Debian package sets service to enable on upgrade
Server Version#: 1.18.1.2019
Instead of honouring the manually set status plexmediaserver.deb sets the service to enable on package upgrade which is unwanted behaviour.
Can you please fix that, thank you!
already corrected in the new packaging which is pending release by Engineering.
(I rewrote it from ground up. It’s adaptive as well as works on both Init and Systemd based systems).
It might undergo one more revision before final release. I’m working on that now.
Thank you.
Still happening btw
New packaging not yet deployed. It will unfortunately continue to happen until Engineering releases it. I keep pushing.
Thanks for the update, appreciated.
