DVR with Commercial skipping status
Whats the status of recording OTA news like ABC and CBS with plex removing the commercials?
It works. Need an antenna and a tuner. When you set the recording, you can opt to have commercials removed.
I mean, it actually works or you think it works?
I know it works because that is my recordings are setup and they don’t have the commercials. Its not 100% perfect, it does miss some occasionally.
Thanks for your reply. It appears to have been fixed.
Are you having trouble with viewing OTA recorded shows via a FireTV stick? Mine have been crashing since the new UI update?
I don’t use a firestick.
