Dashboard not showing anything, agents not updating media
Running on UNRAID 6.7.0
Server Version#: 1.15.6.1079
Hi All,
Thank you for any help yo can provide.
Have Plex running in Docker on Unraid.
The Dashboard is empty, even though both libraries have the option selected.
The media agents aren’t updating any media details.
I’ll attach the logs, and the dashboard screenshot.
Plex Media Server Logs_2019-06-01_19-40-48.zip (3.5 MB)
Broken database
Jun 01, 2019 19:15:07.256 [0x152ca5670700] ERROR - SQLITE3:(nil), 11, database corruption at line 79998 of [bf8c1b2b7a]
Jun 01, 2019 19:15:07.256 [0x152ca5670700] ERROR - SQLITE3:(nil), 11, database corruption at line 68430 of [bf8c1b2b7a]
Jun 01, 2019 19:15:07.256 [0x152ca5670700] ERROR - SQLITE3:(nil), 11, statement aborts at 9: [SELECT (SELECT max(idx) FROM 'main'.'fts4_tag_titles_segdir' WHERE level = ?) + 1] database disk image is malformed
Jun 01, 2019 19:15:07.257 [0x152ca5670700] ERROR - Failed to commit transaction (../Library/MetadataItem.cpp:6079) (tries=1): Cannot commit transaction. database disk image is malformed
Jun 01, 2019 19:15:07.764 [0x152ca5670700] ERROR - SQLITE3:(nil), 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
See: https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
Hi Having same issue. restored database, works for 12-24 hrs then same error, ostarted after last update. How do I roll back?
Unraid is most likely the problem here
Hey all,
Thanks again for your help.
I downgraded to Unraid 6.6.7 and reinstalled Plex, as the database repairs didn’t work, and the backup corrupted itself after about 8 hours.
I’ll let you all know if I have any more issues, its been back online for 24 hours so far.
Cheers
Having the same kind of issue on my UnRaid instance running latest UnRaid (6.7.0) and Plex docker versions.
Some libraries work while others don’t. Seeing the same SQLITE3:(nil), 11, database corruption lines in my log files. Does plex automatically back up the database that I can use to restore from or was that something I should have been better on top of?
Enabled as default for Plex Pass users
See Settings/Scheduled Tasks
Also experiencing database corruption with unRAID 6.7.0 and Plex version 1.15.8.1163 on linuxserver/plex:latest Docker image. Database restore steps didn’t help, restored from an old backup of the /config Docker volume, dashboard showed unexpected error again within 8 hours.
Logs:
Jun 03, 2019 13:25:55.925 [0x1505c93e9700] Error — SQLITE3:(nil), 11, database corruption at line 79051 of [bf8c1b2b7a]
Jun 03, 2019 13:25:55.925 [0x1505c93e9700] Error — SQLITE3:(nil), 11, statement aborts at 7: [select distinct metadata_items.id from metadata_items  where metadata_items.library_section_id in (1) and ((metadata_items.metadata_type=2 or metadata_items.metadata_type=18) and (metad
Jun 03, 2019 13:25:55.926 [0x1505c93e9700] Error — Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
I initially configured this server with unRAID 6.7.0 so I don’t want to downgrade to 6.6.7 (which sounds so far like the only fix) so I’m just going to disable Plex and follow the forums until there is a fix. :pensive:
Since it’s a bug in unraid, I strongly suggest you follow their forum as well :wink:
