DreamPlex - ein Plex Client für Enigma2
try to turn off
showInfobarOnBuffer in settings. maybe this causes this behavior
greets
enigma2-plugin-extensions-dreamplex_2.1.0-beta24_all.ipk
- fixed restore liveTv once more again
- removed show infobar on buffer empty - was not working
- changed to toggleshow for infobar
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta24_all.ipk
I have a question:
in system check i found out that i haven't got mjpegtools installed, but when i'm asked to install it cannot do it.
I use BH, where can i find ipk to install manually?
DonDavici or anyone, can you upload a Dreamplex 2.1 demo un youtube? I found only 1.x demos from long time ago. I'm planning to buy a vu+ and i want to know how well is working plex on dream/vu machines.
I have a question:
http://feed.merlin3.info/index.php?dir=mips32el/&file=mjpegtools_2.0.0-r2_mips32el.ipk
there will be a bigger review after the 2.1 is released as stable. but maybe someone else can post a short video :-)
opkg install mjpegtools_2.0.0-r2_mips32el.ipk
Installing mjpegtools (2.0.0-r2) on root.
Collected errors:
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for mjpegtools:
 *      libpng12-0 (>= 1.2.49) *
 * opkg_install_cmd: Cannot install package mjpegtools.
here you can find most of all ...
here is the missing one ..
http://feed.merlin3.info/index.php?dir=mips32el/&file=libpng12-0_1.2.49-r0-opt1_mips32el.ipk
enigma2-plugin-extensions-dreamplex_2.1.0-beta25_all.ipk
- added use forced subs in direct local mode
- implemented subtitle handler for direct local
- fixed liveTv in views
- some changes to avoid gs
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta25_all.ipk
enigma2-plugin-extensions-dreamplex_2.1.0-beta26_all.ipk
- fixed gs in player with subtitlewatcher
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta26_all.ipk
I have a problem.
On my vu+solo2 it is since three days that my box cannot download backdrops and posters of new added Movies or Series.
I have free space on Usb.
After i sync library or backdrops in the dir where i store them i find new files 0 dimension.
I found out that this is happening from when i installed this 2 ipk i attach.
Do you think there is something wrong with them, or maybe i have to check something else?
- made DreamPlex compatible with DM7080 and OE2.2
- fixed hopefully partsCount error
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta27_all.deb
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta27_all.ipk
I have a problem.
looks ok for me. send me the dreamplex of a sync and we can have a look :-)
Has anyone tryed this on OpenVix with a vu+ solo2 kernel version, 3.13.5, Gui version 2014-09-29
Sorry Dondavici, what do you mean with send me the dreamplex? DO you need Log?
I 've 2 boxes, on 1 it works on the other not so i think there must be something wrong with it.
- startup fix for remoteplayer
- fixed gs in player when no progress data
- avoid conflict with other skins in special cases
- small tweak
NOTE: currently there is work in progress with subtitles and remote player
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta28_all.ipk
http://dl.bintray.com/dondavici/Dreambox/enigma2-plugin-extensions-dreamplex_2.1.0-beta28_all.deb
sorry. yes i mean dreamplex log and if exists crashlogs :-)
I'll try do post log tomorrow.
I have another problem.
On myplex i have my local library and a remote shared library with some movies (about 10-12)
In Dreamplex all my local library has the right posters and backdrops.
While when i browse to remote library on the first movie i have the right name, but for poster and backdrop i have the one of the first movie of my local library. And so on for the second third and so on.
It seems that dreamplex choose the ordinal number instead of the name of the movie.
Is there a way i can solve?
Tnx
Tnx
Any idea about this problem?
Do you need any log?
Tnx
