@dunewarrior said:
Figured it out. apparently SQLITE adds a ROLLBACK to the sql dump now IF there is a fault encountered during the dump process, which there is. SO the FAQ needs updated and the ROLLBACK in the dump file needs changed into a COMMIT. i will try that on mine and post results.
Worked like a charm, at least the DB now passes a pragma check and is running for my server.
Just wanted to add (since this worked for me) for anyone who isn’t familiar, you open the dump.sql file in a text editor and change the last line from ROLLBACK; to COMMIT;
