Copy and Paste
When Fixing The movie title, it would be nice to be able to copy and paste from one box to the other or from the web to any of the title box. I find the need to change the title to the appropriate language for the movie or shows. at this time I have to type the new title on every box in order to have it changed. If I try to copy and paste, it won’t retain the new pasted title.
Can you share a specific example of what you’re trying to achieve and where it’s currently not working like this?
I’m not sure I understand what you’re suggesting.
Click out of the box before you click “Save Changes,” and it will be fine.
it works for me. you’re going to have to be more specific. Give me a title that doesn’t work and I’ll check. It probably has special characters or something weird, like an invisible character that is being copied.
You can check here: View non-printable unicode characters
