Creating a Content Security Policy for Plex Web
I’m using some of my nginx reverse proxied home services as a testbed for writing minimal content security policies. The following policy allowed me to play content without triggering any CSP exceptions:
add_header Content-Security-Policy "default-src 'none'; connect-src 'self' https://plex.tv https://*.plex.direct:* wss://*.plex.direct:* wss://pubsub.plex.tv; object-src 'self'; font-src 'self' data:; img-src 'self' https://www.google-analytics.com data: blob:; script-src 'self' 'sha256-WYWOVIbktjxzj8LQgW7AYkuN+xTPTYJhegm6zoIXchY=' https://www.google-analytics.com https://www.gstatic.com; style-src 'self' 'sha256-MZKTI0Eg1N13tshpFaVW65co/LeICXq4hyVx6GWVlK0='; media-src https://*.plex.direct:*; frame-ancestors 'none'" always;
  1. the following code in index.html required a workaround for inline scripts:
    <script>webpackJsonp([3],[]);</script>
  2. the following code in main.js required a workaround for inline styles:
var u, c, d, p = "2.8.3", h = {}, f = t.documentElement, m = "modernizr", v = t.createElement(m), g = v.style, y = ({}.toString,
" -webkit- -moz- -o- -ms- ".split(" ")), b = "Webkit Moz O ms", w = b.split(" "), S = b.toLowerCase().split(" "), P = {}, _ = [], x = _.slice, C = function(e, n, i, r) {
    var a, s, o, l, u = t.createElement("div"), c = t.body, d = c || t.createElement("body");
    if (parseInt(i, 10))
        for (; i--; )
            o = t.createElement("div"),
            o.id = r ? r* : m + (i + 1),
            u.appendChild(o);
    return a = ["­", '<style id="s', m, '">', e, "</style>"].join(""),
    u.id = m,
    (c ? u : d).innerHTML += a,
    d.appendChild(u),
    c || (d.style.background = "",
    d.style.overflow = "hidden",
    l = f.style.overflow,
    f.style.overflow = "hidden",
    f.appendChild(d)),
    s = n(u, e),
    c ? u.parentNode.removeChild(u) : (d.parentNode.removeChild(d),
    f.style.overflow = l),
    !!s
Hopefully those looking to add some modern websec to their services or the Plex devs will find this handy as a starting point. It’d be great if Plex one day set its own CSP headers! More info at OWASP, Mozilla, and content-security-policy.com.
The sha-256 hashes for the script and style above are very likely to break as versions change, and this was only tested against PMS 1.0.3.2461 (Plex Web 2.7.4)
That has been super helpful. Thank you!
Do you by any chance have an update for the CSP code ? I always come back to plex to see what has changed, its surprising to me that there is only one forum post about CSP.
