i want to install plex using a docker-compose file, but i can’t find the official image of plex.
I have found one : provided by linuxserver team, but i couldn’t make it work.
Does someone have a good adresse for it ?
It’s for an install on a vm debian, rolling on container ( docker ).
Thanks for help.
All share on fstab are configurated as well, need a good link to find a dockercompose … Thanks a lot
Thank’s i have installed, and it works but have some issue.
Not all my media are founded, i have the right mount in fstab
the right adress in compose file, i can see the files if i’m watching them with winscp.
But Movies are not founded, less than half of my music are added etc etc … :\
The vast majority of difficulties with Plex in Docker revolve around a disconnect between the user the container runs as and the ownership and permissions on the media files.
Actually this was a problem with my ram ( not enought allocated )…
But the docker on my gsm is disconnected. And in the plex webUi on my computer it’s online O.O"
