Create .NFO files for XMBC Agent
I made some script to scrape all the files of a season and all movies in their own folders for easy addition to Plex using the XMBC Agent.
The only metadata you get is what you have in the filename or the folder name.
Simply copy paste the files into a txt file you will rename as .vbs
For Episodes:
I like to name my daily show this way: YYxMMDD (Year x Month Day), then Name of the Show and “-” and Actors and “-” and Title of the episode. Which gives:
14x0809 PlexSeries - Ismelda, Plex, XBMC - Nice VbScript
This script will convert the YYxMMDD in a proper aired date, add the series name to the director tag and each actors (must be separated by comas and no more than 4) to the credits. The title of the episode in Plex will be the “Actors - Episode Name”.
The script will work also for files named
"01x001 Series - EpisodeTitle" not adding any aired date and only adding the Series to the Director tag. and the “EpisodeTitle” as title
or
"01x02 EpisodeTitle" only adding the “EpisodeTitle” as title without the numbering.
The script has to be put where the files are. It will not overwrite any pre-existing .nfo file create with the name of the episodes.
[spoiler]
'Create a .nfo file from the title of the video file used with this format :
’ “YYxMMDD Series Title - Credits1, Credits2, Credits3, Credits 4 - Title of the episode”
'-“YY” is either the season number or the year if from 2009 (can be change if you set the value to sYear) and up
'-“MM” is the month and
'-“DD” the day.
’ If the numbering is less than 7 characters then it is ignored
'-“Series Title” goes into the Director tag
'-“Credits1 to 4” is optional and will fill the credits if it exists and is used for the actors up to 4
’ and each must be separated with a comma
'-“Title of the episode” is just the name of the episode.
set wshell = createobject(“WScript.Shell”)
CurPath = WShell.Currentdirectory
Set fso = CreateObject(“Scripting.FileSystemObject”)
Set objFolder = fso.GetFolder(curpath)
Set files = objFolder.Files
dim filename, dF, tF, sF, cF1, cF2, cF2t, cF3, cFt3, cF4, cF4t, i0, i1, i2, i3, i4, i5, i6, i7, i, nF, filesys, sYear
Set filesys = CreateObject(“Scripting.FileSystemObject”)
sYear = “09”
For each fileIdx In files
If (fso.GetExtensionName(fileIdx.Path) <> “jpg” AND fso.GetExtensionName(fileIdx.Path) <> “vbs” AND fso.GetExtensionName(fileIdx.Path) <> “ini”) then
i0=0
i1=0
i2=0
i3=0
i4=0
i5=0
i6=0
dF=""
tF=""
sF=""
cF1=""
cF2=""
cF2t=""
cF3=""
cFt3=""
cF4=""
cF4t=""
filename = fso.GetBaseName(fileIdx)
	nF = InStr(filename,".cd")-1
	If nF >0 Then
		filename = Mid(filename,1,nF) & ".cd1"
	End If
	if not filesys.FileExists(CurPath & "\" & filename & ".nfo") Then
		'Create the xml file
		Set xmlDoc = CreateObject("Microsoft.XMLDOM")
		Set objRoot = xmlDoc.createElement("episodedetails")
			xmlDoc.appendChild objRoot
		'Tilte of the episode with the credited actors
		Set objName = xmlDoc.createElement("title")
			i8 = InStr(filename," ")+1
			i0 = InStr(filename," - ") +3			'Look for the starting position of the episode name after the " - "
			i7 = InStr(filename,".cd")				'If there is a .cdX part, check the position of the ".cd"
			if i7 >0 then							'If there is a ".cd"
				i = i7-i0							'The title length is from the start of the title (i0) to the position of the ".cd"
				If i0>1 Then						'if there is a " - "
					tF = Mid(filename,i0,i)			'extract the string from the start to the end of the title length
