Deleting recordings
When I delete a recording the dvr schedule for the recording is still visible, does this not get deleted when you delete the recording?
No, it doesn’t. The recording schedule is separate from the actual recorded file.
does it not update the schedule and delete it then or is the schedule just then left with obsolete information in it
ideally if you cancel a recording or even delete it, it should be removed from the schedule, as what is the point of leaving it in the schedule if is no longer required
