DreamPlex - ein Plex Client für Enigma2
Any progress with channels & music yet? This could really be a great client - keep up the good work!
HI, guys.
I need help. Please.
I instaled the plugin in my azbox premium. It´s works too. I can see all title movie and series, but I can´t to see.
When I choice one serie.  I can listening the song of series but I can´t see too. What is happing?
I could need some help.
I have installed the latest version of Dreamplex and installation went fine. I can see the plugin from enigma but when I start the plugin the resolution becomes the wrong one. This results in that I only see 1/4 of the screen.
very annoying since I can't configure the plugin or use it.
Is there any configuration file where I can configure the resolution of the plugin?
My dreambox is configured to use 720p and the plugin seems to use 480 or similar....
thanks
i'm using this on a vu duo , trying to remote stream but i got a 401 error any ideas all login is correct and it shows in myplex as a dm500?
Hi
i have installed Dreamplex 1.05 in a Azbox Mini Me running OpenSPA2.02/OpenPLi3.0  OE2.0  install goes OK
i can login to my remote server using myplex account, but i can´t get movies to play
here is output log from dreamplex
14:25:05.0437653  >>> I < === BOX INFORMATION ===
14:25:05.0439102  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
14:25:05.0440963  >>> I < === VERSION ===
14:25:05.0442189  >>> I < current Version : 1.05
14:25:05.0443629  >>> I < === GLOBAL SETTINGS ===
14:25:05.0445002  >>> I < debugMode: 0
14:25:05.0446455  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
14:25:05.0447906  >>> I < logfolderpath: /tmp/
14:25:05.0449368  >>> I < mediafolderpath: /hdd/dreamplex/media/
14:25:05.0450816  >>> I < playerTempPath: /hdd/dreamplex/
14:25:05.0452208  >>> I < showInMainMenu: True
14:25:05.0453739  >>> I < showFilter: True
14:25:05.0455131  >>> I < autoLanguage: False
14:25:05.0456509  >>> I < stopLiveTvOnStartup: False
14:25:05.0457882  >>> I < playTheme: False
14:25:05.0459261  >>> I < fastScroll: False
14:25:05.0460640  >>> I < summerizeSections: False
14:25:05.0625175  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex/'
14:25:05.0630931  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex'
14:25:05.0635169  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex'
14:25:05.0637379  >>> I < adding fonts
14:25:05.0677562  >>> I < added => Modern
14:25:05.0719047  >>> I < added => Named
14:25:05.0760129  >>> I < added => Saint
14:58:41.0742597  >>> I < === BOX INFORMATION ===
14:58:41.0744427  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
14:58:41.0746257  >>> I < === VERSION ===
14:58:41.0747471  >>> I < current Version : 1.05
14:58:41.0748960  >>> I < === GLOBAL SETTINGS ===
14:58:41.0750338  >>> I < debugMode: 0
14:58:41.0751799  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
14:58:41.0753654  >>> I < logfolderpath: /tmp/
14:58:41.0755167  >>> I < mediafolderpath: /hdd/dreamplex/media/
14:58:41.0756723  >>> I < playerTempPath: /hdd/dreamplex/
14:58:41.0758108  >>> I < showInMainMenu: True
14:58:41.0759500  >>> I < showFilter: True
14:58:41.0760893  >>> I < autoLanguage: False
14:58:41.0762371  >>> I < stopLiveTvOnStartup: False
14:58:41.0764292  >>> I < playTheme: False
14:58:41.0765658  >>> I < fastScroll: False
14:58:41.0767318  >>> I < summerizeSections: False
14:58:41.0948833  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex/'
14:58:41.0955041  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex'
14:58:41.0959753  >>> E < Exception(): [Errno 2] No such file or directory: '/hdd/dreamplex'
14:58:41.0962060  >>> I < adding fonts
14:58:41.0997235  >>> I < added => Modern
14:58:42.0040441  >>> I < added => Named
14:58:42.0084957  >>> I < added => Saint
seems to me that you do not have the directory /hdd/dreamplex
if you do not have a hdd you can alter the path in the config to somewhere else.
greets
hi don
i have added a 8GB usb pendrive as HDD and i have mounted it partioned it as FAT32
it seems to be working now...
is it best if i make a partision EXT3?
hi
ext3 is better but not necessary if it works with fat32.
dreamplex is storing pictures there to speed up a bit :wink:
greets
Hi Don
I just added there: http://www.i-have-a-dreambox.com/wbb2/thread.php?threadid=166940&threadview=0&hilight=&hilightuser=0&page=46 a log with "problems" on direct play and new server.
