Dashboard showing all traffic as local behind SSLH and Nginx
Server Version#: 1.15.5.994
Custom server access URLs: [https://plex.mydomain.com:443,(http://192.168.x.x:32400/)
All services are in docker containers.
SSLH on 192.168.70.239
Openvpn-as on 192.168.70.238
Nginx on 192.168.70.242
Plex on 192.168.70.244
Plex is unable to distinguish between local and remote traffic.
My setup is SSHL forwards ssh traffic to Openvpn-as which then uses portshare to forward the ssh traffic to Nginx.
Plex shows the remote users as 192.168.70.242, which shows in the local lan graphs.
my nginx config is:
#                PLEX                 #
#Must be set in the global scope see: https://forum.nginx.org/read.php?2,152294,152294
#Why this is important especially with Plex as it makes a lot of requests http://vincent.bernat.im/en/blog/2011-ssl-session-reuse-rfc5077.html / https://www.peterbe.com/plog/ssl_session_cache-ab
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
#Upstream to Plex
upstream plex_backend {
    server 192.168.70.244;
    keepalive 32;
server {
	listen 80;
	server_name plex.mydomain.com;
	return 301 https://$host$request_uri;
server {
	#listen 80;
	#Enabling http2 can cause some issues with some devices, see #29 - Disable it if you experience issues
	listen 8443 ssl http2; #http2 can provide a substantial improvement for streaming: https://blog.cloudflare.com/introducing-http2/
	#Faster resolving, improves stapling time. Timeout and nameservers may need to be adjusted for your location Google's have been used here.
	resolver 8.8.4.4 8.8.8.8 valid=300s;
	resolver_timeout 10s;
	send_timeout 100m; #Some players don't reopen a socket and playback stops totally instead of resuming after an extended pause (e.g. Chrome)
	#Reuse ssl sessions, avoids unnecessary handshakes
	#Turning this on will increase performance, but at the cost of security. Read below before making a choice.
	#https://github.com/mozilla/server-side-tls/issues/135
	#https://wiki.mozilla.org/Security/Server_Side_TLS#TLS_tickets_.28RFC_5077.29
	#ssl_session_tickets on;
	ssl_session_tickets off;
	#Plex has A LOT of javascript, xml and html. This helps a lot, but if it causes playback issues with devices turn it off. (Haven't encountered any yet)
	gzip on;
	gzip_vary on;
	gzip_min_length 1000;
	gzip_proxied any;
	gzip_types text/plain text/css text/xml application/xml text/javascript application/x-javascript image/svg+xml;
	gzip_disable "MSIE [1-6]\.";
	#Nginx default client_max_body_size is 1MB, which breaks Camera Upload feature from the phones.
	#Increasing the limit fixes the issue. Anyhow, if 4K videos are expected to be uploaded, the size might need to be increased even more
	client_max_body_size 100M;
	#Forward real ip and host to Plex
	set_real_ip_from 192.168.70.239;
	set_real_ip_from 192.168.70.238;
	real_ip_header X-Forwarded-For;
	real_ip_recursive on;
	proxy_set_header X-Forwarded-By $server_addr;
	proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
	proxy_set_header X-Real-IP $remote_addr;
	proxy_set_header X-Forwarded-Proto $scheme;
	proxy_set_header X-Forwarded-Port $server_port;
	proxy_set_header Host $http_host;
	#Websockets
	proxy_http_version 1.1;
	proxy_set_header Upgrade $http_upgrade;
	proxy_set_header Connection "upgrade";
    #Disables compression between Plex and Nginx, required if using sub_filter below.
	#May also improve loading time by a very marginal amount, as nginx will compress anyway.
    #proxy_set_header Accept-Encoding "";
	#Buffering off send to the client as soon as the data is received from Plex.
	proxy_redirect off;
	proxy_buffering off;
	#Plex
	location / {
		#Example of using sub_filter to alter what Plex displays, this disables Plex News.
		#sub_filter ',news,' ',';
		#sub_filter_once on;
		#sub_filter_types text/xml;
		proxy_pass https://192.168.70.244:32400;
I’m not very familiar with reverse proxies, but isn’t this what they do. They mask traffic as being local so they can work through firewalls.
