 V:54.00 Avg:47.69 Global:47.47
x264 [info]: frame P:17025 Avg QP:20.07 size: 12154 PSNR Mean Y:43.83 U:49.39 V:50.43 Avg:45.07 Global:44.93
x264 [info]: frame B:25629 Avg QP:23.59 size: 2652 PSNR Mean Y:43.18 U:49.02 V:50.17 Avg:44.45 Global:44.28
x264 [info]: consecutive B-frames: 4.1% 22.9% 72.9%
x264 [info]: mb I I16…4: 12.4% 0.0% 87.6%
x264 [info]: mb P I16…4: 2.3% 0.0% 6.1% P16…4: 54.1% 18.1% 8.4% 0.0% 0.0% skip:11.0%
x264 [info]: mb B I16…4: 1.9% 0.0% 0.6% B16…8: 31.9% 7.0% 0.5% direct: 8.6% skip:49.6% L0:28.1% L1:60.4% BI:11.5%
x264 [info]: coded y,uvDC,uvAC intra: 64.2% 77.3% 36.5% inter: 16.3% 25.8% 0.9%
x264 [info]: i16 v,h,dc,p: 37% 18% 20% 25%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 14% 16% 5% 8% 8% 7% 6% 5%
x264 [info]: i8c dc,h,v,p: 51% 17% 25% 8%
x264 [info]: Weighted P-Frames: Y:0.9% UV:0.3%
x264 [info]: ref P L0: 65.4% 12.4% 22.1% 0.1%
x264 [info]: ref B L0: 77.4% 22.6%
x264 [info]: ref B L1: 92.0% 8.0%
x264 [info]: SSIM Mean Y:0.9812836 (17.278db)
x264 [info]: PSNR Mean Y:43.464 U:49.200 V:50.306 Avg:44.726 Global:44.547 kb/s:1367.97
[12:38:41] muxmp4: optimizing file
[12:38:41] mux: track 0, 43020 frames, 294236292 bytes, 1367.87 kbps, fifo 8
[12:38:41] mux: track 1, 80662 frames, 27525707 bytes, 127.96 kbps, fifo 512
[12:38:41] libhb: work result = 0
[12:38:42] hb_scan: path=/home/robc/Plex/TV Shows/Only Fools and Horses/Series 5/5x08 Frogs Legacy [Xmas 1987].MKV, title_index=3
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening /home/robc/Plex/TV Shows/Only Fools and Horses/Series 5/5x08 Frogs Legacy [Xmas 1987].MKV/BDMV/index.bdmv
libbluray/bluray.c:960: nav_get_title_list(/home/robc/Plex/TV Shows/Only Fools and Horses/Series 5/5x08 Frogs Legacy [Xmas 1987].MKV) failed (0x7ffae811fe30)
[12:38:42] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Using libdvdcss version 1.2.12 for DVD access
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can’t open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[12:38:42] dvd: not a dvd - trying as a stream/file instead
Input #0, matroska,webm, from ‘/home/robc/Plex/TV Shows/Only Fools and Horses/Series 5/5x08 Frogs Legacy [Xmas 1987].MKV’:
Duration: 00:59:52.48, start: 0.000000, bitrate: 256 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 700x568 [PAR 12:11 DAR 1050:781], PAR 191:175 DAR 191:142, 25 fps, 25 tbr, 1k tbn, 50 tbc
Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
[12:38:42] scan: decoding previews for title 1
[12:38:42] scan: audio 0x1: AC-3, rate=48000Hz, bitrate=256000 Unknown (AC3) (2.0 ch)
[12:38:42] scan: 10 previews, 700x568, 25.000 fps, autocrop = 0/0/2/0, aspect 4:3, PAR 12:11
[12:38:42] scan: title (0) job->width:704, job->height:528
[12:38:42] libhb: scan thread found 1 valid title(s)
[12:38:44] gtkgui: Custom Preset: RC Plex Test
[12:38:44] 1 job(s) to process
[12:38:44] starting job
[12:38:44] sync: expecting 89837 video frames
[12:38:44] job configuration:
[12:38:44] * source
[12:38:44] + /home/robc/Plex/TV Shows/Only Fools and Horses/Series 5/5x08 Frogs Legacy [Xmas 1987].MKV
[12:38:44] + title 1, chapter(s) 1 to 1
[12:38:44] + container: matroska,webm
[12:38:44] + data rate: 256 kbps
[12:38:44] * destination
[12:38:44] + /root/Videos/5x08 Frogs Legacy [Xmas 1987].mp4
[12:38:44] + container: MPEG-4 (.mp4 and .m4v)
[12:38:44] + optimized for progressive web downloads
[12:38:44] * video track
[12:38:44] + decoder: h264
[12:38:44] + frame rate: same as source (around 25.000 fps)
[12:38:44] + strict anamorphic
[12:38:44] + storage dimensions: 700 * 568 -> 698 * 568, crop 0/0/2/0, mod 2
[12:38:44] + pixel aspect ratio: 12 / 11
[12:38:44] + display dimensions: 761 * 568
[12:38:44] + encoder: x264
[12:38:44] + options: ref=2:bframes=2:subme=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[12:38:44] + quality: 20.00 (RF)
[12:38:44] * audio track 0
[12:38:44] + decoder: Unknown (AC3) (2.0 ch) (track 1, id 1)
[12:38:44] + bitrate: 256 kbps, samplerate: 48000 Hz
[12:38:44] + mixdown: Stereo
[12:38:44] + encoder: faac
[12:38:44] + bitrate: 128 kbps, samplerate: 48000 Hz
[12:38:44] encx264: encoding with stored aspect 12/11
[12:38:44] encx264: Encoding at constant RF 20.000000
x264 [info]: using SAR=12/11
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264 [info]: profile Main, level 3.0
[12:38:44] reader: first SCR 0 id 0 DTS 0
Handbrake doesn’t do BluRay ISO files.
MakeMKV - to get an MKV file with the original video and audio streams - then Handbrake.
Also, you’ll catch a lot more Handbrake Flies with Honey:
https://forum.handbrake.fr/
all kinds of flies buzzing around over there - and a whole bunch of them know everything there is to know about Handbrake…
I can help you get started on your Handbrake career…
I can’t tell you why Handbrake isn’t working on some OS I’ve never heard of before that’s so far out in the Galaxy you have to use an ancient version of Handbrake.
I’m not trying to do any kind of ISO files?
I’m just trying to convert the MKV to MP4 playback to AAC/H264
I’ll take a look into it but if it doesn’t work I’ll look into backing up everything and then switching the OS as the Handbrake website shows a version for Ubuntu but not CentOS, I believe the CentOS version I have was built using a release of their source code but I cannot confirm 100%
Well… obviously I don’t know much, about much, but…:
libdvdread: Can't open file VIDEO_TS.IFO.
That’s about all I had to go on…
Those logs on the Handbrake Forum will strike more pay dirt than they will here on the Plex Forum.
