Delete caching object
I'm trying to delete a previously created stroage object with:
Data.Remove("test")
After reading the object again with:
tmp = Data.LoadObject("test")
The data still exists... I'm trying to delete this object in case of an error.
def MainMenu():
  Plugin.AddViewGroup('InfoList', viewMode='InfoList', mediaType='items')
oc = ObjectContainer(title1=TEXT_TITLE, view_group = ‘InfoList’)
token = getToken(“tv”)
Only process if we got a valid token.
errmsg = “”
if token != “”:
result = getChannels(token)
if debug == True: Log("Token to use for api calls: " + token)
if result.has_key('channels'):
  for channel in result['channels']['elements']:
    testchan = channel;
    oc.add(createTVChannelObject(channel))
# Check errormessage if we got a negative reply from the api.
if result.has_key('errors'):
  deleteTokenFromCache("tv")
  errmsg = "<br>[ " + result['errors'][0]['description'] + " ]"
oc.add(PrefsObject(title=TEXT_PREFERENCES, thumb=R(ICON_SETTINGS)))
if len(oc) < 2:
failoc = ObjectContainer(header=“Fehler!”, message=“Zugriff nicht möglich.” + errmsg)
failoc.add(PrefsObject(title=TEXT_PREFERENCES, thumb=R(ICON_SETTINGS)))
return failoc
return oc
Any hints about removing storage objects? Or did I face a bug?
I would suggest using Dict rather than Data.
'''save a token'''
Dict['token'] = token
'''delete the saved token'''
Dict['token'] = None
