Custom Autoplay next episode countdown
I tried the FAQ, Duckduckgo and searching this forum. All I’ve found is 4-5 year old threads which didn’t really help me out too much. So I figured I’d make an updated thread in chase anyone else is having the same issue.
Is there any way to change the countdown timer. Now it seems to be +10 seconds.
It would be better if you could set it to like, +3… Or even -10, like halfway through the credits. With an option to set different cutoffs for different series. For example, Rick and Morty always have an after-credits scene. So there it would be best with +3, while most other series have a normal credits before ending, so being able to set like -10 seconds for those would be awsome.
If there is ANY way to already do this, or something similar, it would be great if someone would help me figure it out. I can’t find the settings for autoplay anywhere…
Like, can I just manually change something in a config-file or something?
Thanks for ANY feedback.
Apparently I hadn’t checked all my open tabs, and missed this one:
This takes like 5 seconds.
Everyone interested NEEDS to visit that link, in the top left corner it says VOTE, so… yea, press Vote.
Then leave a comment.
Also, you don’t have to make an account. I was auto logged in with my Google account so it took like 5 seconds…