Did you already saw that?
Regards
Bender
hi
dreamplex is storing pictures there to speed up a bit ;-)
greets
Hi Don
thanks i have formatted it with ext3 and have settup particioned as hdd now i get past the error but still not playing
i have checked the manufacturer of my stb azbox minime and on their specs it states nearly all support for most video encoders out there
but still mine is not playing, for instance Mkv i know it support so most of my movies i play on my dm800 mkv here i cannot playthem, it keeps exitiing the movie returning to the movies list and does not load the channel but some how now on the log is not showing any error that i can notice
so i cannot still play the videos on mkv or divx or ts or vob.. strange i am using OpenSPA 2.01 based on the Openpli3.0 version
i have pretty much selected all the settings available on the dreamplex plugin
tried , streamed, tried transcoded on lower resolution, local... but it still wont work on any of them...
here is log attached
16:46:27.0543353  >>> I < === BOX INFORMATION ===
16:46:27.0544737  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
16:46:27.0546561  >>> I < === VERSION ===
16:46:27.0548384  >>> I < current Version : 1.05
16:46:27.0549536  >>> I < === GLOBAL SETTINGS ===
16:46:27.0550872  >>> I < debugMode: 0
16:46:27.0552305  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
16:46:27.0553710  >>> I < logfolderpath: /tmp/
16:46:27.0555137  >>> I < mediafolderpath: /hdd/dreamplex/media/
16:46:27.0556561  >>> I < playerTempPath: /hdd/dreamplex/
16:46:27.0558028  >>> I < showInMainMenu: True
16:46:27.0559370  >>> I < showFilter: True
16:46:27.0560728  >>> I < autoLanguage: False
16:46:27.0562088  >>> I < stopLiveTvOnStartup: True
16:46:27.0563439  >>> I < playTheme: True
16:46:27.0564786  >>> I < fastScroll: True
16:46:27.0566139  >>> I < summerizeSections: False
16:46:27.0735116  >>> I < adding fonts
16:46:27.0784567  >>> I < added => Modern
16:46:27.0836258  >>> I < added => Named
16:46:27.0889859  >>> I < added => Saint
16:47:37.0598573  >>> I < === BOX INFORMATION ===
16:47:37.0600296  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
16:47:37.0602655  >>> I < === VERSION ===
16:47:37.0604261  >>> I < current Version : 1.05
16:47:37.0605486  >>> I < === GLOBAL SETTINGS ===
16:47:37.0606846  >>> I < debugMode: 0
16:47:37.0608614  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
16:47:37.0611311  >>> I < logfolderpath: /tmp/
16:47:37.0614494  >>> I < mediafolderpath: /hdd/dreamplex/media/
16:47:37.0618680  >>> I < playerTempPath: /hdd/dreamplex/
16:47:37.0621485  >>> I < showInMainMenu: True
16:47:37.0624342  >>> I < showFilter: True
16:47:37.0627120  >>> I < autoLanguage: False
16:47:37.0629713  >>> I < stopLiveTvOnStartup: True
16:47:37.0632192  >>> I < playTheme: True
16:47:37.0635562  >>> I < fastScroll: True
16:47:37.0638971  >>> I < summerizeSections: False
16:47:37.0878349  >>> I < adding fonts
