'DVR Schedule' missing on Samsung-tizen - DVR is now useless
Server Version#: 1.25.7.5604
Player Version#: 5-33-1
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
Starting with release 5-32-1 the DVR Schedule function is missing on Samsung-tizen TVs. How do you locate upcoming recordings or schedule new ones (do not know what is already scheduled nor if something recorded from the guide is correct).
Thanks for your report. This raised some internal discussion and we believe that the DVR functionality has not been previously available on Samsung or other Smart TVs. Perhaps you had used it on another client? However, we have decided to release that functionality today to users and it should be available to you now. Thanks.
Thank you. This function has been on Samsung devices under ‘Live TV & DVR’ for a long time. Additionally, there is no longer a way to jump to future days in the guide (also was available under ‘Live TV & DVR / Guide’.
I’m fairly certain you’re mistaking the Samsung app UI for another TV app. As far as I recall there has never been a way to jump to particular days in the guide.
Thanks for the help with this. I am seeing an issue with the DVR Schedule that is different on the Samsung TVs than on my windows app or Roku’s. My old recording history is shown (today is Saturday 3/12 - am seeing all the way back to 2/21) along with upcoming recordings. All other platforms are just upcoming recordings. Not sure if the system will eventually remove the old schedules but so far nothing has been removed…
