DreamPlex - ein Plex Client für Enigma2
It have enabled the option in the server menu, if I delete the language option, it is not possible to put more than one letter in the field .
In the tv show by pushing text I can select the brittle language , playing in transcode work with the subtitle, playing in direct local, do not show subtitles, and also no subtitles by pushing twice the yellow button …
Wondering what am I doing wrong
Sent from my iPad using tapatalk
so there was a dependency problem installing directly the update ... installing the ipk manually worked, but stil do not get the subtitle convertion done :-(
In the tv show by pushing text I can select the brittle language , playing in transcode work with the subtitle, playing in direct local, do not show subtitles, and also no subtitles by pushing twice the yellow button ....
if there is no option with twice yellow there are only two possibilities. first of all the subs streams is not active yet. subs streams appears only when the first sub text has to be displayed. this could be very late at all in movie ;-)
second option is, that the box is not able to read the subtitle file. there are a lot of standards and engima is not known as the best plattform for different subs standards. external srt file works most of the time. but sometimes there might be something we the encoding.
to be clear if it is dreamplex or something else causing the error do the following.
start the movie over the internal media player of your box. before that rename your srt and put it into the same directory as the movie is. if everything is fine and the subs are shown with twice yellow it is dreamplex. if not than it is the image itself, the sub file, or somehting complety different like permission for the files.
good hunting :-)
if I put the SRT file in the directory, I can read it with yelow yelow ....
that is what I'm currently doing .... a linux script which is automatically copying all my eng.srt into srt so that I can read the movie with subtitle.
But with this solution I cannot choose the language.
But with dreamplex I'm also not seeing an srt file beeing created ? shall I ?
this is not needed.
just select the language you want. no need that the plex server knows that there will be a new srt file with no language ending.
because dreamplex searches for it own for the srt and copies it just in time before movie starts. after the movie stops the temp srt is deleted again.
I was doing this as a workaround .... but this is exactly what I'm doing, selecting the file with text ..... starting the movie but no srt created .... and nothing to be seen in yellow yellow nor in the folder while playing the movie.
Will perhaps try a clean reinstall
just do what you did again and send me the dreamplex logfile. i can have look. maybe there is a bug. we will catch it down for sure :-)
Changelog for 2.1.0-beta45:
- default FHD skin tweaks
- some refactoring for consitent code usage
Downloads
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta45_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta45_all.ipk/download
Please find attached the log file
Changelog for 2.1.0-beta46:
- bugfix in player
- debug tweaks
Downloads
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta46_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta46_all.ipk/download
i think i found the error. wait for beta 47 :-)
cool .....
Changelog for 2.1.0-beta47:
- subtitle bugfix if there is no index tag in stream
- removed unneeded restore of livetv when leaving view
- improved backdrop m1v support for shows
- bugfix in FHD skin to avoid gs = unsupported font tag in eList
Downloads
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta47_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta47_all.ipk/download
Downloads
Subtitles still doesn't work ....
you have to write "en" for language in settings. not only "e".
the GUI doesn't allow to add a letter .... I accidently delete one, and now cannot add. can you tell me where the config file is, so that I can perhaps change it directly ?
i will push a new beta soon where this behavior is fixed :-)
Changelog for 2.1.0-beta48:
- bugfix for FHD/HD handling, params are now correct
- bugfix for subtitle settings
Downloads
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta48_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta48_all.ipk/download
I just uptated to the last beta. Thanks a lot man for your great work to make our devices a full media player/reciever.
Changelog for 2.1.0-beta49:
- bugfix for FHD/HD handling, params are not correct
- updadte danish language -> thx to victordk
Downloads
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta49_all.deb/download
https://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta49_all.ipk/download
