Delete watched videos from myPlex queue
I had a lot of old watched videos in myPlex queue that needed to be deleted, so I wrote this script to automate the process.  There is also a script available which will delete all the UN-watched videos from your queue.
https://github.com/caveatsCode/Plex_Queue_Delete_Watched
Simple script to delete all watched videos from your myPlex queue
Requirements:
Python (I use version 2.7, but other versions may work)
lxml (http://lxml.de/)
Usage:
python Plex_Queue_Delete_Watched.py
You will be prompted to enter your myPlex username and password
ALL watched videos will be deleted from your myPlex queue!
OR
Usage:
python Plex_Queue_Delete_Unwatched.py
ALL UN-watched videos will be deleted from your myPlex queue!
Does seem to work for me :(
This is the error shown:
Traceback (most recent call last):
  File "Plex_Queue_Delete_Watched.py", line 17, in
    auth_token = get_auth_token(page)
  File "Plex_Queue_Delete_Watched.py", line 6, in get_auth_token
    tree = etree.HTML(page.text)
AttributeError: 'Response' object has no attribute 'text'
I'm very interested in this script, and also a script whch would clear the entire queue.
You may be using an outdated version of Requests (based on someone who had a similar problem on StackOverflow).
If you are on Python 2.7, try:
pip-2.7 install requests --upgrade
If you aren't able to upgrade requests, it may be sufficient to replace 'page.text' with 'page.content' anywhere it appears in the script.
There is now a 2nd script uploaded to github to delete UN-watched videos from the queue.
I've tried using your suggestion, and then followed up with some debugging.
It seems the login step/post doesn't work for me, and the queue request gets redirected to https://my.plexapp.com/users/sign_in every time.
The scripts have been completely rewritten and are available on github.  The recent massive changes to Plex webpages broke the screen-scraping of the original script.  The rewritten version utilizes the plex API, so it should be more robust.
