I followed the first guide on the original DB (No Backups). When the last step failed, i then was given the other guide about the corrupt DB and using COMMIT at the end of the file to fix it.
Went into the dump.sql file, change the last line to COMMIT, saved…then did the last line from the original guide. The new DB file was of relative size. Fired plex right up and it worked just fine.