16:47:37.0927752  >>> I < added => Modern
16:47:37.0981879  >>> I < added => Named
16:47:38.0035468  >>> I < added => Saint
16:47:40.0260481  >>> I < Plexserver State: Online
16:47:40.0263368  >>> I < running on sys.version_info(major=2, minor=7, micro=2, releaselevel='final', serial=0)
16:47:40.0280023  >>> I < using this serverName: PlexServer
16:47:40.0281315  >>> I < using this connectionType: 2
16:47:40.0283277  >>> I < myplexUrl: my.plexapp.com
16:47:40.0284650  >>> I < myplex_username: x-te**********
16:47:40.0286062  >>> I < myplex_password: benfi******
16:47:40.0288591  >>> I < myplex_token: HQhQ4YqKxmXWL6******
16:47:40.0290332  >>> I < DreamPlex -> Adding myplex as a server location
16:47:40.0291859  >>> I < DreamPlex -> serverList is [{'uuid': None, 'serverName': 'MYPLEX', 'token': None, 'role': 'master', 'address': 'my.plex.app', 'discovery': 'myplex'}]
16:47:40.0309772  >>> I < Using list of 1 servers: [{'uuid': None, 'serverName': 'MYPLEX', 'token': None, 'role': 'master', 'address': 'my.plex.app', 'discovery': 'myplex'}]
16:47:57.0495863  >>> I < p_url: http://my url ip fromserver:32400/library/sections/1
16:47:57.0497907  >>> I < p_mode: movie
16:47:57.0499231  >>> I < p_final: notSet
16:47:59.0292978  >>> I < viewName: ('Short List', 'DP_ViewList', 'DPS_ViewList')
16:48:30.0242242  >>> I < viewMode -> play
16:48:30.0247690  >>> I < Gather media stream info
16:48:30.0248988  >>> I < server: myurl ip from server:32400
16:48:31.0219911  >>> I < Stream selection is set OFF
16:48:31.0227541  >>> I < physical file location: /media/Filmes/Assault.on.Wall.Street.2013.720p.WEB-DL.H264-HDB [PublicHD]/Assault.on.Wall.Street.2013.720p.WEB-DL.DD5.1.H.264.mkv
16:48:31.0228841  >>> I < looks like a unix file
16:48:31.0230147  >>> I < Selecting stream
16:48:31.0232849  >>> I < url: http://my url ip from server:32400/library/parts/7/file.mkv
16:48:31.0234185  >>> I < We are playing a stream
16:48:31.0235528  >>> I < Resume has been set to 0
16:48:31.0237460  >>> I < No streams to process.
16:48:31.0238775  >>> I < All subs disabled
16:48:31.0241275  >>> I < PLAYURL => http://my url ip from server:32400/library/parts/7/file.mkv
16:48:31.0242578  >>> I < RESUME => 0
16:48:31.0244453  >>> I < resumeStamp: 0
16:48:31.0251529  >>> I < Checking for usable gstreamer service (builtin)...
16:48:31.0254136  >>> I < we are able to stream over 4097
16:48:31.0255482  >>> I < self.ENIGMA_SERVICE_ID = 4097
16:48:32.0518740  >>> I < We have selected media at http://my ip from server:32400/library/parts/7/file.mkv
16:48:42.0649303  >>> I < played time is 0 secs of 1739703800148 @ 0%
16:48:42.0650697  >>> I < Less that 30 seconds, will not set resume
hi don
i have made some more testing with different versions of dreamplex on the Azbox minime
and i have come to a conclusion that might be something related with gstreamer??
using azplayer i can play remote from a NFS server share  and hdd replacement conection and play all movie formats.