				Else
					tF = Mid(filename,1,i7)			'if there is no " - " then the title starts at the 1st character
				End If
			Else									'if there is no ".cd"
				If i0>3 Then						'if there is a " - "
					tF = Mid(filename,i0,200)		'extract the string from the start to the end of the title length
				Else								'If there is no " - "
					If i8>1 Then					'If there is a space
						tF = Mid(filename, i8,200)	'Get the title from after the 1st space
					Else
						tF = filename				'then the whole title is the filename
					End If
				End If
			End If
			objName.Text = tF
			objRoot.appendChild objName
		Set objName = xmlDoc.createElement("plot")
			objName.Text = ""
		'If the date of release is valid
		Set objName = xmlDoc.createElement("aired")
			i1 = InStr(filename," ")
			If i1=8 Then
				'For year from 2009
				if Left(filename,2)>sYear Then
					d="20" & Left(filename,2) & "-" & Mid(filename,4,2) & "-" & Mid(filename,6,2)
				End If
			End If
			objName.Text = d
		'Add the series name
		Set objName = xmlDoc.createElement("director")
			i0 = InStr(filename,"-")-1
			i1 = InStr(filename," ")+1
			i2 = i0-i1
			if i2 > 0 Then
				sF = Mid(filename,i1, i2)
			Else
				sF = ""
			End If
			objName.Text = sF
		'First credit if it exists
		Set objName = xmlDoc.createElement("credits")
			i3 = InStr(tF,",")-1
			If i3>0 Then
				cF1 = Mid(tF,1,i3)
			Else
				i4 = InStr(tF,"-")-2
				If i4>0 Then
					cF1 = Mid(tF,1,i4)
				Else
					cF1 = ""
				End If
			End if
			objName.Text = cF1
		'If there is a second credit
		If i3 > 0 Then
				cF2t = Mid (tF, (i3+3),100)
				'Wscript.Echo cF2t
				i5 = InStr(cF2t,",")-1
				If i5>0 Then
					cF2 = Mid(cF2t,1,i5)
				Else
					i4=InStr(cF2t,"-")-2
					If i4>0 Then
						cF2 = Mid(cF2t,1,i4)
					End If
				End If
				objName.Text = cF2
		End If
		'If there is a third credit
		If i5>0 Then
				cF3t = Mid(cF2t,(i5+3),100)
				'Wscript.Echo cF3t
				i6 = InStr(cF3t,",")-1
				If i6>0 Then
					cF3 = Mid(cF3t,1,i6)
				Else
					i4=InStr(cF3t,"-")-2
					If i4>0 Then
						cF3 = Mid(cF3t,1,i4)
					End If
				End If
				objName.Text = cF3
		End If
		'If there is a 4th credit
		if i6>0 Then
				cF4t = Mid(cF3t,(i6+3),100)
				'Wscript.Echo cF4t
				i4=InStr(cF4t,"-")-2
				cF4 = Mid(cF4t,1,i4)
				objName.Text = cF4
		End If
	'if not filesys.FileExists(CurPath & "\" & filename & ".nfo") Then
		set rdr = CreateObject ( "MSXML2.SAXXMLReader")
		set wrt = CreateObject ( "MSXML2.MXXMLWriter")
		Set oStream = CreateObject ( "ADODB.STREAM")
		oStream.Open
		oStream.Charset = "utf-8"
		wrt.indent = True
		wrt.encoding = "utf-8"
		wrt.output = oStream
		Set rdr.contentHandler = WRT
		Set rdr.errorHandler = WRT
		rdr.Parse xmlDoc
		wrt.flush
		oStream.SaveToFile CurPath & "\" & filename & ".nfo", 2
		Set rdr = Nothing
		Set WRT = Nothing
	End If
End If
Next
Wscript.Echo “Done”
[/spoiler]
For Movies:
The script will take the name of the folder as title and if there is a year into paranthesis will also add the year to the xml.
You can edit the script to add your own values to the Studio (nStudio), the Collections (nSet) and the Country (nCountry)
The script will parse the first level of subfolder in which it is adding a movie.nfo in each folder. If you have say a year folder and put the script there, it will scan all the folders there and add a movie.nfo file (if none is already there).
