Server Version#: 1.21.3.4046-3c1c83ba4
Player Version#: N/A
Good Morning Everyone,
This morning I work to an error message saying the database was corrupt. I have followed other articles and not having much luck. My database is about 700MBs so it is something I have been using for a long time. I have attempted a restore of the Database Directory, and repairing the database with sqlite3. I really want to repair this database because I need the watched / unwatched but most importantly I have all my playlists. Really don’t want to recreated all my Star Wars or Marvel playlist if I don’t need to.
Thank you for the reply and I thought that would work. Under normal circumstances it would have be I see that I change the default destination to a NAS and upon trying to get that backup I found I had 2 drives that went out in that NAS. I do have the original files that were saying they were corrupted. I also restored those files to a couple days ago and having the same problem. I realize I might be SOL now that I found the NAS has gone out but hoping there is another way.
When you try the above alternative command line, does it abort immediately with the error message, or do you get a dump.sql file out of it? And if you do, how large is it?
It depends on the size of your database and probably also the extent of the damage.
The speed of your server is of course also important.
On my old Core i7 desktop machine, I can export and re-import a 350 MB database (no damage, though) within very few minutes.
There is no guarantee that th eprocedure will be successful. If the damage is too big, you may end up with lots of duplicate or wrong data in the dump file.
I was waiting to make sure I did what you were wanting. I went ahead and ran 5 then 6. I have attached what I get when it runs. It is long and wouldn’t let me put in message.
Looks like the damage is greater than what can be automatically repaired.
I have a guy who said he can take a look at the file over the week end.
I will contact you per PM.