but when i try to play via Dreamplex any version from 1.03 up to 1.05  it simple doesnt work, it loads covers data info mas does not play the movies and ends up exiting the movie loading
i have tried several config , from stream, to direct local,  to transcoded on various speeds from 1.5mbs upwards and none seem to work
have u got any ideas where the problem might be here is a debug log
00:51:45.0422598  >>> I < Stream selection is set OFF
00:51:45.0424800  >>> D < streamData = {'videoData': {'viewOffset': '17060', 'title': 'Sem dor, sem ganho', 'tagline': '', 'contentRating': '', 'summary': u'Fl\xf3rida. Daniel Lugo (Mark Wahlberg) \xe9 um fisiculturista que sonha com o chamado "sonho americano", no qual tem dinheiro \xe0 vontade para levar a vida como quiser. Para alcan\xe7ar este objetivo ele conta com a ajuda de um colega, Adrian Doorbal (Anthony Mackie), e do ex-presidi\xe1rio Paul Doyle (Dwayne Johnson). Juntos eles planejam o sequestro e a extors\xe3o de um conhecido criminoso local, Victor Kershaw (Tony Shalhoub). S\xf3 que, ao realizarem o golpe, eles n\xe3o contavam com as inevit\xe1veis consequ\xeancias que ele traria.', 'studio': 'Paramount Pictures', 'year': '2013', 'duration': '7776810'}, 'subtitle': {}, 'external': {}, 'contents': 'type', 'audio': {}, 'partsCount': 1, 'mediaData': {'videoFrameRate': '', 'videoCodec': '', 'videoResolution': '', 'audioCodec': ''}, 'audioCount': 0, 'parts': [('/library/parts/249/file.mp4', '/media/Filmes/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF.mp4')], 'audioOffset': -1, 'subCount': 0, 'subOffset': -1}
00:51:45.0426952  >>> D < partsCount: 1
00:51:45.0428483  >>> D < parts: [('/library/parts/249/file.mp4', '/media/Filmes/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF.mp4')]
00:51:45.0429902  >>> D < server: IPIPIPIPIPIPI:32400
00:51:45.0432224  >>> I < physical file location: /media/Filmes/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF/Sem Dor, Sem Ganho (2013) 720p Dublado - AndreTPF.mp4
00:51:45.0433547  >>> I < looks like a unix file
00:51:45.0434887  >>> I < Selecting stream
00:51:45.0436688  >>> I < We have selected media at http://IPIPIPIPIPIPI:32400/library/parts/249/file.mp4
00:51:45.0438466  >>> I < url: http://IPIPIPIPIPI:32400/library/parts/249/file.mp4
00:51:45.0439873  >>> I < We are playing a stream
00:51:45.0441272  >>> I < Resume has been set to 17060
00:51:45.0443050  >>> I < No streams to process.
00:51:45.0444396  >>> I < All subs disabled
00:51:45.0447022  >>> I < PLAYURL => http://IPIPIPIPIP:32400/library/parts/249/file.mp4
00:51:45.0448374  >>> I < RESUME => 17060
00:51:45.0450456  >>> I < resumeStamp: 17060
00:51:45.0883516  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:45.0886403  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:45.0881300  >>> D < selection: ('Sem dor, sem ganho', {'viewOffset': 17060, 'viewCount': 0, 'rating': '6.4000000953674299', 'title': 'Sem dor, sem ganho', 'tagline': '', 'writer': 'Pete Collins / Christopher Markus', 'ratingKey': '266', 'server': 'IPIPIPIPIPIPIPIPI:32400', 'summary': u'Fl\xf3rida. Daniel Lugo (Mark Wahlberg) \xe9 um fisiculturista que sonha com o chamado "sonho americano", no qual tem dinheiro \xe0 vontade para levar a vida como quiser. Para alcan\xe7ar este objetivo ele conta com a ajuda de um colega, Adrian Doorbal (Anthony Mackie), e do ex-presidi\xe1rio Paul Doyle (Dwayne Johnson). Juntos eles planejam o sequestro e a extors\xe3o de um conhecido criminoso local, Victor Kershaw (Tony Shalhoub). S\xf3 que, ao realizarem o golpe, eles n\xe3o contavam com as inevit\xe1veis consequ\xeancias que ele traria.', 'director': 'Michael Bay', 'cast': ['Mark Wahlberg', 'Rebel Wilson', 'Dwayne Johnson'], 'viewMode': 'play', 'studio': 'Paramount Pictures', 'year': '2013', 'genre': u'A\xe7\xe3o', 'runtime': '2:09:36', 'viewState': 'unseen'}, {'fanart_image': 'http://IPIPIPIPIP:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2Flibrary%2Fmetadata%2F266%2Fart%2F1376768114&width=560&height=315&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W' 'videoCodec': 'h264', 'thumb': 'http://IPIPIPIPIP:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2Flibrary%2Fmetadata%2F266%2Fthumb%2F1376768114&width=195&height=268&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W' 'videoResolution': '720', 'ratingKey': '266', 'contentRating': '', 'token': 'HQhQ4YqKxmXWL61eFj3W', 'key': '/library/metadata/266', 'aspectRatio': '2.35', 'type': 'Video', 'audioCodec': 'aac'}, {'unwatchURL': 'http://IPIPIPIPIPIP:32400/:/unscrobble?key=266&identifier=com.plexapp.plugins.library&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W' 'libraryRefreshURL': 'http://IPIPIPIPIP:32400/library/sections/1/refresh?X-Plex-Token=HQhQ4YqKxmXWL61eFj3W' 'watchedURL': 'http://IPIPIPIPIP:32400/:/scrobble?key=266&identifier=com.plexapp.plugins.library&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W' 'deleteURL': 'http://IPIPIPIPIP:32400/library/metadata/266&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W'}, <enigma.gPixmapPtr; proxy of *' at 0x140fea0> >, 'http://IPIPIPIP:32400/library/sections/1/all&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W')
