Difficulties recovering malformed database
Server Version#: Latest Stable
Player Version#: Latest Stable
I’ve come up against a malformed (error 11) database. Unfortunately it seems that all of the backups are also malformed.
Using the instructions for a db recovery on this page, I can get through the list and the final instruction to sqlite>> .read db-recover.sqlite seems to complete.
However, I am not seeing the restored database.
Any help?
There is another way to do this:
"Plex SQLite" com.plexapp.plugins.library.db  .dump >   dumpfile.sql
mv com.plexapp.plugins.library.db com.plexapp.plugins.library.db-damaged
"Plex SQLite" com.plexapp.plugins.library.db < dumpfile.sql
You’ll need to use correct path for Plex Sqlite,
then set ownership and perms afterward
Nevermind. Worked it out.
When re-opening sqlite after
“Once the original corrupted database has been moved, start the SQLite shell back up using the same command as before, then run the following command:”
specify the database, i.e.
>  "/usr/lib/plexmediaserver/Plex SQLite" com.plexapp.plugins.library.db
OK, thanks. I’ll remember it for next time.
ATM the database recovery as worked. My bad for not specifying the recovery database file name when re-opening sqlite,
Cheers