[spoiler]
Dim nStudio, nConuntry, nSet, nYear, i, j, n, nMovie
nStudio = " "
nSet = " "
nConuntry = " "
Sub ShowFolderList(folderspec)
    Dim fs, f, f1, fc, s
    Set fs = CreateObject(“Scripting.FileSystemObject”)
    Set f = fs.GetFolder(folderspec)
    Set fc = f.SubFolders
    For Each f1 in fc
        If not filesys.FileExists(CurPath & “” & f1.name & “” & “movie.nfo”) Then
            i = InStr(f1.name,"(")+1
            j = InStr(f1.name,")")-i
            If i>1 Then
                n = i-3
                nMovie = Mid(f1.name,1,n)
                nYear = Mid(f1.name,i,j)
            Else
                nMovie = f1.name
                nYear = “”
            End If
            Set xmlDoc = CreateObject(“Microsoft.XMLDOM”)
            Set objRoot = xmlDoc.createElement(“movie”)
            Set objName = xmlDoc.createElement(“id”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“title”)
                objName.Text = nMovie
            Set objName = xmlDoc.createElement(“originaltitle”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“releasedate”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“year”)
                objName.Text = nYear
            Set objName = xmlDoc.createElement(“tagline”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“outline”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“plot”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“studio”)
                objName.Text = nStudio
Set objName = xmlDoc.createElement(“mpaa”)
objName.Text = " "
Set objName = xmlDoc.createElement(“rating”)
objName.Text = " "
            Set objName = xmlDoc.createElement(“certification”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“genre”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“director”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“country”)
                objName.Text = nConuntry
            Set objName = xmlDoc.createElement(“set”)
                objName.Text = nSet
            Set objName = xmlDoc.createElement(“credits”)
                objName.Text = " "
            Set objName = xmlDoc.createElement(“runtime”)
                objName.Text = " "
            Set objAct = xmlDoc.createElement(“actor”)
                objRoot.appendChild objAct
            Set objName = xmlDoc.createElement(“name”)
                objName.Text = " "
                objAct.appendChild objName
            Set objName = xmlDoc.createElement(“role”)
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
                objName.Text = " "
            set rdr = CreateObject ( “MSXML2.SAXXMLReader”)
            set wrt = CreateObject ( “MSXML2.MXXMLWriter”)
            Set oStream = CreateObject ( “ADODB.STREAM”)
            oStream.Open
            oStream.Charset = “utf-8”
            wrt.indent = True
            wrt.encoding = “utf-8”
            rdr.Parse xmlDoc
            wrt.flush
            'oStream.SaveToFile CurPath & “” & f1.name & “” & f1.name & “.nfo”, 2
            oStream.SaveToFile CurPath & “” & f1.name & “” & “movie.nfo”, 2
            Set rdr = Nothing
            Set WRT = Nothing
        End If
    Next
End Sub
ShowFolderList CurPath
Wscript.Echo “Done”
[/spoiler]
If you need help on configuring the script to fit your files naming, please feel free to ask.
Nice work. Easy and just what I was looking for.
Can you add      and      and       and
also studio was spelt wrong and doesn't come out properly.
How do you make the movie.nfo rename itself to .nfo?
cheers!
Ok I did replace the movie script with the addition you wanted and the fixed the spelling mistake in Studio (and I was wondering why this didn't work :) lol)
You can only have the name of the folder for the movie as I don't check for the names of the files inside which can be plenty if you have trailers and extras in there as well. So as "movie" is just doing it right I prefered that so the movie file itself can have any name you wish. If, on the other hand you have the same name for the movie as the folder the movie is in you can switch:
oStream.SaveToFile CurPath & "\" & f1.name & "\" & "movie.nfo", 2
for
oStream.SaveToFile CurPath & "\" & f1.name & "\" & f1.name & ".nfo", 2
Out of curiosity why do you need these nodes (id, outline and such and Plex calculate automatically the runtime on movies)? They are not added to Plex as far I know so kinda useless data...
they are used in the agent and on XBMC too and are present in all my nfo files.
thanks for the change!!
how about using Ember Media Management (EMM) to generate your .NFO ?
forum.kodi.tv/showthread.php?tid=191781
the latest version is really stable even if tagged as a BETA version…
Ember Media Manager 1.4.7.2 BETA x86 - 2015-06-11
Regards.
Because this is not for show/movies that have metadata like your christmas movies or familly vacations movies. So the point is to ensure that your self made metadata is recorded somewhere in case of an issue with Plex database or something. This way, using the XBMCnfo agent for Plex and the nfo you create, you always get your own metadata back.
There are also web shows that are not tv shows and you only get the metadata for them on the website you took them from.
Thanks for this, been struggling with a whole bunch of tutorials and your script helped a lot =D> ^:)^