00:51:45.0888592  >>> D < resetGuiElements: False
00:51:45.0894747  >>> D < showMedia: False
00:51:45.0896612  >>> D < is playable content
00:51:45.0897980  >>> D < is movie
00:51:45.0899486  >>> D < ajahahaj: 266
00:51:45.0901447  >>> D < seenUrl: http://IPIPIPIPIPIPIP:32400/:/scrobble?key=266&identifier=com.plexapp.plugins.library&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W
00:51:45.0902828  >>> D < unseenUrl: http://IPIPIPIPIPIP:32400/:/unscrobble?key=266&identifier=com.plexapp.plugins.library&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W
00:51:45.0904215  >>> D < deleteUrl: http://IPIPIPIPIP:32400/library/metadata/266&X-Plex-Token=HQhQ4YqKxmXWL61eFj3W
00:51:45.0905597  >>> D < refreshUrl: http://IPIPIPIPIP:32400/library/sections/1/refresh?X-Plex-Token=HQhQ4YqKxmXWL61eFj3W
00:51:45.0923040  >>> D < target: /hdd/dreamplex/media/plexserver_266_poster.jpg
00:51:46.0100748  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0103555  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0320691  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0323494  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0540681  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0543488  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0760734  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0763557  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0980687  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:46.0983502  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0200720  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0203539  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0420739  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0423554  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0640709  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0643509  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0860697  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:47.0863501  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0080702  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0083535  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0300706  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0303538  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0520691  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0523501  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0740755  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0743551  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0960702  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:48.0963512  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0180711  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0183523  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0400715  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0403519  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0620727  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0623533  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0840724  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:49.0843530  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0060702  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0063569  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0280693  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0283494  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0500688  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0503496  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0720753  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0723570  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0940687  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:50.0943508  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0161217  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0164052  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0168380  >>> I < Checking for usable gstreamer service (builtin)...
00:51:51.0171066  >>> I < we are able to stream over 4097
00:51:51.0172522  >>> I < self.ENIGMA_SERVICE_ID = 4097
00:51:51.0245901  >>> I < rLen: [-1, 1980028672]
00:51:51.0247366  >>> I < rPos: [-1, 0]
00:51:51.0380927  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0383760  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0600751  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0603576  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0820718  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:51.0823545  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0040736  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0043557  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0261389  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0264210  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0480735  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0483540  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0700732  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0703539  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0920712  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:52.0923514  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0140720  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0143531  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0360724  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0363526  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0580731  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0583580  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0800753  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:53.0803562  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0020729  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0023538  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0240725  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0243545  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0460961  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0463773  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0680729  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0683529  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0900737  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:54.0903539  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0120691  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0123499  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0340741  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0343545  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0560854  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0563664  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0780684  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:55.0783481  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0000714  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0003512  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0220693  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0223494  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0440716  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0443519  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0660748  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0663531  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0880723  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:56.0883538  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0100726  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0103544  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0321493  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0324940  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0546588  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0551537  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0760722  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0770711  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0980713  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:57.0990794  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0200695  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0210710  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0420742  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0430687  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0640688  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0650706  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0860714  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:58.0870696  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0080691  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0090794  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0300708  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0310708  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0520750  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0530707  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0740698  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0750702  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0960738  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:51:59.0970699  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0180700  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0190794  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0400732  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0410850  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0620879  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0631437  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0840723  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:00.0850745  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0060695  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0070705  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0280708  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0290795  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0427510  >>> I < played time is 0 secs of 22000 @ 0%
00:52:01.0429153  >>> I < Less that 30 seconds, will not set resume
00:52:01.0432100  >>> D < g_myplex_accessToken: HQhQ4YqKxmXWL61eFj3W
00:52:01.0433903  >>> D < token: HQhQ4YqKxmXWL61eFj3W
00:52:01.0435670  >>> D < server: IPIPIPIPIPIPIP:32400
00:52:01.0437021  >>> D < urlPath: /video/:/transcode/segmented/stop?session=298fe00b-66b8-448f-9519-5aa481893789
00:52:01.0438445  >>> D < header: {'X-Plex-Token': 'HQhQ4YqKxmXWL61eFj3W'}
00:52:01.0500727  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0510701  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0720696  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0730694  >>> W < exception: 'DP_Player' object has no attribute 'session'
00:52:01.0888695  >>> W < got evEOF
00:52:01.0890438  >>> W < Error:
Hi don
And here is another log just made in log debug normal
01:29:42.0410547  >>> I < === BOX INFORMATION ===
01:29:42.0412538  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
01:29:42.0415095  >>> I < === VERSION ===
01:29:42.0416486  >>> I < current Version : 1.03
01:29:42.0417732  >>> I < === GLOBAL SETTINGS ===
01:29:42.0419391  >>> I < debugMode: 1
01:29:42.0420938  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
01:29:42.0422508  >>> I < logfolderpath: /tmp/
01:29:42.0424039  >>> I < mediafolderpath: /hdd/dreamplex/media/
01:29:42.0425564  >>> I < playerTempPath: /media/hdd/dreamplex/
01:29:42.0427026  >>> I < showInMainMenu: True
01:29:42.0428464  >>> I < showFilter: True
01:29:42.0429982  >>> I < autoLanguage: False
01:29:42.0431440  >>> I < stopLiveTvOnStartup: True
01:29:42.0432882  >>> I < useBufferControl: True
01:29:42.0434325  >>> I < setSeekOnStart: True
01:29:42.0435787  >>> I < playTheme: False
01:29:42.0437232  >>> I < fastScroll: True
01:29:42.0438709  >>> I < summerizeSections: False
01:29:42.0629685  >>> I < adding fonts
01:29:42.0658450  >>> I < added => mayatypeuitvg.ttf
01:29:42.0692219  >>> I < added => goodtime.ttf
01:29:42.0694365  >>> I < added => saint.ttf
01:30:22.0013749  >>> I < === BOX INFORMATION ===
01:30:22.0015599  >>> I < Box: ('Unknown', 'minime', 'sh4', 'duckbox')
01:30:22.0017856  >>> I < === VERSION ===
01:30:22.0019261  >>> I < current Version : 1.03
01:30:22.0020768  >>> I < === GLOBAL SETTINGS ===
01:30:22.0022195  >>> I < debugMode: 1
01:30:22.0024000  >>> I < pluginfolderpath: /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/
01:30:22.0025521  >>> I < logfolderpath: /tmp/
01:30:22.0027579  >>> I < mediafolderpath: /hdd/dreamplex/media/
01:30:22.0029145  >>> I < playerTempPath: /media/hdd/dreamplex/
01:30:22.0030999  >>> I < showInMainMenu: True
01:30:22.0032842  >>> I < showFilter: True
01:30:22.0034322  >>> I < autoLanguage: False
01:30:22.0036044  >>> I < stopLiveTvOnStartup: True
01:30:22.0037505  >>> I < useBufferControl: True
01:30:22.0039591  >>> I < setSeekOnStart: True
01:30:22.0041041  >>> I < playTheme: False
01:30:22.0042792  >>> I < fastScroll: True
01:30:22.0044228  >>> I < summerizeSections: False
01:30:22.0265306  >>> I < adding fonts
01:30:22.0267904  >>> I < added => mayatypeuitvg.ttf
01:30:22.0270492  >>> I < added => goodtime.ttf
01:30:22.0273168  >>> I < added => saint.ttf
01:30:37.0310250  >>> I < Plexserver State: Online
01:30:37.0313383  >>> I < running on (2, 6, 6, 'final', 0)
01:30:37.0317313  >>> I < using transcode: true
01:30:37.0318704  >>> I < using this transcoding quality: 3
01:30:37.0320077  >>> I < using this segments size: 5
01:30:37.0322047  >>> I < using this serverName: PlexServer
01:30:37.0323394  >>> I < using this connectionType: 2
01:30:37.0325489  >>> I < myplexUrl: my.plexapp.com
01:30:37.0326921  >>> I < myplex_username: x-te**********
01:30:37.0328347  >>> I < myplex_password: benfi******
01:30:37.0330898  >>> I < myplex_token: HQhQ4YqKxmXWL6******
01:30:37.0332709  >>> I < DreamPlex -> Adding myplex as a server location
01:30:37.0334304  >>> I < DreamPlex -> serverList is [{'uuid': None, 'serverName': 'MYPLEX', 'token': None, 'role': 'master', 'address': 'my.plex.app', 'discovery': 'myplex'}]
01:30:37.0340707  >>> I < Using list of 1 servers: [{'uuid': None, 'serverName': 'MYPLEX', 'token': None, 'role': 'master', 'address': 'my.plex.app', 'discovery': 'myplex'}]
01:30:40.0401898  >>> I < excluded unsupported section: Musica
01:30:56.0623903  >>> I < p_url: http://68.168.115.106:32400/library/sections/1
01:30:56.0625252  >>> I < p_mode: movie
01:30:56.0626581  >>> I < p_final: notSet
01:30:58.0646333  >>> I < viewName: ('List', 'DP_ListView', 'DPS_ListView')
01:31:17.0264897  >>> I < viewMode -> play
01:31:17.0269156  >>> I < We are set to Transcode, overriding stream selection
01:31:17.0270506  >>> I < Transcode quality is 3
01:31:17.0273163  >>> I < Plex Client Capability = protocols%3Dhttp-video%3B%3BvideoDecoders%3Dmpeg2video%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmpeg4%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmpeg1video%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmp4%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Ch264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%3BaudioDecoders%3Dmp3%2Caac
01:31:17.0276322  >>> I < Gather media stream info
01:31:17.0277649  >>> I < server: 68.168.115.106:32400
01:31:17.0735123  >>> I < Stream selection is set OFF
01:31:17.0740878  >>> I < physical file location: /media/Filmes/2.Dias.Em.Nova.York.BDRip.XviD.Dual.Audio-3LT0N/2.Dias.Em.Nova.York.BDRip.XviD.Dual.Audio-3LT0N.avi
01:31:17.0742235  >>> I < looks like a unix file
01:31:17.0743573  >>> I < Selecting stream
01:31:17.0745340  >>> I < We have selected media at http://68.168.115.106:32400/library/parts/256/file.avi
01:31:17.0747101  >>> I < url: http://68.168.115.106:32400/library/parts/256/file.avi
01:31:17.0748465  >>> I < We are playing a stream
01:31:17.0749853  >>> I < We will be transcoding the stream
01:31:17.0752580  >>> I < Using preferred transcoding server: 68.168.115.106:32400
01:31:17.0753994  >>> I < Setting up HTTP Stream
01:31:17.0758303  >>> I < Encoded HTTP Stream URL: http://68.168.115.106:32400/video/:/transcode/segmented/start.m3u8?identifier=com.plexapp.plugins.library&ratingKey=273&offset=0&quality=3&session=f58e0486-df6f-4cde-bf2d-068ba21310d6&secondsPerSegment=5&url=http%3A%2F%2Flocalhost%3A32400%2Flibrary%2Fparts%2F256%2Ffile.avi&3g=0&httpCookies=&userAgent=&X-Plex-Client-Capabilities=protocols%3Dhttp-video%3B%3BvideoDecoders%3Dmpeg2video%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmpeg4%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmpeg1video%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Cmp4%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%2Ch264%7Bprofile%3Ahigh%26resolution%3A1080%26level%3A51%7D%3BaudioDecoders%3Dmp3%2Caac&X-Plex-Access-Key=KQMIY6GATPC63AIMC4R2&X-Plex-Access-Time=1377300677&X-Plex-Access-Code=ZI%2F64Ygekde%2FwCLEhkRgoGWss2RNKW86Tl8JL8vKSyc%3D
01:31:18.0228542  >>> I < Got: http://68.168.115.106:32400/video/:/transcode/segmented/session/f58e0486-df6f-4cde-bf2d-068ba21310d6/3/index.m3u8
01:31:18.0230499  >>> I < Transcoded media location URL http://68.168.115.106:32400/video/:/transcode/segmented/session/f58e0486-df6f-4cde-bf2d-068ba21310d6/3/index.m3u8
01:31:18.0232605  >>> I < Resume has been set to 0
01:31:18.0234819  >>> I < PLAYURL => http://68.168.115.106:32400/video/:/transcode/segmented/session/f58e0486-df6f-4cde-bf2d-068ba21310d6/3/index.m3u8
01:31:18.0236190  >>> I < RESUME => 0
01:31:18.0238125  >>> I < resumeStamp: 0
01:31:18.0245141  >>> I < Checking for usable gstreamer service (builtin)...
01:31:18.0247823  >>> I < we are able to stream over 4097
01:31:18.0249363  >>> I < self.ENIGMA_SERVICE_ID = 4097
01:31:18.0506047  >>> I < rLen: [-1, 1973876480]
01:31:18.0507496  >>> I < rPos: [-1, 0]
01:31:28.0788894  >>> I < played time is 0 secs of 21931 @ 0%
01:31:28.0790317  >>> I < Less that 30 seconds, will not set resume
01:31:29.0271947  >>> W < got evEOF
01:31:29.0273507  >>> W < Error:
Hi!
I'm trying to run a plex media server on my PC, but when i try to connect with dreamplex i get a greenscreen with the following:
15:01:51.0353527  >>> I < HTTP response error: 403 Forbidden
Am i missing out on something simple? The media server on my pc have permission to go through the firewall..
are you using openpli and did you install from their repository?
i pushed a new 1.6beta2 in the ihad forum. or just use my original 1.5. this should work as well
Hi don
i am using OpenAzMod OpenPli2.1 version
where can i get thee 1.6.2 beta version so i can install?  is there a IPK install version so i can install via tmp folder?
just to remind  i am usinga Azbox mini me
Hi!
Some more information from the logfile:
15:01:49.0070810  >>> I < Using list of 1 servers: [{'uuid': None, 'serverName': 'PlexServer', 'token': None, 'role': 'master', 'address': '192.168.1.84:32400', 'discovery': 'local'}]
15:01:51.0287768  >>> I < p_url: http://192.168.1.84:32400/library/sections/1
15:01:51.0292020  >>> I < p_mode: movie
15:01:51.0297759  >>> I < p_final: notSet
If i put the p_url into a browser on a PC i get no 403 (a xml document is showing). I also tried to put the dreambox IP in the network advanced settings box with clients who doesn't have to authenticate but no luck.
Any hints?
Edit:
The latest beta (b6) solved my issues. Yay!
Not expecting a reply to this one either...Is there any progress with this client? Channels, music etc? Currently dreamplex crashes my vu+ solo2 on the latest vix image but it was sort of working before.
i'm using on a dreambox 800hd and streaming mkv+h264+aac5.1.
output from the box is only pcm 2 channel.
i"m using oozoon oe2 + gp3 for the image.
any ideas on what i am missing
does someone know which profile dreamplex uses? i need to transcode the aac 5.1 to ac3 as my amplifier doesn't support it. or, more preferably transcode the audio on the dreambox
Check this out: Version 1.07 or 1.07a-beta.1
https://github.com/DonDavici/DreamPlex/releases
I have no problems/crashes with the 1.07 version.
